05-04-2024, 08:46 AM | #1 |
Rep 1
2015 M4 Buying Advice
I am currently in the market for a 15 M4 i’ve found one near me with 21k miles listed for about 47,000. Would this be a good deal? I know the crankhub can be an issue with the S55 is there something else i should also look for while test driving the car. If you have any other suggestions or advice they would help greatly.
Carfax Link: https://www.carfax.com/vehicle/WBS3R...331059?no_ul=1 |
05-05-2024, 11:16 AM | #2 |
Rep 181
Mine a 2015 with 20k miles and I have never had an issue with it but it’s a weekend summer car vs a daily driver. I don’t think the crank hub is an issue unless you plan to modify it and increase power substantially. Others can certainly weigh in with their perspectives/experiences as well.
Just recognize the connected drive apps will no longer work on this year as the 3G sunset impacted this year. If that’s important to you, factor some kind of upgrade into your spending. Also, you may want to see if the car is in the original tires. At this point they likely need replacement even if tread depth is still good based on being 9 years old. Good luck. |
05-05-2024, 11:53 AM | #3 |
We are what we allow ourselves to be...
85
Rep 96
Does look well take care of. Does not appear to be a competition package as it's a 2015 model, missing features in the pictures, and coding.
https://www.mdecoder.com/decode/wbs3r9c53fk331059
05-17-2024, 12:00 AM | #4 |
Racecar Driver
1323
Rep 2,004
Drives: BMW M4
Do a PPI. That’s all I’m going to say.
