09-28-2020, 09:35 PM | #1 |
Dictator for Life
343
Rep 560
Clutch Delay Valve removal MT
Anyone has been able to remove the clutch delay valve on our F10 MT M5.
The switch from 1st to second is really annoying especially on slow speed/startup in SportPlus.
03 e39M5 Imola Red-Tubi Exhaust/GROMAudio
16 F10 M5JavaGrun/MT/CP/CCB/B&O/ReaRDVD 23G82M4SignalGrun/MT/CCB/CarbonBuckets 09 Ferrari SCUDERIA Rosso Corsa 23CayenneGTSCoupe |
09-29-2020, 01:23 AM | #2 |
Custom User Title
80
Rep 103
I've done this on my F13 - I did it and also had a Rogue SSK installed, probably one of the best combinations I've done on this car besides maybe the KW H/A/S in terms of improving tangible feeling when driving the car.
You won't regret it, even if it is a bit of a pain in the ass.
2014 BMW M6 Coupe, Sakhir/Black, 6-Speed, CCB - DME/AA/Eisenmann/Rogue/KW/Brixton
2021 BMW Alpina B7, Frozen Black/Black 2020 Bentley Continental GT, Beluga/Grand Black 2016 BMW X5 35d, Alpine White/Black, MSport |
09-29-2020, 07:00 AM | #4 | |
Dictator for Life
343
Rep 560
09-29-2020, 09:48 PM | #5 |
Custom User Title
80
Rep 103
I didn't do it myself, but it's pretty standard stuff. We have the same manual transmission that's on many other BMWs. You buy the modified valve, bleed the system, and install it. Install is nothing special AFAIK.
09-29-2020, 09:51 PM | #6 |
Dictator for Life
343
Rep 560
What valve did you use? I have time next week, I try to do it.
09-29-2020, 09:55 PM | #7 |
Dictator for Life
343
Rep 560
This write up perfectly explains why my e39 m5 is smoother than my f10 m5. They said bmw removed the cdv on my e39 m5 but they kept it on the regular e39.
https://www.zeckhausen.com/catalog/index.php?cPath=6562
09-30-2020, 06:02 AM | #8 | |
Rep 606
Drives: 2000 M5, 2001 M5, 2013 M5 6MT
For the F10, spend the money on the modified valve if you like, but I just removed it and reinstalled the line. There is plenty of "length" in the hose to make up for there not being a valve in place. Bleed the line and you're GTG. |
thxbuff2001342.50 |
10-01-2020, 02:59 PM | #9 |
Rep 9
If someone does this, please take pictures. This seems like a mod I would like to do asap. I always thought the first gear clutch takeup seemed a bit vague, now I know why.
10-01-2020, 05:35 PM | #10 | |
Dictator for Life
343
Rep 560
I scheduled it next week with a mechanic. |
10-02-2020, 11:16 AM | #12 |
Lover of the 3rd pedal
70
Rep 103
Drives: '16 M5 6spd; '13 Audi S4 6 spd
In all seriousness, I just start in second all the time. Did it with my Audi S4 that I ordered new in '13 and drove the last seven years before my '16 F10 I bought at the beginning of this year. Would be interested in hearing more about this but would need to find an independent to do it. Original warranty runs out in 500 miles (or two months) and CPO is next year. Have only heard good things
10-04-2020, 01:16 AM | #13 | |
Custom User Title
80
Rep 103
10-04-2020, 02:04 AM | #14 | ||
70
Rep 103
10-05-2020, 12:29 AM | #15 | |
Custom User Title
80
Rep 103
Some people remove it altogether, which also works. I don't think your warranty is in jeopardy either way, but if you want to be safe do the modified valve.
10-05-2020, 08:09 AM | #16 |
Big girls don't cry.
125
Rep 506
The bleed process is what's stopped me thus far. If somebody can walk me through that, I'll do the removal and document it for the rest of us.
2003 E46 M3 COUPE - With "bolt-ons"
10-06-2020, 05:52 AM | #17 | |
Rep 606
The method I've used is a "soda pop" bottle (that's been cleaned - I've been bleeding brakes with it for years) with a hose resting on the bottom and attaching to the bleeder. Keep about an inch of brake fluid in the bottom to create an air lock. Air bubbles get pushed out while bleeding but no air gets pulled back in when releasing. Open the bleeder and pump the clutch using your hand... it will probably get stuck to the floor. Repeat a bunch of times, close the bleeder, pump up the clutch pedal and check feel. Repeat 2-3 more times, keeping an eye on the reservoir level and at your bottle for fill level and also to look for air bubbles coming out. Once you don't see air, it's probably good to go. There isn't much capacity in the system, so it really shouldn't take much to bleed it out. It's just that sometimes air can get trapped because it's hard to generate pressure to move things along when the bleeder is open. A power brake bleeder probably works well here, I don't have one to try though. |
10-06-2020, 12:05 PM | #18 | |
Rep 16
Also, did the clutch feel mushy or extremely soft thereafter? Does it change the clutch feel in any way? |
10-08-2020, 05:49 AM | #19 |
Rep 606
Removed it. Clutch felt the same as usual. A delay valve does not change the characteristics of the hydraulic system in terms of feel. It just slows the movement of fluid. Pedal effort does not change.
SGTVinny7.50 |
10-08-2020, 08:44 PM | #20 |
Rep 631
Drives: 2014 M6 Grand Coupe CP
CDV only affects the engagement rate. It prevents "dumping the clutch".
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination |
10-14-2020, 03:54 PM | #21 |
Rep 9
