08-12-2021, 11:53 AM | #1 |
Rep 2,982
CA Smog questions
I am reinstalling a stock x pipe in place of my akra evo mid pipes. I don't have a stock muffler so I was going to couple the stock x pipe to my rear akra mufflers. Will this cause me to fail the visual inspection even though it has no effect on smog whatsoever?
Secondly, is there an actual guidance on the type of drive cycles I need to go through to get my car to register all clear and O2 readiness? I had my car scanned and I only showed a battery fault from a momentary low battery warning and my EDC warning was on due to my coilovers. |
08-12-2021, 12:09 PM | #2 |
Rep 183
Drives: 91 M5, 98 M3, 08 M3
Catback does not matter, you will pass smog with the rear akra mufflers.
https://www.smogtips.com/BMWDriveCycle.pdf |
08-12-2021, 02:48 PM | #3 | ||
Rep 2,982
08-13-2021, 08:22 AM | #4 |
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
I failed with a stage 1 tune and stock exhaust. 02 readiness not set with the tune. Changed the tune back to stock and drove about 50 miles but didn't adhere to any specific drive cycle - just drove the car. And it passed smog.
Good luck and let us know how it goes. I now have an Akra slip like you and was told it passes visual in CA and I don't feel like changing it if I dont have to.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
08-13-2021, 11:02 AM | #5 | |
Rep 164
I also ran the Stage 1 tune and flashed back to stock in order to pass smog. I did not mess with the drive cycle to set readiness monitors. I drove down the fwy late at night going between 55-60 for 15 min. Turned around and stayed again at 55-60, very light on the throttle for 15 min. When I got home I plugged in my hand held scanner and all monitors were set. Last edited by pjk380; 08-13-2021 at 11:13 AM.. |
Longboarder3436.00 |
08-13-2021, 11:23 AM | #6 | ||
Rep 2,982
I'll try the late night run after cold start and keep it under 3,000 rpm as that drive cycle tip sheet says. Thank you guys for your input. |
08-13-2021, 11:52 AM | #7 | |||
1194
Rep 3,670
08-13-2021, 01:05 PM | #8 | |
Rep 6,771
Drives: 2016 BMW i8
08-14-2021, 11:13 AM | #9 |
Rep 743
I just passed smog on my Eisenmann Sport in San Marcos. The guy said he doesn’t care about the cat back, as long there’s no tunes.
