ZPOST
  TireRack
      01-27-2010, 08:21 PM   #1
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Who is interested in FCABs for the Ms
For those that don't know, there aren't any options for us in terms of FCABs, our bushings are unique to our car in terms of size and the fact they are offset.
The only options revolve around changing to a centered bushing which results in loss of handling and caster.
I may be able to get a solution done if there is interest. It would be a "solid" design but the increase in vibration would be minimal. The install would also be quite simple, and require only a jack/stands and a basic socket and ratchet. Price would be in the 200-300 range per set.
What is an FCAB? The FCAB is what transmits the braking force of the front wheels into the chassis. Essentially when you brake, the force of the front wheels gripping is applied into this bushings (laterally toward the center). The location of the control arm in this bushing also sets caster (laterally toward the outside = more caster) This bushing is also responsible for force distribution from the front wheels during cornering.
Stiffening this bushings results in more precise control in both braking and cornering as well as longer life.
      01-27-2010, 08:34 PM   #2
F360C
Drives: E86 S54
Interested!
07 Z4 M Coupe AW/IR
      01-28-2010, 12:24 AM   #3
RussRamz
M Slut
RussRamz's Avatar
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
Absolutely. I have a set of Treehouse racing bushings (designed for the E36), while they are great at creating a stable car under heavy braking, I have lost quite a bit of steering feedback and the car feels numb going through the corners.
You have to be 100% behind someone before you can stab them in the back.
David Brent
      01-28-2010, 12:29 AM   #4
hansaysso
hansaysso's Avatar
Drives: 07 Z4MC, 93 RX7 FD3S
really interested
      01-28-2010, 08:39 AM   #5
O-cha
O-cha's Avatar
218
Drives: Mcoupe
That's who I'm trying to get to make them. They make e46 style ones, but they are centered in distance.
How did you use e36 style housings for your M coupe? They are completely different mounting, and actually are offset properly. Or did you mean you have the ones for the e46?
      01-28-2010, 09:29 AM   #6
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
You know I'm down. Do you have a picture of the existing bushing compared to E46 M3 aftermarket ? We might be able to make something work or machine one on the lathe depending on the difference in design.
      01-28-2010, 09:38 AM   #7
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Whole new piece has to be made can't machine one down. It's actually really simple, the interest just has to be there.
      01-28-2010, 01:23 PM   #8
RussRamz
M Slut
RussRamz's Avatar
I am using the E46 style FCABs which I was told had the same offset. They fit, but totally changed the steering feel of the car. I thought about going back to stock, but with my race suspension and stoptechs, I figured I would just get used to the numb feeling (which I have to an extent). The suspension and brakes would wear out a stock set too fast and not fare well under the loads I put on my car. If you get treehouse to build them, I would be in for a set for sure! If they work well and are a limited production, I might even get two sets.
David Brent
      01-28-2010, 01:32 PM   #9
Getssum96
Drives: TBD
In for sure
      01-28-2010, 04:34 PM   #10
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Who told you they were the same offset?
      01-28-2010, 09:58 PM   #11
stubble88
Drives: 2013 e92 ZCP blue
How soon can we get them?
      01-28-2010, 10:21 PM   #12
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Hopefully soon.
      01-28-2010, 11:18 PM   #13
RussRamz
M Slut
RussRamz's Avatar
I bought them from Bimmerworld, but it was last year and I don't recall who I spoke with personally. He was certain the offset would match.
They didn't, but I put them in anyway because the car was unstable under hard braking.
David Brent
      01-28-2010, 11:57 PM   #14
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Yea, they still list them as offset, which they are 100% not. Confused me for a while too.
      01-29-2010, 04:04 AM   #15
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
Interested
      02-05-2010, 11:25 AM   #16
RussRamz
M Slut
RussRamz's Avatar
Hopefully soon.
Is it safe to say the FCABs will see production?
David Brent
      02-08-2010, 04:25 PM   #17
O-cha
O-cha's Avatar
218
Drives: Mcoupe
No, they don't really want to do it unfortunately. Going to have to find something though, stock bushing just wont cut it on track.
      05-06-2010, 02:44 PM   #18
inTgr8r
inTgr8r's Avatar
2432
Drives: M2 Comp
delete
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
zpost
