      06-05-2008, 06:00 AM   #1
Kris
123
Drives: m3
Smile Can somene help...
This 'feature' is driving me nuts. When I unlock the car for both doors (coupe) and then open the drivers door, the whole window goes down. This usually isn't a problem but in sydney it's pissing rain so the car ends up looking like a pool on the inside!
Further, how can I disable this double door lock open thingie??? and how can enable opening both doors from open? Is this a dealer only thing?
Thanks gurus!!
:roundel:
      06-05-2008, 06:02 AM   #2
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
The dealer has to program your remote Kris..
      06-05-2008, 06:09 AM   #3
Kris
123
Drives: m3
Crapo. Ill get them to do this.. Thanks!
      06-05-2008, 06:12 AM   #4
SimonB
135 to 335 M Sport to X3 30d M Sport
Australia
164
Drives: 2018 X3 30d, optioned up!
Don't you just love technology! Haha... This shouldn't be a dealer program thing though.
2018 X3 30d, Carbon Black Metallic, M Sport Package, Panorama glass sunroof, Lumbar support, Instrument panel in Sensatec, Ambient Lightning, Harmon Kardon Surround Sound , Dynamic Damper Control
      06-05-2008, 06:14 AM   #5
Kris
123
Drives: m3
I read my manual and couldn't find it!? Found stuff about day time lights and whatever else...
      06-05-2008, 07:23 AM   #6
white 125M
white 125M's Avatar
11
Drives: White 125 M Sport
Kris, obviously not what's supposed to happen but this happens on the Z4 and there is a technique you could try on your 135 which may work. Sitting in the car (drivers seat), close the door, then with key in ignition and turned onto ACC or with engine on (your choice), lift the window switch but don't lift through the detent. As the window approaches the top of travel, you may need to finesse the the final bit of up travel until the window reaches full travel. Then, hold the window switch up through the detent and hold for 4 or 5 seconds and then release the switch. Open the car door and the window should drop slightly and then return to full up position when you close the door.
What may be happening here, is that the window as an anti-trap feature and it's 'memory' may think there's something there - what you're trying to do with the technique (above), is to re-calibrate this mechanism. Happens all the time on the Zed's, bit of pain but usually gets out of sync when raising and lowering the roof. I'm surprised the manual doesn't describe how to reset the window but give my suggestions a try - you might need a couple of goes to finesse the procedure but I reckon it should work.
Cheers,
Phil
      06-05-2008, 05:01 PM   #7
Kris
123
Drives: m3
Thanks Phil, I'll give this a whirl. It only seems to happen when I unlock both doors which is quite strange!
Ill give that a go!
      06-05-2008, 06:13 PM   #8
Rob
Drives:
think you press the key flop too many times: 1st time to unlock the driver's door - 2nd time to unlock the passenger and boot - the 3rd time you press the key - the windows will drop when you physically open the doors (all in the instrution manual)
      06-05-2008, 06:20 PM   #9
Kris
123
Drives: m3
I swear I press it twice. Ill double check
      06-05-2008, 06:27 PM   #10
blackie36
Drives:
On mine, if I click the remote to open the doors and hold the open button down, it unlocks and opens the sunroof and both windows. If I just click once, it just unlocks the doors.
Not sure if that helps??
      06-05-2008, 06:33 PM   #11
Swift135
Australia
23
Drives: 330d, M3 DCT E92
Kris, check your email!
      06-05-2008, 06:55 PM   #12
WAY
Australia
458
Drives: Fast ones
I have ze answer.
When you press twice, it is designed to drop the window. Unfortunately because your car is set to open only the driver's door with one press, the second press obviously causes the window to drop. To change it, you need to go to the icon with a key and a tick. Sellect that, then scroll down the icon that has three vertical lines and one 45 degrees angle line. That is meant to be one door open (in a 4 door car I guess). Select this and change it to the icon with four 45 degrees lines.
How did I know this? I went through the same bloody problem! Lol
      06-05-2008, 07:01 PM   #13
Kris
123
Drives: m3
haha nice one Wayne! I'll give this a go How annoying is it!?
      06-06-2008, 01:43 AM   #14
imported_Dodgy
Australia
Drives: SG 135i 6M
The reason the window drops is for easier access in a tight spot. You can open the door a little to squeeze in, but with the window up, whilst the door space is wide enough, the window crowds the entrance. It's programmed to drop the window lower when you press TWICE.
Options are (until re programmed)
Press once, and unlock passenger door from inside (although I think just one press should unlock both if you've selected the "easy access window thingy"
Press twice when it is a tight squeeze and you want to "slide" into the car in a tight spot.
Could tell you how to fix it with iDrive (easy), but not with standard display.
I know it seems an annoying feature, but it's quite clever for its purpose really.
Delivered! 1700hrs Tues May 20 2008: Sparkling Graphite, 6MT, Black Boston Leather, Accented Aluminium, Sun Roof, Pro Nav, Comfort Access.
      06-06-2008, 01:58 AM   #15
Kris
123
Drives: m3
Thanks dodgy, going to disable it. I dont find having the window down makes it really that much easier, rather have the window up for when its rainin!
      06-06-2008, 05:08 AM   #16
imported_Dodgy
Australia
Drives: SG 135i 6M
Absolutely. You only need it if parked in a tight spot.
At the moment, I am trying to park with nothing within 4-5 metres of my doors.
      06-06-2008, 05:10 AM   #17
Kris
123
Drives: m3
Well, I set the unlocking to open both now from a single unlock press.. works better. The second press still lowers the window all the way down, doesnt appear that can be changed.
Further, it appears that the car only will turn on all the welcome lights when the lightswitch is in the AUTO position. If its in the OFF position, and you leave/reenter the car the welcome lights won't come on?
Anyone know how to have them on perm when opening the car regardless of the switch? More than likely another setting I guess???
      06-06-2008, 05:42 AM   #18
MMMMM3
MMMMM3's Avatar
Australia
Drives: 2011 Jerez Black e90 M3 DCT
Should I just order Comfort Access to avoid this problem? Or won't that help?
      06-06-2008, 06:36 AM   #19
Alext
138
Drives: B M W
How do you disable this without using the Nav?
      06-06-2008, 07:06 AM   #20
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
Na...I have CA and I am in the same boat as Kris..:iono::iono:
Will have a better look at it in the morning..
      06-06-2008, 07:27 AM   #21
Kris
123
Drives: m3
CA won't fix/change this. Its just a setting I need to find.... its only minor! Theres alot to tweak in these cars..
      06-06-2008, 07:43 AM   #22
Alext
138
Drives: B M W
Let us know how you go guys....cheers!
1addicts
