06-29-2021, 09:09 PM | #1 |
Rep 2,203
accusump valve selection
seeing consistent oil pressure drops on high g left hand turns, down to 25psi is concerning, even small turns like a chicago box will see a drop in pressure
Installing a 2 or 3 quart accusump, there are two options. Assumptions: Idle is 30-32 psi, on track psi is always over 80 except in high g left hand turns 20-25 psi switch, probably never trigger but is automatic 35-40 psi switch, must be enabled when I enter the track manually, will prevent deep dips 55-60 psi switch, must be enabled when I enter the track, should keep oil pressure graph flat
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten.. 1974 2002, many various 3s. |
07-08-2021, 08:58 AM | #2 | |
Rep 2,028
Just remember to wire in a switch so you can flip it back off at the end of your run. You don't want the solenoid constantly firing to release oil at 35-40psi idle. it will burn out. |
07-08-2021, 10:59 PM | #3 | |
Supreme Galactic Commander (one galaxy over...)
674
Rep 1,778
Best,
Andy '12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune |
07-19-2021, 07:32 PM | #4 | |
Rep 2,203
07-20-2021, 04:19 PM | #5 |
Rep 2,028
yepp and it's not like that will hurt the accusump. it will just bleed off a little pressure as it trys to keep you at 55-60. It's not like if you dip below 3,000rpm for a second or two the accusump will then be useless.
