      12-13-2008, 01:16 PM   #1
Luvmybmw
One Fast 1
Luvmybmw's Avatar
Drives: '08 AW e82
Installing M door sills
What is the best way to install the M door sills. I have read all you do is remove the old and replace the new, but how do you accomplish this without breaking anything. Thanks for any help and/or advice.
      12-13-2008, 03:45 PM   #2
Lester
Drives:
By the looks of the drawing on Realoem, those little clips should just pop out. You may want to have some new ones on hand in case they decapitate themselves. I would just pry gently with a flat trim remover, and see what happens. I recall someone on this forum said they did not take long to replace.
      12-13-2008, 04:13 PM   #3
Oregon
NRA Life Member, BMW CCA 30 year member
Oregon's Avatar
Drives: 04' M3
1971 2002  [0.00]
2004 M3  [0.00]
2008 135i  [0.00]
http://www.1addicts.com/forums/showthread.php?t=10095
:wink:
Resigned 1ADDICTS Moderator
“To disarm the people is the best and most effective way to enslave them.” – George Mason
      12-16-2008, 06:22 AM   #4
Luvmybmw
One Fast 1
Luvmybmw's Avatar
Drives: '08 AW e82
Thanks...a good "tool" helps to remove the clips. Once they are off the install is very simple.
This is what is used...
      12-23-2008, 09:32 AM   #5
CoolToolGuy
1er Happy Camper!
CoolToolGuy's Avatar
Drives: '09 135i,'07 X3
+1 - Speaking from experience, since the door sills are plastic, it is very easy to ruin them if you don't have the right tool
I was determined to get the M door sills on the car immediately, so I used a flat tool to try and pry out the clips - I got the door sills off, but the grooves that the clips fit into ripped, and the clips stayed in the body. I had to pry them out, and some of the clips broke. I didn't care so much about the stock door sills as I don't think they are going back on, but I may need to remove the M sills sometime in the future.
So the moral of the story is use the right tool. I'm checking around for it now. :thumbup:
Have Fun,
Rick
      12-23-2008, 09:51 AM   #6
Luvmybmw
One Fast 1
Luvmybmw's Avatar
Drives: '08 AW e82
Have Fun,
Rick
1addicts
