08-01-2021, 07:00 PM | #1 |
Rep 2
Knocking/rattle after oil change
On my first start up after changing the oil, the engine made a knocking/rattle sound for about a second and went away.
Oil filter and drain plug were all reinstalled with no leaks and engine oil was at the proper level. Is this normal? |
08-01-2021, 08:40 PM | #2 | |
Rep 539
If not, then it's normal. However, it's good practice to do so. |
08-01-2021, 11:28 PM | #4 | |
Rep 2
This is the second time I have done this. Did I possibly damage anything? |
08-02-2021, 12:29 AM | #5 | ||
Rep 539
08-02-2021, 02:05 PM | #6 |
Rep 634
Air in the valve lifters, completely normal if it goes away after a second or two.
Could have the same if the car sits for a while between start ups. This is because all the oil has been drained to the sump and the oil need a couple of seconds to be redistributed inside the engine. I have an old car I drive 1-2 times a month, sounds awful every time I start it for 1-2 seconds If you have it when the engine is running you have lost oil pressure and a huge issue.
_____________________________
-14 Imola Red M5 Competition Pack (sold) -90 BMW 850i Supercharged -20 i3s -20 Ducati Diavel 1260s |
