02-27-2009, 08:35 PM | #1 |
Rep 48
Squeaking Brakes
New 2008 M3. Problem is loud, obnoxious squeaking brakes, I believe front driver side. Happens when the car is warm, only when coming to a slow stop, and lasts a long time, not just a sqeak when I come to a stop. Car has 1,400 miles. Took it to dealer once and they looked at it and couldn't find anything wrong. Took it again 2 weeks later and said please, fix this f*cking noise.. They out nickel on the brakes and said that should take care of it. Problem is it almost sounds worse! This is pissing me off.. The head mechanic agreed with me that the squeaking is not the normal squeak you sometimes hear with these brakes, but in the shop twice with no luck.. Anybody else have this problem? Again, its coming to a slow stop and lasts for a couple seconds, not just a squeak at the end.. Anyone?
02-27-2009, 08:42 PM | #3 |
Rep 235
they told me it was some "emergency brake spring" thats what it said on the paper.. was removed / fixed.
yes, it did solve the problem for about a few weeks... then the squeeking came back -___- |
02-27-2009, 11:15 PM | #4 |
Rep 409
Mine has 90 miles and it is squeaking. I thought it was because its new. I am taking the car in for a Manufacterer defect in the hood. Paint/bump to fix , will have brakes looked at also! Buy you're right only happens when letting off pressure when coming to a stop. Not at full pressure. Good luck.
09'M3 JerezB/Tech/Cold/Prem/PDC/SR/Black Leather/ANTHRACITE Sycamore/IPOD/USB/Rear Sunshade/Premium Sounnd/6MT***Just Hit The Ground! Delivery 02/25/2009***
02-27-2009, 11:34 PM | #5 |
49
Rep 341
mine squeaks too! but i'm pretty sure that it is very normal. Sometimes due to the weather, heat/moisture, and dirt, it causes dirt/objects to get in between the brake pads and the disc. causing some squeak. I'm my opinion, it does not really matter.
2008 AW/BLK M3 6MT / Eisenmann Race / H&R / HID Angels / 3D Front & Rear Lip / UUC SSK / TE37 / Turner Pulleys / 4.10FD & 2 Clutch Salisbury Diff / Escort 9500ci
02-28-2009, 01:05 AM | #7 |
Rep 666
mine squeak sometimes when i'm going very slow and braking. i just let go and step on the brakes again. It's not too annoying as it's only when i'm braking at less than 10mph and coming to a stop and it's only if i'm braking lightly
2008 E92///M3 - | Alpine White/Fox Red Extended Novillo | Technology | Premium | Cold | Mods: | 19" Avante Garde | Macht Schnell Filter | RPi Scoops | Rogue SSK | MS Spacers | ACM Test Pipes | ESS Tune | Remus Race | LUX V4 Angels | KW V3 | |
02-28-2009, 06:57 AM | #9 |
414 little horsies
56
Rep 405
i dont have the squeak at all
thats because i properly broke in the breaks Just do the following: from 5 miles an hour go to 60 miles an hour fast and break as hard as you can until 5 miles an hour then repeat 8 times Ur Squeak will disappear
Race Precision Inc
02-28-2009, 08:04 AM | #10 |
Rep 6,007
They all squeak, mine is very loud from the front at slow speed stops. It's worse under 40 degrees. Over 50 or so I never hear the noise. Supposed to be normal though on high performance brakes at least according to the manual.
02-28-2009, 09:03 AM | #11 |
Rep 48
no, this is not the squeak referenced in the manual, the mechanic who drove it with me said as much, and he's been working on BMWs for over 20 years.. however, they can't seem to fix it, as the nickel they put on the brakes does not seem to be doing anything..
03-16-2009, 05:28 PM | #12 |
Rep 791
mine used to squeak at very low speeds and slow stops from 1000 -2500 miles, now i have a little over 4000miles and the squeaking is gone, the dealer had told me to deal with it because nothing is wrong and it turns out nothing was wrong just requires a little time to break in which is easier to do of course after the break in period of the engine
SOLD Current 2008 Space Grey E92 M3 * JRZ RS Pro * TE37SL * AP Racing * Sparco Evo * Akrapovic Slip On * Studio RSR Cage *
SOLD 2003.5 E46 M3 * Apex ARC8 * MCS 2-Way * Stop-Tech C43 * Recaro Profi XL * SOLD 2008 Jet Black E92 M3 * HRE C20 19in Wheels * KW Clubsport * Huper Ceramic Tint * Stop-Tech Trophy BBK * Gintani SC & Gintani Custom Exhaust * Vertice Front Bumper * Arkym Diffuser * |
03-16-2009, 10:37 PM | #13 |
Rep 5,448
mine dont squeek. or maybe I am just used to the Hawk hp+ pads on my e46.
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
03-23-2009, 08:10 PM | #14 |
Rep 655
Drives: Gone- 08 DCT SSII, 2006 SMG
Location: Current: 2014 BMW 4-Series Convert for the fiance w M Package, F150, 06 S2000, 08 911 c4s
i just had my 19's put back on and this is the first time i noticed a squeak...... i watch the mechanic use a torque wrench to tighten the rims vs an impact gun so i don't think they are over tightened. it seems to be at slow speeds when i turn..... from the drivers side.
2008 SSII DCT M3/Peapack/Parsippany NJ
03-23-2009, 08:50 PM | #15 |
Rep 1,198
Mine squeal/squeek too and I'm at 7500 miles. It's the pad compound that is causing the problem. Similar to a full race pad, it squeeks. If you change the pad to one that doesn't squeek, you will lose performance in the brakes. They'll still work but probably won't have the same feel or heat tolerance.
BC
'15 M3, '16 911 Turbo S Cab
04-01-2009, 12:45 PM | #16 |
138
Rep 2,386
does the 5-60-5 mph thing really work? im about to tell them to replace all my pads and rotors and everything so i can do this lol
or can u do it from now even? at 4600 squeeky miles? |
04-01-2009, 01:10 PM | #17 | |
Rep 110
This is true but the pads are bedded before being installed at the factory. If the OP's squeal is abnormal as described, he may have very very slightly warped a rotor, causing excessive vibration between the pads and rotors.
“Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?"
-George Carlin |
04-16-2009, 06:52 PM | #18 |
Rep 1
I can't help but notice this thread. Here's a bed-in procedure you can follow.
http://www.stoptech.com/tech_info/wp_bedinstock.shtml Typically OE pads, and rotors from the factory whether on a new car or installed from a dealer aren't bedded in. There aren't instructions on new cars to bed-in your brakes(heat up the brake pad material and transfer the material to the rotors) |
04-16-2009, 07:10 PM | #19 | |
Rep 135
same!
I am having the same problem. Have u fixed the sound, know how to fix the sound, or where the hell its coming from?
330i '04 sold
335xi '07 400hp sold 435xi '14 360hp sold M3 CP '17 444hp |
