05-17-2010, 08:59 AM | #1 |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
Any brake flush tips?
Doing a complete brake flush this weekend. Got a Bavauto pressure bleeder and two cans of super blue. Any tips? Also will this flush the clutch as well or will it have to be bled seperate? I just dont want to mix fluids.
[URL=http://imageshack.us/photo/my-images/153/071jt.jpg/]
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings |
05-17-2010, 09:26 AM | #2 |
Imola Lover
26
Rep 749
http://m3.madrussian.net/diy.shtml .
You'll need to bleed the clutch separately -- Make sure you never let the fluid level in the reservoir get anywhere near the min-mark or you'll be spending the next hour getting air out of your clutch. Unless you trigger the ABS system, you're going to have some mix.
05-17-2010, 10:03 AM | #3 |
Dark Sider
129
Rep 1,779
Did you do the tap and bleed 3 times on each caliper finish as suggested? Wonder how big a deal it would be to skip that one
05-17-2010, 10:08 AM | #4 |
Imola Lover
26
Rep 749
I tap before I bleed. Whether it does anything or not, it doesn't hurt and takes, literally, three extra seconds, so why not?
05-17-2010, 10:15 AM | #5 |
Dark Sider
129
Rep 1,779
Very cool. So after putting to the reservoir you just tap each caliper than bleed til fluid changes color? Sound reasonably easy.
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings Last edited by mousitch; 05-17-2010 at 10:29 AM.. |
05-17-2010, 10:26 AM | #6 |
2431
Rep 11,667
I highly recommend getting flare nut wrenches for loosening the bleeder valve at the caliper.
They will prevent a potential major headache of using an open spanner. Also; A quick method for doing the clutch fluid. - Remove the old fluid with the turkey baster. - refill with new. - pump clutch 20x (approx) & repeat. Then do it again in a couple of weeks. Not a pure drain & flush method but it gets most of it & it's easy.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
05-18-2010, 09:20 AM | #7 | |
Rep 632
Flare nut wrench is a good thing to have, but box end wrenches will work also since there is no line coming off the bleeder screw. Just another thought. As to getting the ABS pump flushed, I had seen on the M3forums that if you have the ignition in the on position (engine not running) and depress the brake pedal while doing the bleeding, it will activate and cycle the ABS pump. You'd have to think about how to do this with your pressure bleeder too - maybe start at each corner by manual bleeding using the brake pedal and a buddy, and then switch to the pump for the rest of the bleed, I don't know. I can tell you I bled the brakes in my M3 the manual way with my wife pressing the brake pedal and it went smoothly, and didn't take too long either. One definite, definite word of caution with the bleeders - if that thing comes loose from the master cylinder and gets brake fluid on any painted surface, you will have major paint damage - the stuff is real bad for paint. I have seen a couple of bleeders burst off from the master and it's a mess to say the least. I guess I'd use it if I were sure it was secure, but I didn't have one and doing it the manual way nearly guarantees minimal risk of brake fluid getting on any painted surface (just wrap towels around the master to catch drips from filling. |
05-18-2010, 11:59 AM | #8 | ||
Rep 606
1) Turkey baste the old fluid out of the MC.Perhaps do this at the driver's side front so whatever comes out of the ABS pump has a short distance to travel? This step, I would think, should flush out whatever is discharged from the ABS pump. I actually do both a pressurized and manual bleed/flush. I use a Motive Bleeder and open the valves at each corner to pull new fluid through the system. Then I do the manual pump routine with a friend pumping 10-15 times and holding on the last pump while I open the valve. I do this for all corners. Quote:
|www.onehotlap.com|Real People|Real Cars|
05-18-2010, 12:44 PM | #9 |
Dark Sider
129
Rep 1,779
Thanks for the tips!. So after the intial bleed with the pressure bleeder just turn on ignition and pump 15-20. Then hold down and open driver side front valve. Correct? How long should i let the valve drain for the ABS?
05-18-2010, 12:50 PM | #10 |
2431
Rep 11,667
^ I would confirm with a tech re the ABS.
I know for certain, on other brands they tell you specifically to NOT cycle the ABS. It can lead to air entrapment which is a PITA to resolve.
05-18-2010, 12:54 PM | #11 |
Dark Sider
129
Rep 1,779
Might just stick with a normal flush. Cant see the ABS holding a large amount of fluid anyway. Suppose it wont harm anything to mix Super Blue with OEM?
05-18-2010, 01:38 PM | #12 | |
Rep 606
My routine has always been to simply light up the ABS system with one hard stop after bleed/flush. I find that this always firms up the peddle quite a bit. Non-issue. Technically speaking *may* lower the boiling points but it'd be a negligible difference.
08-03-2011, 06:06 PM | #13 | |
Rep 662
Is this weblink a reliable source in relation to brake & clutch bleeding????
Current: Z4MCoupe, Interlagos Blue, Carbon Extended Leather, Sat Nav, Heated Seats, Supersprint Exhaust, BBS CH19's, Stubby Aerial. AND E82 1M, Alpine White
Sold: 3 x 130i (White, Red & Black), Mk4 VW Golf R32, '03 Reno Clio Sport |
08-04-2011, 05:54 AM | #14 |
27
Rep 341
To be safe, you can use the pressure bleeder without putting fluid into it--fill the master cylinder with fluid, attach the dry bleeder and pressurize. Less convenient, but this minimizes the risk of a leak or blow-off getting fluid on the paint. (My Motive leaks at some of the hose joints when I put 20 pounds on pressure on it...less than that doesn't move fluid at a decent pace.). Just mask sure you stay on top of the fluid level so you don't pump air into the lines.
09-27-2012, 01:12 AM | #15 |
Rep 76
I have used a pressure bleeder for years on a variety of race cars. All you really need is 3-5 lbs of pressure and a little patience. In fact, the most thorough way to bleed is the drip method. Admittedly messy, it definitely works and works well on multiple piston calipers with crossover lines. My experience only....
11-26-2015, 10:27 AM | #17 |
Rep 758
It's on the rear of the slave cylinder on the left hand side of the transmission. Here's some photos of the slave cylinder that show the bleeder.
https://www.ecstuning.com/BMW-E46-33..._All/ES241919/
Top Down 365
11-26-2015, 10:46 AM | #18 | |
Rep 143
Do I bleed it like the brakes? Open valve, compress pedal, close valve, release pedal. Repeat ? Last edited by Bossdog; 11-26-2015 at 10:55 AM.. |
11-26-2015, 10:50 AM | #19 |
Rep 143
I just acquired my Z4M this summer, 2006 with 38K miles. I am assuming the brakes have not been serviced so I intend to flush the brake lines fully. I am considering pulling out the 10-year old brake lines and putting in the SS. Is that a waste if time & money? I will not be tracking this car, only Autocross events. (they are $20 off at Turner this weekend)
Thanks for your input. |
11-26-2015, 02:03 PM | #20 | |
Rep 758
I wouldn't say the SS lines are a waste of money, but 10 years isn't really old for brake lines. My 3.0si is also an '06 and I've had the calipers off and on a number of times and checked the condition of the outer surface of the brake lines and it's not showing any signs of oxidation or any other degradation. Unless the system has had a lot of moisture in it, the outside of the brake hoses usually gives you some idea of what the general condition of the hose is.
Top Down 365
03-19-2016, 09:11 AM | #21 |
191
Rep 453
Drives: 2007 Z4M Coupe
I know this is an old thread but I'm a newbie so I decided to resurrect it. Anyone ever use this vacuum type bleeder from Harbor Freight?
http://m.harborfreight.com/brake-flu...not%20provided Although you need a compressor to use it, seems like an effective way to flush and you can use it to remove old fluid from the master reservoir as well. Half the price of the motive pressure bleeder which is appealing to me given the very few times I'll be using it. |
03-19-2016, 11:37 AM | #22 |
Rep 233
Sorry can't help with the question but I will add a tip. Soak the bleeder screw with penetrating oil prior to trying to loosen it. It will save you a major headache of the bleeder screw breaking off.
