06-08-2021, 04:18 PM | #1 |
Rep 5
Ski Bag Delete
Anybody know how I finish deleting this??
I can't seem to pop it out. I removed all 5 bolts. From the trunk POV, it looks like the carpet's in the way.. but I can't remove the carpet because the ski bag is in the way.. |
06-08-2021, 07:11 PM | #3 |
Rep 2,232
I found this over on the e90 side for the install, doesn't seem to be any trick for install, so probably just need to pull harder?
https://www.e90post.com/forums/showthread.php?t=553388 And the diagrams on RealOEM look a bit different: https://www.realoem.com/bmw/enUS/sho...diagId=52_3381 |
tracer bullet2435.50 bman242.50 |
06-10-2021, 05:41 PM | #4 | |
Rep 5
Once I got the carpet out, I was able to pull the whole container. In case anyone in the future needs this, I attached some photos. Take a flathead and push/pry out the semicircle tabs inwards around the main hub. The front side holds the trim together in the 3rd pic, which holds the bag. I broke it prying the wrong way lol. The back side holds the door together. **PRO TIP** When you want to piece it back together, keep the door separate. Bolt the inside back first, then put the carpet liner in the trunk, then push the door back in. It was impossible to get the carpet liner around the back door with the whole thing assembled. I now have a normal pass-through, without the hassle of a skibag. |
Suprgnat2317.00 |
06-24-2021, 11:51 PM | #5 | |
Rep 34
How did you remove the carpet housing surrounding the ski bag? I need to get at my mulf unit and that’s in the way. |
06-26-2021, 07:44 PM | #6 | |
Rep 5
EDIT: Just saw your other thread. Look at my pro tip above. It's a bitch to put the carpet back with the entire ski bag unit intact. Should consider decoupling the door before putting it all back together. |
07-08-2021, 09:54 PM | #7 | |
Rep 34
08-09-2021, 02:15 PM | #8 |
Rep 5
Tags |
e88, ski, ski bag, trunk, vert |
