      12-13-2010, 07:06 PM   #1
MrRoboto
1846
Drives: VO 1M
Tuning Potential?
Just reading that Proceed is fully compatible with the 335is but there is no gain over the standard 335i.
Is the 1M and the 335is powerplant the same?
      12-13-2010, 07:34 PM   #2
MDORPHN
Drives: AW 1M
Based on everything I have read and heard, the powerplant is identical. It is possible, but unlikely, that there are slight differences in the ecu programming.
Neil
      12-13-2010, 07:46 PM   #3
Jblack4083
Drives: E46 ///M3 JB/CB
Neil
Those differences in the ECU tuning could possibly make it less tuneable?
      12-13-2010, 07:50 PM   #4
Moo
Gold Member
Moo's Avatar
161
Drives: PSYWGN
As hinted the turbos might be a slight bit different, so that might require some tweaking.
I also get the sense that BMW is going to have more anti-tuning measures with the 1M/N54.
I'd be (pleasantly) shocked if you can just pnp a JB.
      12-13-2010, 07:54 PM   #5
ErvGotti
124
Drives: 2008 135i 6MT
2008 135i  [6.00]
Anythings tunable with time and since it's an N54 it'll probably just need a special map with the procede or new JB4.
      12-13-2010, 08:02 PM   #6
MDORPHN
Drives: AW 1M
Perhaps not even that if, as I suspect, the tune is identical to the Z4.
Neil
      12-13-2010, 08:05 PM   #7
Mindgame
Poke Her Face
Mindgame's Avatar
27
Drives: 09 135I
I'm have no official sources but I can only assume the extra power coming out of the "is" model and 1M model is an increase in boost, tuning if you will.
So if you run the same PnP setup with the same amount of boost (135 @ 14psi, 1M at 14psi) you will have the same HP between the two.
Of course, this is speculation.
      12-14-2010, 03:32 AM   #8
spiderz17
Not a BMW Insider
spiderz17's Avatar
Drives: X5 M50i
1M and 335is versions of the N54 are not the same. 1M appears to share the same engine as the Z4 35is. The version in the 335is is slightly lower on HP (320 vs 332).
      12-14-2010, 10:56 AM   #9
TunedM2C
TunedM2C's Avatar
829
Drives: 2016 LBB M2
^ Cool. I never knew the Z435is had a M engine....
      12-14-2010, 11:18 AM   #10
///M1
///M1's Avatar
Drives: Many
Nice one!
2011 BMW E82 1///M: AW, all options; Renntech, Akrapovic, Forge, P3, RevoZ CF bits, many mods
1988 BMW E30 M3: Hennarot, S14, stock
2018 Porsche 991.2 GT3: PtS, CXX, LWBS, PCCB
1998 Porsche 993 C4S: Zenith Blue, last aircooled widebody, Bilstein PSS10, Fister II + Fabspeed exhaust
2008 Audi B7 RS 4: Sprint Blue, Audi Exclusive Euro Bucket Interior, Premium+Titanium, many mods
      12-14-2010, 11:23 AM   #11
MDORPHN
Drives: AW 1M
It doesn't ... until you add "Powered by BMW M" to the valve cover.
Neil
      12-14-2010, 11:16 PM   #12
aus135i
aus135i's Avatar
Australia
27
Drives: F80 M3
Neil
GONE: E82,E83,K46,1199s,RS250,F20,F25,F82,Cayenne,G83
NOW: G07, G20, K66
1addicts
