04-08-2011, 07:34 PM | #1 |
Rep 150
Are my tires ok for another HPDE?
Here's my front right tire after my 3rd HPDE last October (the left one is similar but not as bad):
I have driven about 22000 km or 13750 miles on these and have about 6mm depth front and 5mm depth rear. Am i okay for another HPDE? Will this pass tech? |
04-08-2011, 08:31 PM | #2 |
2042
Rep 25,989
That will be fine for another track day but it doesn't seem like those tires can handle the heat produced by autox or tracking, because the compound is disintegrating.
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
04-09-2011, 09:38 AM | #6 |
2148
Rep 10,176
04-09-2011, 12:07 PM | #8 |
2148
Rep 10,176
I serve as the "final guy" on tech decisions at my events (event chair). I would pass you, no problem. As long as the tearing does not go into the surface of the tires, and remained on the treads, you should be fine.
04-09-2011, 12:37 PM | #9 | |
Rep 150
both my front tires has wear on the outside half of the tire from the lack of camber. am i helping/doing the right thing by bumping up the tire pressure? last event i ran 42 psi cold and got up to 48 psi hot. would lower tire pressure ease the wear and hopefully avoid chunking? i do have a set of brand new Potenza RE-01R sitting in garage but i am hoping not to use them until these wear out |
04-13-2011, 06:09 AM | #10 |
Rep 543
If you are talking about 20-30 minute sessions at HPDEs vs. short autocross runs, the tire pressure is way too high and the heat you are generating is likely causing the chunking. I would try and target closer to 39-41psi hot. You are going to get a little more roll onto the upper part of the sidewall, but that is primarily a camber issue.
04-13-2011, 07:06 AM | #11 |
European Editor
10589
Rep 22,992
Why not take your tires to a local shop that can "shave them" down for racing. I bet TireRack's website could point you in the right direction. That is what I would do.
You have some serious "heat chunking" going on there. |
04-13-2011, 08:45 AM | #12 |
Rep 475
Doesn't appear that there is much thread left on that tire. And I am not too sure that this type of tire would gain the same benefit as an R comp tire would from shaving. Added cost of shaving this type of tire might be spend elsewhere on some other more beneficial things.
04-13-2011, 12:32 PM | #13 | |
Rep 150
The reason why I went for 42 psi cold is the amount of roll and wear i get on the sidewalls of the tire. I don't feel confidence in cornering on the sidewalls of my tires. Camber plate is $500, install is $270 and alignment after is $110. A little steep for me considering I still need to pay $661 more in income taxes. |
04-13-2011, 12:34 PM | #14 | |
Rep 150
04-13-2011, 04:21 PM | #15 |
winter mode
62
Rep 2,057
Drives: 08 135i, 88 M3
yeah you'll be fine. just pay a little extra attention to how they look AND feel. could be easier for more chunks to come off now that the process has started
88 M3: BMWCCA J Sport
08 135: because streetcar |
