08-13-2020, 07:44 PM | #1 |
Rep 18
New M5 Owner
Hello everyone! I've been scrolling through the forum for a little bit while I was car searching. I think "the one" has practically fallen in my lap. I work at a Chevrolet dealership and a customer traded in their M5 for a new C8 Corvette.
It's a 2013 M5 DCT non-comp package in Sakhir Orange on Black Merino leather with 34000 miles. VIN: WBSFV9C57DD095607 The price is right and the service records per the Carfax seem to be thorough. Regular oil changes and spark plugs replaced at around 23,000 miles. Otherwise, the car is bone-stock. I took the car home overnight and I think I fell in love haha. Everything worked flawlessly it seemed and it didn't skip a beat. All felt nice and smooth with plenty of power on tap. I pushed all of the buttons to make sure everything worked. Active seats, heated seats, cameras, different modes, etc. I feel like I've done a good bit of homework and research and have good history on the car to feel comfortable purchasing it, but I wanted to ask you guys what I need to be on the lookout for as common points of interest on these cars to make sure it's all in good shape. I know about the leaky coolant lines due to the bad clamps, etc. Just wanted to see if I can get a comprehensive list of what to check for. In the meantime, here is the listing so you guys can see the photos and info. https://www.hendrickatlanta.com/inve...fv9c57dd095607 TIA! |
08-13-2020, 08:37 PM | #2 |
Rep 1,254
My first thought here is - don't buy a 2013. I know they're cheap and enticing right now but most of the cars I see w/ blown engines due to faulty injectors are 13's. No idea why.
Coolant lines for sure and check for service rec's. That's critical, even at 34k miles.
2009 E92 M3 build thread: https://www.m3post.com/forums/showthread.php?t=1754875
Follow me on IG - www.instagram.com/the_driven_enthusiast |
vlad_the_impaler17.50 |
08-13-2020, 08:44 PM | #3 | |
Rep 18
I have read about the faulty injectors, but apparently it wasn't that common to my understanding? And it was less of an issue on the later '13MY build dates. Maybe I'm just misinformed. Did BMW also not issue an extended warranty regarding this issue for 10yrs/120k miles? If so, I'd be within that range. I will look into it some more. Last edited by vlad_the_impaler; 08-13-2020 at 08:49 PM.. |
08-13-2020, 08:53 PM | #4 | |
Rep 1,254
Overall, I think these cars are solid when cared for. Do your oil changes max every 7k miles. Use 5w40 and use a really good quality oil and filter. In general, take care of it and it will take care of you.
08-14-2020, 02:06 AM | #5 | |
60759
Rep 19,751
If it's non-modded keep it like that as BMW are clamping down on ones that have been or are modded as regards the warranty, they can find out and warranty could be void in event of a claim. 0W30 oil is recommended in UK/Europe on these to cope with the tight rod bearing clearances on ALL models.There have been r/b failures and thicker oils don't do them any favours at start up. Comfort entry models have had problems with door handles. Generally the more oil changes on these the better, every year or at 4-5k miles whichever comes first. Good luck and enjoy! Last edited by M5Rick; 08-14-2020 at 03:20 AM.. |
08-14-2020, 08:42 AM | #6 | ||
Rep 18
Now, for the oil conversation... which seems to be a point of contention on every car forum ever haha. I've seen most people saying to only run 0/5w-40 and not to run anything lighter than that. Yet you told me to run what BMW recommended which is 0w-30 I believe. If running the lighter oil may help the rod bearings, what are the downsides to doing so? Oil consumption? Insufficient lubrication at high temps? I do live in the south US where it can get to 100*F in the summer with very high humidity(yay Georgia weather). |
08-14-2020, 09:10 AM | #7 | |
60759
Rep 19,751
08-14-2020, 09:29 AM | #8 |
Rep 542
Living in Georgia I don't think it's going to make much difference whether you're running 0w or 5w. I believe BMW actually recommended 0w-30 or 0w-40, with 5w-30 and 5w-40 as alternatives. If choosing, though, I'd recommend a 0w-40. Personally I'm using Edge 0w-40, which is supposedly a better oil than their 5w-40, anyways. I noticed perhaps a very small MPG drop on highway going to a 40 weight, but definite reduction in oil consumption.
And as someone with the same color combo: good choice.
Sakhir Orange F10 M5 | KW V3s | Dinan Swaybars | Turner Monoballs | Soul Exhaust | Mishimoto Oil Cooler
08-14-2020, 09:34 AM | #9 | ||
Rep 18
Sheesh, 9.5 liters is a ton of oil. But the motor is a beast and the oil has to make it's way around to a lot of stuff so I guess that makes sense. |
08-14-2020, 09:40 AM | #10 |
Rep 542
It might get that cold overnight, but I'm guessing the car would sit in a garage, yeah? Either way, as long as it's a *good* 0w-40, I don't see a reason to not go that route.
08-14-2020, 10:14 AM | #11 | |
Rep 18
I'll probably just go with the Edge or Mobil1 0W-40 since those are the brands I've seen mentioned the most. Seen Motul a few times too. I've been out of the BMW game for a little while, so it's a ton of new knowledge to shove in my brain haha. |
08-14-2020, 11:15 AM | #12 |
Rep 4,209
Drives: '13 F10 M5 | '15 F15 X5
Overall the car looks like a deal. I did notice on the Carfax some minor damage but those are common. I also noticed the radar built in (very useful). To others point here, yes the 14-16 had some changes but there is plenty of us with '13 enjoying our cars as well. Just remember to keep up on maintenance, I personally do oil changes every 3-4k miles (Liquid Moly 5w-40). The turbo coolant could be a problem but you can easily do that repair at home (its like $60 in parts for all 4 lines).
08-14-2020, 11:21 AM | #13 | |
Rep 18
It did have minor damage, it looks like someone nicked the right side of the rear bumper. Would be an easy fix though for someone to take care of. All in all, the car seems to be very stout. I did forget to mention this, however. When the car first got traded in I took it for a spin right away. It was up to temp and as soon as I got on it, it smoked pretty heavily out of the back. I got onto it again, a little less smoke, and then it never did it again. I was initially concerned, but I asked the PO when the last time he drove it and he told me it had been sitting for about 6 months without being driven and that he barely drove it and babied it. I didn't tell him why I was asking, just asked while making small talk. The battery low warning was also on, which also seems plausible if it had been sitting for 6 months. I drove it again later that same day and took it home the day after and the smoke was completely gone and hasn't happened since. Anything to be concerned about or could it very well just have been because the car was sat for 6 months and the PO babied it? |
08-14-2020, 06:41 PM | #14 |
Rep 649
I wouldn't be overly concerned unless the smoke comes back. Use a very high quality fuel like Shell with V-Power and you should be good. I also live in GA and been changing my oil with Ravenol 0W/40 every 5k miles. Can help you change yours if need be. Good luck with the new ride.
08-14-2020, 06:49 PM | #15 | |
Rep 18
The oil change looks pretty straightforward as far as I can tell? Drain the oil, replace the cartridge filter, prime it with oil, button it up and fill it up. Am I missing anything there? Also, nice to know that you're in the area! Where at if you don't mind me asking? |
08-15-2020, 07:56 AM | #16 | ||
Rep 4,209
08-15-2020, 08:11 AM | #17 |
Rep 606
Drives: 2000 M5, 2001 M5, 2013 M5 6MT
You should buy the car. Seems legit. Sure there's updates for the facelift cars but the 2013's are certainly not bad. The car looks clean and is well optioned.
Seems like people covered the bases on maintenance. My 2 cents, run a high quality 0w-30 or 0w-40 oil, change at an interval you're comfortable with, but don't go the BMW recommended 10k? miles. I change mine at 5k miles for what it's worth. Since the car has sat a lot and you sound like a DIY guy, I'd change the plugs again. This way you can set the gap where you want them and know that you're starting fresh with your driving habits. I bet the car smoked a bit from a lot of idling that day and having sat for a while. Like others said, I wouldn't worry if it stopped smoking now. Probably just needed a good "Italian tune up". Another reason to change the plugs though. At this mileage, you should probably flush the brake fluid and change the diff oil if there is no history of them being done yet. Good luck! |
08-15-2020, 08:41 AM | #18 | ||
Rep 18
I also just stumbled on your Youtube videos and IG, quality content man! Quote:
I was thinking the same thing when I saw the smoke, and after I got on it a couple times it didn't do it again. Even later that day after it had sat and cooled down pretty much all the way. So I went from worrying like crazy to it all seeming to add up. Thank you for the tips, I have always changed my oil on any car I've ever owned at 3000-5000 miles. When I first saw the crazy intervals some manufacturers put on their cars it made me cringe a little bit. But it can't hurt to do it more often, so that's exactly what I'll be doing. Shortly after I get the car I plan on doing an oil change, plugs, brake fluid, diff fluid, and maybe injectors as a preventative measure? Anyone feel free to chime in on the injectors if that's necessary. The other question I have in my mind is carbon build-up. I feel like a motor such as the S63TU is very prone to have bad junk building up. Are catch cans necessary? Does the car already have a system in place to capture all the gross blow-by? Hell, does anyone spray meth just for the sake of keeping valves and such clean? I'll start reading up on it now, but I figured I could pick some brains while I was at it. |
Ickdeep5722.50 |
08-15-2020, 10:06 AM | #19 |
On the Go!
79
Rep 235
It's a well maintained and cared for vehicle. It seems like you plan on doing the same. I completely understand why not many would risk a '13, however, this one does not seem to be abused. The price is fair given the current times but not great, if it's in your budget go for it. Not many 13s go through BMW dealerships and head straight for auctions.
Also, like oil weight the make matters too. A BMW 0w30 oil is not the same as a similar weight from LM or Motul. You should pull the trigger and there are quite a few good threads here in the Maintenance section.
It doesn't matter if you win by a mile or inch, Winning is WINNING!
08-15-2020, 02:33 PM | #20 | |
Rep 18
The price it's listed online for isn't the price I'll be buying it for. It will more than likely be closer to $32000. |
Ickdeep5722.50 |
08-15-2020, 10:28 PM | #21 |
Rep 189
Welcome. I just got my 14 M5 in May for 30k with 42 on the clock. I dont drive it all the much but so far its lived up to its reputation. I have some turner axle backs to install and oil to change. you'll have a blast
08-16-2020, 10:18 PM | #22 |
Rep 18
Thanks! I can't wait to get mine. Will probably take delivery next week. I'll be driving it quite a bit. And probably wrenching on it quite a bit as well haha.
2013 Sakhir Orange/Merino Black M5
1989 Black BMW 325i Coupe |
Ickdeep5722.50 |
