07-02-2009, 05:08 PM | #1 |
Shane
41
Rep 363
Polish
I feel very comfortable with all the steps in detailing save polishing. I have a few areas that need it and I was hoping to get by with a fine polish and do it by hand. How necessary is it to machine polish? Can someone please recommend some good products? I am using Zaino sealant for the final process...not sure if that matters.
07-02-2009, 08:18 PM | #2 |
Donkey Kong King
89
Rep 1,129
Hand applied polish really won't remove defects on the paint. You need to invest in a good polisher (Flex) and some good pads. Next, I recommend Menzerna polishes, very easy to work with and provide excellent results. Follow this with your Zaino. Hit me up with a PM if you want specifics.
[SIGPIC][/SIGPIC]
07-03-2009, 01:21 PM | #3 |
125
Rep 3,515
Polishes need a lot of pressure and heat to be broken down and worked in to the surface. This can be done to a limited extent with hand applications. A buffer will provide significantly better results while polishing, which is the key to getting outstanding results while detailing.
The two most popular options for polishing right now are probably the Flex XC 3401 VRG or the Porter Cable 7424XP. Both of these buffers are paint safe and very easy to use for newer detailers. The PC 7424XP is slightly easier to use but has a little less cutting power. The Flex XC 3401 VRG is my buffer of choice because it's powerful yet comfortable to use. If you click on either link we have some package deals on the buffers includings pads, etc. that are a great value. My favorite combination is the Menzerna PO83 with an orange pad followed by the Menzerna PO106FA and a white pad. It helps remove surface imperfections and restore a bright glossy finish. Let me know if you have any other questions I'd be happy to help. Greg @ Detailed Image |
07-03-2009, 01:33 PM | #4 |
Shane
41
Rep 363
Thanks Greg! I just don't know if my paint really needs something as agressive as the SIP yet. Is there much of a difference between the IP and SIP (PO91 vs PO83)?
BTW, the car is Alpine White if that makes a difference! |
