01-05-2008, 08:31 PM | #1 |
Rep 143
How did 335i fair against M3 on a track?
I hear stories about 335i being actually faster than E46 M3 on a drag because of its Twin Turbo power over the revs.
What about around a track? was the suspension up to par on the 335i? Did it have an LSD? I asks these questions because as good as I imagine the 135i to be....I have a feeling the suspension is a bit weak.
AlpineWhite (deciding)
Black Leatherette (for sure) Glaciersilver or Highglossblack trim Sport Package Active Steering Manual Transmission :roundel: |
01-05-2008, 09:41 PM | #3 |
formerly izzo/comeback
287
Rep 3,382
stock for stock its 4 sec slower... mainly thru turns on the ring
http://bmwblog.net/?p=210
BMW CCA # 418268
01-06-2008, 12:13 AM | #4 | |
Rep 43
01-06-2008, 01:02 AM | #5 | |
Addicted Member
15
Rep 603
:roundel:
[SIGPIC][/SIGPIC]
01-06-2008, 01:16 AM | #7 | |
Rep 8
Not knocking the M3 as it is a sweet ride but comparing the two is kind of like comparing a Dodge turbo diesel to the same truck with a Hemi. The Turbo Diesel will run with the Hemi and not have to be twisted as hard. I wish I had the 335 motor in my wife's Z3. |
01-06-2008, 07:54 AM | #9 |
2148
Rep 10,176
As the article was written in Sept 2006, it was the E46 M3. That was long before the e90/e92 were even announced, never mind being made available for testing.
With the 135i being reported as just a bit better in performance, braking, and handling than the 335i, pretty much universally, I wonder how the M3 vs. 135i would be? |
01-06-2008, 05:39 PM | #11 |
2148
Rep 10,176
True, but also put those same tires on the 335i too then, instead of the runflats they used in that test. I see the 335i as handicapped, in that regard.
01-06-2008, 07:34 PM | #12 |
Rep 65
Can you really use tires as a point of contention though? You'd have to stipulate the level of modification acceptable for the test. OEM if they don't have the same tires you'd be changing them from their true original competitiveness. If you allow that then it's not quite the same.
It seems that the auto journalists have been knocking the 135 as a little soft compared to what they'd like, if not what they'd expected. I can't help but think that there might be an even more capable 1 in the works--despite that as of now there won't be an M--which is worth waiting for. |
01-06-2008, 07:37 PM | #13 | |
15
Rep 361
my guess but 135i for meh, costing a pretty penny already.
:roundel: :roundel: :roundel: :roundel: :roundel: :roundel: :roundel: :roundel: :roundel:
01-07-2008, 01:24 PM | #14 | ||
Rep 6,759
They should have taken the most capable M3 from one of the last production years, not from the first production year. And I hope those numbers were recorded on the same day with the same driver, otherwise they're not very accurate (meaning, were the M3 numbers from the year 2000??). I drove my 335 on the Nurburgring and while I would never claim that I pushed it beyond 80% overall, I was dissappointed in the extra suspension flop. Quote:
Whether it will be sufficiently tight, well, we'll see...
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
01-07-2008, 01:43 PM | #15 | |
57
Rep 1,396
The OP just wants to get a general idea about the M3 vs. the 335i to get a feel for how the 135i might stack up against the M3. I mean, you're talking about switching out tires, and the OP is talking about switching out entire vehicles (sub'ing the 335i in for the 135i to make a general comparison against the M3) :iono: |
01-07-2008, 02:02 PM | #16 | |
Rep 119
Drives: 135i N54
01-07-2008, 02:15 PM | #17 | |
Rep 6,759
In EU say on the 3 series, the "Sport" package is different than the "M Sport" package. Who knows? I think it will be measurably tighter than the 335 "Sport", probably as tight as the 335 "M Sport".
01-08-2008, 01:58 AM | #19 |
Rep 570
02-06-2008, 03:17 PM | #21 |
Rep 186
+1 ! Actually those are stunning numbers. The 4 second delta is well within the realm of driver variance or even variance in track condition from run to run. Effectively equal I'd say.
135i built 2/14/08 SGM w/Black and AL, 6 forward gears
02-10-2008, 07:48 AM | #22 |
Rep 812
