10-30-2023, 02:53 PM | #1 |
Rep 16
Cold Start Noise
Read through some of the cold start rattle threads but most of the videos are no longer accessible and a lot of them seem to confuse the cranking rattle and the clunk after startup so I want to start this topic again.
My car recently developed a tick or rattle during crank and the first few seconds of startup until oil pressure is built. Is this the check valves? Or the chain tensioners? Has there been more people who has experienced it and fixed it? I've been able to reproduce this issue from just an hour of sitting, but it does get worse if it's been sitting for over a day. This video is me cold start my car twice and you can hear it only make the clattering and clicking sound on the first start. |
10-30-2023, 05:15 PM | #2 |
231
Rep 358
Drives: E53 X5, E83 X3, E93 M3
I want to say this is completely NORMAL. Mine does this as well on a cold start until oil pressure is built--lasts probably 1 to 2 seconds.
I'm sure others will chime in with their experience.
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
10-30-2023, 05:26 PM | #3 |
Rep 465
Mine does it. I want to say that over time oil drains through a check valve either in the oil filter housing (not sure ours have a check valve like some other bmw models do) or the check valves in the head or block (11367537692 or 11111734667 maybe?). I'll get the same noise if I do an oil change and drain the filter housing but forget to refill it with oil prior to the first start up. I think you'll find that others have the same noise but say its persisted over a long time and hasn't been a problem.
RocketyMan230.50 |
10-30-2023, 09:52 PM | #4 |
Rep 1,118
Drives: 2009 E92 M3 Dakar Yellow II
Mine does it for like a second or two. I thought it was probably the vanos system pressurizing, it mostly happens when the car has sat for a week or more. Never during daily driving.
RocketyMan230.50 tlrid3r513.50 |
10-30-2023, 11:41 PM | #5 | |
231
Rep 358
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
10-30-2023, 11:47 PM | #6 |
Rep 1,118
10-31-2023, 07:38 AM | #7 | |
63944
Rep 24,830
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
10-31-2023, 05:36 PM | #8 | |
Rep 16
///M Power-Belgium63943.50 |
10-31-2023, 08:51 PM | #9 | |
63944
Rep 24,830
Your noise and my noise and the noise from all the other S65 owners is the same clattering cold start noise . S65 daily-drivers won't hear it . When I daily drive my car , I don't hear the noise anymore . As far as I know , it was fixed only 'once , by replacing the S65 Vanos-Gears. The S65 rattle noise was a 2008 BMW-Puma case . "Client reports rattle noise on cold start" As you can see ..
10-31-2023, 10:18 PM | #10 |
231
Rep 358
Yeah. There's that, then there's this spring/check-valve on the other end of the OFH.
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
spammysammich1598.50 |
11-01-2023, 01:50 PM | #11 |
Rep 934
Drives: E90 M3
In my experience the post oil change clatter (if you didn’t fill housing with oil) is much much more loud/violent than the VANOS rattle. Similar, but different enough to agree with ///M Power-Belgium this sound is the VANOS adjusters making some noise.
Both ideas are in the same vein, one could pop open the filter housing after a long sit and see if it’s empty or considerably lower level of oil than usual prior to cold start. |
11-01-2023, 02:54 PM | #12 | |
63944
Rep 24,830
Yeah mate I know . Sometimes the cold start clatter noise is just 'frightening . As I said , if you want to get rid of it , just 'DD the car (daily-drive-it) Or at least , twice a week. And you won't hear it ..' My car is a garage Queen , and drive it only during summer weekends . This means , I won't get rid of it , just like many other S65/S85 owners . So , the cold start clatter noise is actually a 'choise . But it's definitely 'not normal(!) On the other hand : After 10 years I know , it won't hurt our S65 engine . Can't be otherwise ..
11-01-2023, 08:07 PM | #13 | ||
Rep 16
11-01-2023, 08:40 PM | #14 | |
63944
Rep 24,830
If you can reproduce the clatter noise in about 45 minutes of sitting , I really wonder what your BMW/Dealer would say and do about that ...'
11-01-2023, 08:56 PM | #15 |
Rep 1,118
I’m putting out the Bat signal. deansbimmer would you care to comment on this thread?
11-02-2023, 08:30 AM | #16 |
Rep 934
Drives: E90 M3
11-05-2023, 04:05 PM | #17 | |
Rep 465
Robocop30512.00 |
11-06-2023, 03:25 PM | #18 |
Rep 25
just to chime in. My car has been making this noise for the last 8 years that I've owned it. Quite spectacular if you're in an underground carpark!
02-20-2024, 11:39 PM | #19 |
Rep 16
Late update, was chasing other issues with the car but I've replaced 2 of the 4 check valves in the head, 1 in each. Part #11367537692
Seems to make it happen less consistently, but inconclusive. Did a track day and didn't encounter the noise for almost a week, but now it is back from time to time. Seems like if the start is rougher (colder, higher rpm start?) it is more likely to make a louder racket, otherwise it is more subdued now: I guess I'll never know if those valves fixed anything |
02-21-2024, 08:02 AM | #20 |
Rep 146
02-21-2024, 08:46 AM | #21 | |
Rep 3,994
I guess the clunk hasn't brothered me enough to address, but if I am there in the future i'll throw them in.
02-21-2024, 05:11 PM | #22 | |
Rep 16
The clunk at the end is nothing in noise level compared to the clacking it makes during crank, so I haven't really cared about it. Might've been making it the whole time I owned the car. |
