08-17-2020, 11:56 AM | #1 |
Rep 212
2002 BMW E46 M3 / 55k Miles / VF Supercharged / Mint
2002 BMW M3 •Carbonschwarz on Black Nappa Leather • 55,828 miles • SMG transmission • Clean Title, No Accidents, No liens • Service records from new to 50k miles, all from the same local BMW dealership (Towne BMW) • Forth owner. • Full Power Heated seats • OEM Navi with 6 disc cd changer • Harmon/Kardon Sound System • Window Etching (security) • Sunroof • 2 OEM Keys, Valet and Service Plastic Key, with Original Booklet Navi DVDs etc Maintenance/Refresh History: • Full inspection II service about 400 miles ago (all fluids, oil change, valve adjustment, valve cover gasket, new spark plugs, filters etc) • New Battery (May 2020 3 year warranty) • New all OEM differential main pinion seal, output shaft axle seals, rear cover seal, drain plugs and Castrol fluid (May 2020) • Brakes 70% Front/Rear • Subframe was fully reinforced using Turner Motorsport weld in kit (May 2020). 3M seam sealed and 3M undercoated once done. All new bushings inserted(rtabs, sway bar, diff, subframe etc) • Vanos is without issues. Checked during Inspection II. • Fresh alignment (June 2020) • Airbag recalls completed (June 2020) Modifications: • VF Engineering 420 Super Charger kit with tune • Full Supersprint Section 1, 2 and 3 Exhaust • Status Gruppe SRS Coilover kit with Camber Plates, Front Adjustable Sway Bar Endlinks and Swift Springs 8kg front and 9kg rear (<200 miles) • Status Gruppe Front Carbon Fiber Lip (new) • New Power Flex Yellow Subframe Bushings (front and rear) • New Power Flex Black Performance Diff Bushings (front and rear) • New OEM RTAB Bushings with ECS Tuning Limiters • New OEM Sway Bar Bushings • APEX ARC-8 Wheels in Hypersilver 18x9 front and 18x10 rear (less than 200 miles on them) • 245/35/18 and 265/35/18 Hankook Ventus V12 Evo2 tires (less than 200 miles on them) • New OEM LED Amber taillights – Fully coded and functional • New OEM Amber Side Markers • New OEM Amber Front Corner lights • OEM Cross Drilled Rotors • Status Gruppe Carbon Fiber Rear Diffuser (partially painted to match) • New ECS Tuning lug bolt to stud conversion with black open end lug nuts (bolts are long enough to use 10mm spacer if desired) • New ECS Tuning Matte Black Kidney Grills • New Turner Matte Black Side Gills with new OEM M3 emblems • EAS Full Silver Carbon interior trims • Auto Tecknic Carbon Fiber shift change levers • Turner Rear Camber Arms (rod end) • Coby Wheel Suede E brake handle • OEM M3 black embroidered trunk carpet • Paint Matched Front Bumper Reflectors I purchased this planning to 6-speed swap it and keep it for a while but another opportunity presented itself and I couldn’t pass it up so sadly I’m selling it. Someone will enjoy the fruits of my labor as this should be setup well for years to come. If you have any other questions, feel free to ask me. I have a million more photos for interested parties I can send separately. CAR IS LIVE ON BAT!! PLEASE BID TO PURCHASE! https://bringatrailer.com/listing/2002-bmw-m3-148/
@S_bueme 997.2 GT3 E90 M3 |
08-19-2020, 08:29 AM | #3 | |
Rep 212
bump for the last day on BAT!! looks like someone is going to get themselves a good deal.
