BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wash, Wax, Detail, Cosmetic Maintenance & Repairs
European Auto Source (EAS)
      06-15-2009, 11:03 PM   #1
Singletrack
4th down; 4th quarter? Renegade.
Singletrack's Avatar
Drives: 09 SSII E92 M3; 19 FG M5C
Appropriate product for e92 m3 black trim?
Gurus,
I sincerely tried searching for this, and wonder if I'm simply searching for the wrong terms. I'm trying to figure out what would be the appropriate combination of products to detail the window trim on my e92. It appears as though there is some kind of contaminant on the gloss black trim. Not hard water spots, more like a chemical residue.
The trim appears to simply be painted to me so I was going to hit it with paint cleaner, and then a sealant. Perhaps a little glaze on there before the sealant if there are some scratches to cover up. Am I mistaken? Obviously I will do a spot test, but if you have advice, I would certainly appreciate it.
Thanks!
      06-16-2009, 11:32 AM   #2
JCtx
Drives: No BMW yet
Mine is all scratched, including the mirror surround. I also wonder if it's just plastic, or painted plastic. Not a very good finish regardless.
      06-16-2009, 11:38 AM   #3
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
I don't thinks it's painted. I believe it is just a high gloss plastic.
      06-16-2009, 12:57 PM   #4
SpecC
Completely obsessed with detailing
SpecC's Avatar
299
Drives: E90 SG 330i, white Scion tC
i like this http://www.detailersdomain.com/index...ROD&ProdID=233
      06-16-2009, 02:19 PM   #5
Singletrack
Originally Posted by SpecC View Post
Thanks for the link, but I don't think the trim on the windows is plastic. The trim on the mirrors appears to be though. I say that because there is a chip/scratch on my window trim and it appears to be silver metal underneath - perhaps aluminum?
      06-18-2009, 10:29 AM   #6
digitalmethods
Drives: 10' 328i Xdrive - 12' X3 28i
You probably smudged it with wax and the waqx contained additives in it which whiten moldings. Leaves a chalky residue. You can try and use ONYX which is a molding cleaner. If you have a habit of doing this I'd find a pure carnuba wax that doens't have additives such as P21s.
      08-06-2009, 01:17 PM   #7
Singletrack
For the benefit of others, I wanted to post and say that paint cleaner took this off without issue. As I mentioned, it was a chemical contaminant, not a residue from wax. I used some old Meguiar's Medallion I had, but it was fairly easy to get clean and I'm sure even a cheap paint cleaner would do the trick. Followed it up with some sealant to protect it from future issues.
      08-12-2009, 04:01 PM   #8
Georgeair
Drives: '08 Melbourne E92 M3
Which paint cleaner was that.....
      08-12-2009, 07:07 PM   #9
Singletrack
Meguair's Medallion - it is no longer made due to stricter VOC regulations I believe.
It really was a great product.
Meguiar's Deep Crystal System Paint Cleaner should do the trick and is very cheap at $7-8 a bottle. You should be able to find it at a regular autoparts store.
m3post
