04-26-2011, 02:49 AM | #1 |
Rep 4,033
ESS VT625 Mfest Drag Strip results...
Well I'd only had the car less than a week, did some vbox pulls the 2nd day with the VT575 setup, and managed a great time for only 6psi of boost. A few days later was the drive down to Mfest, I was caravaning down with a group of good friends, still running the VT575 pulley. A Modded GT-R, 2012 GTR, C6 Z06, and others. I can't say we didn't have a few spirited runs along the way, let's just say Dean's Modded GT-R and I are very close, the vid is out there on youtube as well. On the drag strip well, that was a far different outcome, lol.
When I got to the track, Roman@ESS and Alex (from Alexshop) installed the 7.5psi pulley, but we keep the VT575 91 file, it's a very safe file and has nice fat AFR's up top and the timing is not aggressive. I wanted to keep it safe. Vegas does not have a very fast track, but knowing all the cars that would be there, collectively everyone would probably run subpar times, and it would be fun to give it a go anyway, especially when a lot of good friends are there as well running their cars. I hadn't tried the DR's yet, MT 305/35/18's I picked up from Mikewads, and in the past the DCT gave me problems when trying to heat the tires up with a supercharger. It was difficult to warm them up without the DCT tranny over heating, and even if I didn't heat them up and launched, if the tires spun, at times the DCT would throw the car in limp mode, to keep it from overheating. At first the track was not spraying any water down for burnouts, so I had no luck getting the tires to spin while holding the brake. I found two issues, the first was these MT Drag Radials were too much tire, the car had trouble heating them up, even after they finally put down some water! If you can't heat DR's up they are almost like running street tires, possibly worse, they need to get really hot. I tried a few times managed a little burnout etc. but just too much tire really. However when I launched the car it would still spin the tires, sometimes even through the 2nd to 3rd shift, so I gave up trying to heat the tires and decided to just baby it out of the hole and then punch it, even then the car would lose traction. One thing I discovered in all of this and in the past had been vocally skeptical about, is ESS' claim that their DCT software actually helps prevent the tranny from overheating. I simply did not believe it was possible, BUT I was wrong, my tranny even after trying burnouts on many runs, and doing 17 back to back 1/4 mile passes, never gave me an issue, not one. This is huge in my book, I don't believe you need an upgraded cooler, etc. to keep it from overheating for Drag racing. I believe now I will run a smaller DR, one that I can really heat up, and I can finally launch this car without it overheating, and possibly get some really good times at a track with decent air. That alone made me really happy. The car managed a best time of 11.88 @ 125MPH, with a DA ranging between 3700-4000' through the night, and after looking at all of the results from the other cars (vid below), I was very pleased with the #'s and how the car performed and held up, especially knowing my est 60' time, do to bad traction, and not being able to heat up the DR's properly, was a lackluster 2.1, if I had simply did a 1.8 60', the car would have went 11.2, so 10's in this car are doable with a good launch and a decent track, and this is boost only, 7.5 psi. Here is a summary of all my runs, and a comparison graph with actual vs. the Vbox. FWIW the Vegas track did show a .75-1% uphill slope, here are a few graphs that show the slope and the wheel spin that took place. Here are some other times to compare with from that night, very subpar for what they normally do in decent air - Stock E9X M3's, 13-15s @ 102-105MPH NA E46 M3's, 14-15's @ 98MPH E60 M5 13's @ 108-110MPH C6 Z06 12's @ 117-118MPH Stock E55 13-14's @ 103MPH Modded E55 - 12's @ 113MPH 2012 GTR 530HP LC, 11.4 @ 117-118MPH HPF E46 M3 Turbo STage 2 Pump + Meth, 13's @ 122-123MPH HPF E46 M3 Turbo Stage 2.5 Pump + Meth ,12's @ 127-128MPH HPF E46 M3 Turbo Stage 2.5 Race + Meth, 12's @ 132mph HPF Stage 2.75 Pump + Meth, 12's @ 129MPH HPF Stage 2.75 Race fuel + Meth (800whp) 11.64 @ 136MPH HPF Stage 4 Race Fuel + Meth (750whp) 11.00 @ 131MPH 996TT, K16's, ECU Flash, 13's @ 111mph Here is a vid of most of my runs, some are just flat out terrible, but of course it's rare that every pass a good one. Never had a run where all the way through there was no wheel spin. Even with MT DR's at 20psi! Big Thanks to Robert (PG) for putting all this together and letting me use his Vbox to record from inside the car, thank you Robert! Here is another video that Robert put together with many of the other cars running, it's part one, part two and possibly three, will come later.
16 F82 M4 DCT - ZCP - JB4 - 556WHP / 570WTQ
08 E92 M3 DCT - Bolt Ons - 60-130MPH 10.71s - 11.88 @ 118MPH - 377WHP ESS VT2-625 SC 60-130MPH 6.80s - 11.30 @ 129.3 MPH 586WHP / 379WTQ ESS VT3-750 - 60-130MPH 6.14s - 10.81 @ 135.13 MPH 690WHP/463WTQ Shift-S3ctor E92 M3 - 1/2 Mile Trap Speed WR - 174.13 MPH Last edited by DLSJ5; 04-26-2011 at 02:48 PM.. |
04-26-2011, 03:18 AM | #2 |
CLU KINGSMEN
29
Rep 566
nice, informative & complete write up. Thx for sharing. ESS handles business.
E92 M3 Satin Black GTS ModeCarbon Rimier MotorSports Premier Protective Films
HRE || RECARO || KW |
04-26-2011, 03:55 AM | #3 |
Track Duty
266
Rep 2,467
Nice write up and comparisons. Mu car was at the track that night as well. Your car sounds amazing!
My car did a best if 13.5@107 mph with a sh!tty 2.3xx 60' times. I was disappointed in the results but now seeing what other cars did I don't feel too bad. |
04-26-2011, 05:20 AM | #4 |
Rep 508
you did great job! wow really fast! I didn't know that you had 7.5psi pulley. My best time was 12.2
E92 M3 DCT/ESS VT-575/FABSPEED hfc's/AE exhaust/BBS LM 19'/ KW CS/RD sways/STOPTECH TK/ RECARO PP /BMW PSW/WIECHERS SPORT roll cage/CF parts that covers the back seat/VRS hood/bumper/csl trunk/diffuser type 2/CF:mirror cap/side & front grills
04-26-2011, 06:34 AM | #5 |
1122
Rep 7,690
Great write up Drew and nice results for being on an elevation of 3700ft-4000ft.
Cant wait to see more results once you get the right DRs on. Keep it up !! |
04-26-2011, 06:50 AM | #6 |
Rep 944
Damn This car does not get tired
http://www.youtube.com/user/Ferre86
| e93 M-DCT ESS VT2-625 | Akra Slip-on | Challenge Race Catless x-pipe | Challenge front lip | Challenge Diffuser | Carbon front grilles | defi gauges control unit | Macht Schnell gauge panel | E93 M3 trunk Spoiler | IND Carbon Fiber Side Markers | |
04-26-2011, 11:17 AM | #9 |
Custom User Title
9
Rep 105
Impressive display of durability Drew. Only 5 minutes of cooldown before your fastest pass of the night? Crazy -- and that doesn't even count driving back down the return and the burnout!
04-26-2011, 12:13 PM | #10 |
115
Rep 2,682
I'm telling you I wouldn't be surprised If you trapped 135mph at sea level ... When I spoke to Robert I told him the same thing... I wasn't impressed by the 125mph trap but when I was informed on the altitude and confirmed what other cars trapped and after talking with a couple of buddies that drag like it's going out of style they said the same thing , expect a 130+ mph trap.
These cars self adapt to weather !!! They do 2million calculations per sec ..... Or something crazy like that . A BMW tech buddy who is top 5 master techs in the east coast confirmed this. To have your car perform and run the way ESS has it working is a fukcing miracle !! You will never ever see an other company achieve what they have with this plat form PERIOD . AA 520whp with Meth and 8lbs & 2 BOV & 1 Bypass very efficient ... R u kidding me...... I put down 535 with stock cats and 6 psi & 1 unefficient Bypass Valve ,Thats why support Roman & AJ"" honesty and quality"" !! To Drew now we all now you will have your M for a very long time and will continue to see Awesome results from you thanks to ESS FYI: Me Izzy & a bunch of buddy's are renting out English town NJ track for the day sea leveled track .... Now here is the key playing factor to all the above mentioned Facts =People who love their M's deserve to enjoy their cars day in day out with out any headaches ... Last edited by m33; 04-26-2011 at 01:39 PM.. |
04-26-2011, 01:56 PM | #11 | ||||||||
Rep 4,033
Thanks man, as always! Quote:
08 E92 M3 DCT - Bolt Ons - 60-130MPH 10.71s - 11.88 @ 118MPH - 377WHP ESS VT2-625 SC 60-130MPH 6.80s - 11.30 @ 129.3 MPH 586WHP / 379WTQ ESS VT3-750 - 60-130MPH 6.14s - 10.81 @ 135.13 MPH 690WHP/463WTQ Shift-S3ctor E92 M3 - 1/2 Mile Trap Speed WR - 174.13 MPH |
04-27-2011, 03:21 AM | #13 |
Bulldog
482
Rep 3,355
Awesome write up Drew! It was great to see you at MFest and even more impressive is how you hammered your car with ZERO issues! I know that you will only improve with each and every race!
Looking forward to meeting up with you again soon!
Prev: Individual F80 M3 - Fjord Blue/Silverstone(interior) | Fashion Grey(exterior)
GTS |
04-27-2011, 02:16 PM | #14 |
Rep 4,033
Thanks J!
Always good to see you Brotha, car did great. Let's meet up at CNC again.
04-27-2011, 02:25 PM | #15 |
Rep 4,033
FWIW I went out and did a 1/4 mile VBox pull on the stock RE11 tires, I had major problems hooking up and had to lift in order to get traction, so no doubt it has an awesome ET in it if I could get a solid launch, that wasn't the main factor here, I wanted to see a trap speed at sea level. With not being able to stay in throttle the entire time, this 102 1/8th mile trap and 130 1/4 mile trap is damn good.
Below is a screenshot of the run. I have Robert taking a look at the file, the graph will show the wheelspin and throttle lift. He will analyze the graph and calculate the trap speed as a 1/4 mile track would measure it, meaning the average speed 66' before the finish line. This was with the VT625 pulley 7.5psi, VT575 91 octane only file, 91/100 mix approx 95 octane, Water Meth enabled, street tires, 55 degrees. Here is the graph that was analyzed by Robert, it gives us an approx. idea of what the actual #'s would have been at an NHRA track. You can see in the graph where the traction issues took place and I had to lift off the throttle.
08 E92 M3 DCT - Bolt Ons - 60-130MPH 10.71s - 11.88 @ 118MPH - 377WHP ESS VT2-625 SC 60-130MPH 6.80s - 11.30 @ 129.3 MPH 586WHP / 379WTQ ESS VT3-750 - 60-130MPH 6.14s - 10.81 @ 135.13 MPH 690WHP/463WTQ Shift-S3ctor E92 M3 - 1/2 Mile Trap Speed WR - 174.13 MPH Last edited by DLSJ5; 04-27-2011 at 05:27 PM.. |
04-27-2011, 04:20 PM | #16 |
Scared money don't make money.
67
Rep 1,448
Drives: 2009 E92 M3 DCT
That's a legit trap speed bro .
2009 E92 M3/DCT/Alpine White/Fox Red/Carbon Leather OE Tuned 402 whp & 303 wtq/Gintani X-pipe/MXP Axle Back/Rogue Pulley/AFE Stage 2/Cosmetics By IND & EAS HUGE THANKS: Gintani, OE Tuning, and EAS |
04-27-2011, 04:37 PM | #18 |
All I do is Win... Eat Race Sleep
153
Rep 2,184
Drives: 2018 Range 2011 M3 2019 600lt
nice numbers congrats on 130.
Rs7 : 10.4 133.50 with a 1.7 60ft Toyo R888 F10 M5: 11.308 131.96 with a 1.9 60ft Street Tires E90 M3: 11.2 126.7 with a 1.8 60ft Street Tires |
04-27-2011, 05:25 PM | #20 | |
Rep 4,033
I updated my last post with the actual Vbox graph, showing the wheel spin in 1st and 2nd gear, as well as what the approx. time would be at an NHRA track.
04-27-2011, 05:31 PM | #21 |
BimmerPost Supporting Vendor
9596
Rep 10,884
Great trap speed. Car is making some serious power
04-27-2011, 05:46 PM | #22 | |
Custom User Title
9
Rep 105
(fictitious 60-130 times) baseline with meth: 7.4s 1st run w/o meth: 7.6 2nd run w/o meth: 7.7 3rd run w/o meth: 7.8 4th run w/o meth: 7.8 5th run w/o meth: 7.9 Or does it pretty instantly drop to a base level like: baseline with meth: 7.4s 1st run w/o meth: 7.7 2nd run w/o meth: 7.9 3rd run w/o meth: 7.9 |
