      10-05-2009, 03:31 AM   #1
Discotheque
Discotheque's Avatar
Australia
Drives: Mazda 3 Neo
Air filter
I know this is going to sound like a silly bloody question, but how do you actually get into taking out the air filter!? Do i need special tools or the force to open the intake box?
Cheers
      06-28-2011, 05:59 AM   #2
Terrier
Yet another cool E87!
Terrier's Avatar
Singapore
Drives: Silver 118i
Cheers
Any help on this will be appreciated as im gg to work on mine this wkend.
Thks
      06-30-2011, 10:43 PM   #3
madrid90
Leader
madrid90's Avatar
Drives: BMW 328i coupe
you should take a look in the DIY section... I did mine by following the instructions in one of the posts
      07-07-2011, 12:15 AM   #4
Jeef Beef
Lord Captain Commander
Jeef Beef's Avatar
Australia
110
Drives: a sleeper
You need a Torx T20
E82 135i M-sport: SGM/6MT/Black
      07-08-2011, 09:37 AM   #5
Terrier
Terrier's Avatar
Singapore
Drives: Silver 118i
Did the air filter change successfully 2wks ago. the location of the air filter on the 118i N46B20 set up is different from those write up found.
The air scoop component will first have to be removed using torx screw. Next remove the 2 nuts holding the air box in place. Once the 2 nut is out, lift up and out the entire air box. the air box is tighten with 5 torx screws so remove the 5 screws will expose the air filter.
hope this helps thou i know having pics would be much better.
cheers
      07-08-2011, 01:11 PM   #6
blingers
blingers's Avatar
Australia
25
Drives: Pre-LCI 130i
terrier is your car a facelift? is the filter a pod or panel?
      07-26-2011, 09:27 AM   #7
Terrier
Terrier's Avatar
Singapore
Drives: Silver 118i
its a pod filter. 2009 facelifted model.
1addicts
