10-04-2020, 07:41 PM | #1 |
Rep 9
Drives: 2020 BMW X5, Porsche Carrera
X5 Competition M Star-Spoke 809M Wheels
Will the X5 (G05) M Competition 809M style wheels fit on a X5 4.0i? I have the 742M wheels currently.
10-08-2020, 12:50 PM | #2 |
Rep 739
The 809M wheels are 21x10.5 +31 in the front and 22x11.5 +37, which means that compared to the 742M wheels, the fronts and rears will have 7mm less inner clearance, while protruding 19mm. This will work just fine.
10-08-2020, 07:00 PM | #3 |
Rep 9
Thank you for the information. So I should have no problem installing them on my X5? Thanks again, Chris
10-08-2020, 07:38 PM | #4 |
Rep 739
10-09-2020, 05:53 AM | #5 |
Rep 1,290
The G05 and F95 share the same platform, chassis, and the majority of suspension components. They also share the same body and fenders. Those wheels will absolutely fit., Like mentioned above though, the fronts are 21s, and the rears 22.... which is weird... lol
The only thing I'm not 100% sure about.... are the lugs. They are the same thread pattern, but the seats on the G05 are quite large. I'm not sure what the lug seats look like on an F95. If they are smaller, you may want to pick up an OEM set of lugs from an X5M at your local BMW dealer. I imagine someone can post a pic of X5M lugbolts though. If they look the same as your original ones.... you're good.
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019 690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813 6pot/4pot Big Brake Kit:https://g05.bimmerpost.com/forums/sh....php?t=2097342 |
10-28-2020, 06:06 AM | #7 |
Rep 1,314
I would confirm the hub sizes. Typically in the past the X5M and the X6M have had different hub sizes for the front and the rear. They would not fit the regular X's.
12-31-2020, 12:29 PM | #9 |
Rep 83
I think its a way of getting wider tires in the front and still be able to have close to stock rolling diameter. 1% difference compared to the rear wheel. You also have more rubber and maybe better grip in cornering.
09-02-2024, 03:30 PM | #13 |
Rep 78
Bump for more info/confirmation on this.
Looking at a used set of these for a summer wheel/tire set up for my wife's X5 40i.
Current: '16 328i XDrive Gran Turismo, '23 X5 M40i XDrive
Past: '23 GR Corolla, '19 RS3, '17 Tundra,'13 Evo X, '12 Mustang GT, '08 Civic Si, '03 Evo VIII, '01 Golf GLS 1.8T |
