      10-13-2020, 02:38 PM   #1
wifesbimmer
158
Drives: '20 X5 M50i, E92 M3, '16 F150
changing to the winter set
I live in Alberta. The old man winter tends to show up a lot earlier than the rest of the continent. I am planning on switching the current summer tires to the winter ones. Does anyone know what the torque setting is for the wheel nuts?
Thanks in advance,
      10-14-2020, 02:26 AM   #2
BHCJJS
21
Drives: '21 G05 x40i M Sport, '04 E46
It's in the "mobility" section of your vehicle manual, but it's 101 lbs ft / 140 Nm.
I still have about a month before I have to swap mine as well, but I no longer have access to a garage with a post lift, so I have to buy a floor jack and stands.
Do you mind sharing how you're doing the swap? Never done it without a post lift.
      10-15-2020, 01:50 AM   #3
Ninefourteener
Ninefourteener's Avatar
1346
Drives: 2020 X5 M50i, 2020 Alfa 4C
Stands are necessary if the car is going to be spending a lot of time in the air, and you're going to be underneath it.
For a tire swap? Just get a floor jack, and a few cheap BMW jack pads on ebay
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019
690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813
6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342
      10-15-2020, 02:52 PM   #4
wifesbimmer
158
you are right. I do not think the stands are necessary for this kind of a job. I am planning on just jacking each wheel, unbolt, swap and screw back on the bolts to the right torque. I will look into the BMW jack pads for sure. Thanks for the tips.
      10-15-2020, 03:09 PM   #5
wifesbimmer
158
Speaking of the BMW jack pads, can you recommend one?
Thanks
      10-15-2020, 09:54 PM   #6
BHCJJS
21
Thanks! I think I've been reading too much about people wanting to swap both front and back on one side at the same time, and thought that was normal.
      10-15-2020, 10:32 PM   #7
denaliman
denaliman's Avatar
470
Drives: 2021 BMW X6M Competition
2013 X6M  [0.00]
Thanks
These work I have a couple.
https://www.amazon.ca/POTAUTO-Univer...2819081&sr=8-3
_____________________________________
2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4
      10-16-2020, 10:19 PM   #8
wifesbimmer
158
Originally Posted by denaliman View Post
I just ordered a couple. Thanks
      10-24-2020, 08:01 AM   #9
Therealmatzaman
Drives: X5 G05
I bought my jack pads from turner before they had them on Amazon. Works great. I don’t use stands to switch bc each wheel is only up in the air a few mins. But I’d recommend floor chocks so it doesn’t roll. Unlikely but you never know.
