06-25-2009, 11:36 PM | #1 |
Rep 1,419
Ez Wax Scam or Real?
I got a free can of EZWAX today, the can says it Waterless Cleaning Wax...it washes and waxes at the same time.
Here are some pictures, what do you guys think of the product? |
06-26-2009, 12:55 AM | #2 |
Rep 45
Drives: 2010 Space Gray E92
Looks like a great companion to use with a ShamWOW!!!!!
06-30-2009, 12:19 PM | #6 |
85
Rep 1,609
Are you suppose to hose off the loose dirt before doing anything to the car first? Can you imagine that you are wiping and rubing the paint with loose dirt traped inside the cloth. It just scare me to use this kind of product. Why don't you try it on your buddy's car first and tell us what you think?
7/08 135 Coupe, Crimson Red, 6 SP, Sport, Taupe Lette/Aluminum. Performance Mods: JB4 on Map 5, BMS DP Fix V3, Injen polished intake, AR Catless DP, Maddad resonated mid-pipes, aFe exhaust polished tips, ST Suspension Coil Over and Hotchkis front sway bar. Others: BMS OCC, BT Scanner, Mud Flap. Next Mods: AA Front Strut Brace.
06-30-2009, 12:47 PM | #7 |
Rep 197
Good god, that stuff sounds HORRIBLE!
You don't "emulsify" dirt... emulsification applies only to non blendable liquids. It isn't going to dissolve, lift, and separate (or whatever other BS) the dirt on your car if you're swirling a cloth all over your finish. Most of the crap on your car is probably silica based grit, like ground up road sand and blown soil. Brake dust too! If you don't rinse your car and wash it with soap and a soft sponge, you'll be grinding glass into your finish, essentially. I wouldn't trust that stuff on my car in a million years. Screw swirl marks. If I sent you free shine-o-paper to restore your clearcoat would you use it? It would just be sandpaper XD |
