07-19-2010, 09:47 AM | #2 |
Ninja
390
Rep 4,014
might be a bad battery...my e60 was 2 yrs old, had that warning happen frequently over a 2 month span..then I finally had a high battery discharge warning...took my car in for service...took a few days to diagnose, but they finally changed the battery...no issue..
what the main concern should be s what's causing your battery to drain if it is that..could be a module not shutting down and not allowing your BMW to fully go into sleep mode....
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i |
07-19-2010, 12:40 PM | #3 | |
90
Rep 1,882
having to reset the clock continuously is a sign of a battery/power problem. |
07-20-2010, 09:13 PM | #4 | |
Rep 683
Check battery
Do an advance search for info & make sure service tech. check the factory installed battery (part number) being correct b 4 doing anything else. See Car & Driver longterm test on their x6 5.0i Good luck. It may have come fr. the factory but ..... service will say u r not driving it enuf if it's not ur daily driver. Last edited by archwerks; 07-20-2010 at 09:24 PM.. |
