Coby Wheel
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics
      03-20-2024, 10:17 AM   #1
tgb1974
Drives: 2016 F83 M4 (DCT)
NBTevo iDrive display too dim in the daytime?
I have been periodically frustrated/confused my my NBTevo iDrive display dimming during the daytime. I remembered being able to adjust the brightness on the display in the settings menu, but in iDrive 6 that option disappeared and was replaced with only permitting a brightness adjustment at night. Why BMW changed that is beyond me.
Anyway, as you may or may not know, three is a coding solution to this. kubax86 just fixed this for me. Took 5 minutes. He changes the head unit parameter "dim_variant" from "new" to "old."
After that, the general display brightness setting is available in the settings.
The attached picture (which is not mine, I found it on the internet) illustrates the before and after difference.
2016 BMW F83 ///M4 Tanzanite Blue Metallic/Silverstone Full Merino // NBTevo ID 6 retrofit // G3x/F90 10.25" MGU display retrofit // GTS flash // SmartTOP // 437M + Pilot Alpin PA4 (winter) // 359M + ContiSportContact 5P (summer)
Retired: 2013 E93 M3 | 2015 F22 M235i xDrive | 2012 E70 X5 xDrive 35d | 2010 E90 328i xDrive
      05-10-2024, 10:15 AM   #2
Dorian_M4C
Dorian_M4C's Avatar
Drives: BMW M4, saab 93, Audi a4
Damn, how exactly did he do it? Was it remotely? Mine is the same right now, a lot of overcast and it’s extremely dim smh
Dorian M
      05-10-2024, 03:02 PM   #3
tgb1974
If your head unit is original and you did not already modify the original coding (such as to enable CarPlay if you did not have it originally), you can do this yourself using BimmerCode. This is how:
In the head unit ECU, go to:
HU_NBT2 - 3005 Display PIP Info - DIM_VARIANT
Value will be set to NEW. Change the value to OLD. That's it!
If, however, BimmerCode will not allow you to access your head unit, you should ask kubax86 to do it remotely for you. Took 5 minutes.
f80post
