09-23-2021, 02:03 AM | #1 |
96
Rep 346
Best suspension mods for rear of F82?
I’m going to be getting my rear subframe replaced. I’m going to be going with Some budget Megan adjustable control arms and rear toe arms. What else do you guys recommend I do? Sway bar? Bushings? If so which bushings? What else should I upgrade while I’m in there? I’m on BC coilovers already FYI. Appreciate your recommendations!
09-24-2021, 01:46 AM | #3 |
Rep 3,729
Definitely upgrade to the turner diff bushing bracket while you have the subframe dropped. You could use two of the revised poly bushings from OEM BMW to reduce NVH.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
irunalot1518.00 |
09-27-2021, 01:57 AM | #4 | |
96
Rep 346
Long story short there’s a crack somewhere on there so I’m replacing the rear subframe. I figured since it’s it’s coming out I should do other whileiminthere upgrades. In this case I’ve gone with Hotchkiss front and rear sway bars which are Front 4 way adjustable- 32mm Rear 3 way adjustable - 25.5mm FWIW. Power flex bushings for the rear diff. The ECS toe link arms and adjustable camber arms. I still need adjustable sway bar end links for front and rear correct? Any recommendations? And anything else I should get suspension wise? I’ll upload pics of what I ordered. |
