ZPOST
  TireRack
      07-14-2010, 05:05 AM   #1
jsoltan
jsoltan's Avatar
Drives: 2007 BMW Z4 M Coupe, 13 328i
Z4M Brake Rotors- Where to Buy?
What is the best place to source front/rear Discs for 2007 MCoupe? BMW parts are around 250.00 a side from most BMW dealers. Need CSL.
      07-14-2010, 06:32 AM   #2
inTgr8r
inTgr8r's Avatar
2432
Drives: M2 Comp
You can get them for $205 from Tischer.
Racing Brake also makes a front rotor, but they are more expensive than that.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
      07-14-2010, 09:51 AM   #3
jragan
Imola Lover
jragan's Avatar
Drives: 2007 Imola Red M Coupe
The nice thing about the Racing Brake setup is that it's a true two-piece design so next time you don't have to replace the whole rotor, just the actual disc which I believe is cheaper than the OEM disc+hat combo.
His: RIP-"Ruby" E86 ///M Coupe: Pics Track Pics Short Vids Long Vids
Hers: 997-1 C4S: Pics
      07-14-2010, 11:30 AM   #4
jmillet
jmillet's Avatar
64
Drives: 2023 Hyundai IONIQ 6 SEL AWD
If you are still covered by the 4 year/50,000 mile BMW Maintenance Program and your rotors are worn below minimum thickness (26.4mm front and 18.4mm rear) why not get them replaced by the dealer?
E86 Z4 M Coupe Specs.pdf
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      07-17-2010, 07:18 AM   #5
AWM3
BMW Fan
AWM3's Avatar
11
Drives: 2012 E92 M3, Alpine White
With normal street use and factory pads those rotors should easily be good for more than 50K miles. If you've gone through them sooner than that, it's probably from track use, so they're just an expendable supply like anything else on a track car - gas, oil, tires, brake pads, hotel rooms etc etc.
      07-17-2010, 08:43 PM   #6
jsoltan
jsoltan's Avatar
Need to be replaced. Car has 78K and way past warranty. Yes there is track use. Why not? That is what the car was built for!
      07-19-2010, 08:28 AM   #7
AWM3
BMW Fan
AWM3's Avatar
11
Much respect from me for racking up that many miles on your Z4M. I would like to know if you have experienced any significant mechanical problems during that time or learned anything about how the car holds up with higher mileage that might be helpful to others later on.
      07-20-2010, 07:31 AM   #8
jsoltan
jsoltan's Avatar
I have to say that other that Inspection #1 and #2 and oil changes at 5K intervals the car has been trouble free. I have changed the pads all around once at 50K and other that a one time electrical gremlin that required a flat bed I have experienced very little issues. It seems that those who track their cars are more apt to take care of minor issues before they become major ones. The car has been great. Bought it when BMW was giving 7500 in truck $$$. Bought for 9K under dealer invoice. So I don't have an issue with mostly highway miles.
      07-26-2010, 06:46 PM   #9
jsoltan
jsoltan's Avatar
Still need help as to where to buy!!!
      07-26-2010, 07:05 PM   #10
inTgr8r
inTgr8r's Avatar
2432
Drives: M2 Comp
what more do you need?
There have been several suggestions, I bought mine at Tischer.
      07-26-2010, 07:59 PM   #11
lucid
lucid's Avatar
Drives: E30 M3; Expedition
Yes, if you want the OEM rotors, get them from Tischer.
Also, do the E46 M3 PF rotors fit our cars?
http://www.hmsmotorsport.com/store/b...3-direct-drive
      07-27-2010, 05:46 AM   #12
jsoltan
jsoltan's Avatar
Thank you Herr General.
      08-03-2010, 03:53 PM   #13
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
i have to agree tischer is the safe way to go.
      08-03-2010, 05:13 PM   #14
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
65
Drives: 2006 Z4MC Interlagos
The OEM rotors are produced by Zimmermann - you can get them through import specialists such as Altom and Beck/Arnley. You may save a couple of bucks, however; I would go with Tischer as suggested.
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM
zpost
