BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      04-22-2009, 05:51 PM   #1
J08M3
J08M3's Avatar
Drives: 2011 M3 COUPE
Where's the 1/4 mile times???
We need to get some 1/4 mile times to compare aftermarket mods. In my opinion this will be far better than dyno results. This is the real world and what all of us will be feeling when we drive our cars. The dyno results posted on this board are all over the place, even on stock cars. It's way to easy to manipulate the dyno to show gains. Many people don't even know how to use a dyno correctly to get accurate real world readings. Especially to show gains with ECU flashes. If you're not using the dyno correctly and go to tune the ECU you are doing nothing more than correcting your dyno mistakes. Here's a couple interesting reads on dynos
http://www.dinancars.com/bmw/technia...ern-bmw-engine
http://raceprecision.com/forums/viewtopic.php?f=3&t=105
Of course every 1/4 mile pass will be different, but so is every dyno run. You need a good number and an average with the same driver. Baseline then with mods.
      04-24-2009, 07:21 AM   #2
J08M3
J08M3's Avatar
No one's with me on some 1/4 mile times? Is this cause most bolt on mods won't show any improvement in 1/4 mile times?
The other good thing about 1/4 mile time comparisons is you can show improvements from mods such as weight reduction, differential gears, possible quicker shifts with ssk or clutch stops, suspension changes (although those are better on a track for a M3). No need to worry about how to setup a fan to get your scoops to work.
      04-24-2009, 07:44 AM   #3
dcstep
Drives: '09 Cpe Silverstone FR 6MT
2009 M3  [8.40]
You go first.
If you do your baseline on a dyno and then the after on the same dyno, with the same correction factors, then the difference is real. If you want to risk your rear end on a drag strip, then go ahead. I'm looking forward to your report.
Dave
      04-24-2009, 09:04 AM   #4
J08M3
J08M3's Avatar
Originally Posted by dcstep View Post
You go first.
Dave
It takes a little more than just correction factor to get accurate dyno readings.
Your rear end isn't risked anymore on the drag strip than any time you drive your car. Unless you're not flooring it, in which case your aftermarket mods mean nothing anyway. If I had a local drag strip I'd be more than happy to post times.
      04-24-2009, 09:19 AM   #5
SS32
SS32's Avatar
156
Drives: 2008 M3
I'll disagree with you on that. These cars aren't made to run down the strip, they're made for the track.
      04-24-2009, 09:27 AM   #6
J08M3
J08M3's Avatar
I agree these aren't drag race cars. But you're seriously telling me you don't think it can handle a few 1/4 mile runs to test out HP gains from mods? Now if you put some slicks on it you might start ending up with problems. Some track times to compare mods would be nice too, but it's going to be far harder to compare 10 or 20 hp gains on a full track.
I think many people would be shocked to see the thousands of dollars they're spending on mods are not going to give them the time gains they would expect in a 1/4 mile. Showing a .1 difference in 1/4 mile time looks a lot less impressive than showing 10Hp or so on a dyno.
      04-24-2009, 11:08 AM   #7
Oakleyguy
Resident Engineer
Oakleyguy's Avatar
Drives: Land Cruiser
2014 Toyota URJ200  [0.00]
2017 BMW M2  [0.00]
2015 BMW M4  [10.00]
2005 Toyota UZJ100  [0.00]
It's a valid point, but does it hold true for the e92? (Axle Breakage in specific)
      04-24-2009, 11:16 AM   #8
J08M3
J08M3's Avatar
I agree PG, but I think you only get cherry picked results from the aftermarket tuners here with their dynos too.
As for those worried about destroying their rear end... What about launch control? If your rears gonna blow why would launch control come from the factory?
I just think showing 10-20hp on a dyno (330 whp - 350 whp) looks far more impressive than showing 12.8 down to 12.7 or 12.65 on a 1/4 mile.
Like you said there's driver error, but there is also mechanic error on the dyno... No system is perfect for measuring gains. But actual driving from a dead stop on pavement is how my car really spends it's time, and that is where I'm concerned about performance gains showing. Not on a dyno staying still inside of a shop.
      04-24-2009, 11:23 AM   #9
lucid
lucid's Avatar
Drives: E30 M3; Expedition
I agree with dcstep that these cars will most likely not hold up all that well to repeated 1st gear full out high torque launches. That's not what they are designed for. This is speculation on my part as I don't have evidence to back it up, but I don't see the point of risking my car just to find out.
      04-24-2009, 11:26 AM   #10
swamp2
swamp2's Avatar
Drives: E92 M3
Uhhh, dragtimes.com....
      04-24-2009, 12:00 PM   #11
dlbrooks18
dlbrooks18's Avatar
161
Drives: e90 335i
yeah, what's the fastest recorded 1/4 mi time for the E9X M3? Anyone break into the 11's yet?
      04-24-2009, 12:15 PM   #12
M3 Montreal
Drives: 2012 M3 SG ,DCT & 2011 S4
+1 on that !
I would never launch it hard for 1/4 mile runs this is a track car for me and not a 1/4 mile car.
2012 E92-M3 Space Grey on Fox Red, DCT
2011 B8 S4 S-Tronic , Black on magma red
      04-24-2009, 12:23 PM   #13
silvrevo
silvrevo's Avatar
Drives: M235v 6spd
they are in the mid 13's................
      04-24-2009, 12:30 PM   #14
STI
Romania
Drives: M3 E46 & GDB STI
J08M3 you have a PM from me check it out, maybe it can help you
I've been looking on the dragtimes site and I spotted an e9X m3 with something like 12.3 if I remember right...
      04-24-2009, 01:10 PM   #15
J08M3
J08M3's Avatar
yea, ever count how many more youtube videos there are of people totally wrecking their M3 on a road course (where it's designed for)? or even just on the street?
damage far exceeding a blown rear from a drag strip.
      04-24-2009, 01:26 PM   #16
ChitownM3
Drives: 2001 SS Camaro
I'm probably heading to the drag strip this tuesday. I'll let you guys know how it goes. I have a 6mt, AA ECU, AA pulley, Remus race exhaust and magnaflow x pipe. I will also be using a mixture of 93 and 100 octane.
      04-24-2009, 02:06 PM   #17
J08M3
J08M3's Avatar
Low 12's maybe??
      04-24-2009, 02:12 PM   #18
ChitownM3
Low 12's maybe??
Im not the best of drivers, but that's what I'm looking for.
      04-24-2009, 02:16 PM   #19
SS32
SS32's Avatar
156
Drives: 2008 M3
Mechanical failure and driver error are two completely different things.
      04-24-2009, 02:18 PM   #20
J08M3
J08M3's Avatar
Absolutely true, but both are equally bad and it seems much more expensive when the crash is on a road course or street. Also seems to happen much more by amount of videos posted.
      04-24-2009, 03:57 PM   #21
dcstep
2009 M3  [8.40]
Such as cooling the car properly and entering the data correctly. Most race shop dyno operators know how to do that and have proper cooling fans, etc.
You don't know much about drag racing do you? If you go to a serious track, there'll be traction enhancer in a concrete start box. The stress on the rear end, even with street tires, is several time the stress of autocross or lapping at a high speed track.
I used to run a 5.0 Mustang in ESP at SCCA and many of the guys also drag raced. The ESP rules limited them to stock splines and trannies. ALL that did more than a few drag runs either busted the tranny or twisted an axleshaft. This is like a Ennis, TX, which is a SERIOUS strip, with guys running 300 mph quarter miles. Still, even lesser strips will goop up the start box. It really stresses the rear end.
Like I said, if you don't believe me, take your M3 out and run three runs before and three after and tell us how it went. There's a reason the serious drag guys run 9" truck rear ends and 32-spline axles. There's not making much more hp than us and maybe double the torque.
The M3 is NOT designed to drag at pro strips. On the street you're ok, because the wheels will spin before you break anything, but the strip is another matter.
Dave
      04-25-2009, 01:05 AM   #22
ChitownM3
I don't think any modern car is MADE for the stress of a drag strip. Doesn't stop people from bringing their cars out there.
m3post
