05-03-2011, 02:32 PM | #1 |
Rep 62
Track Settings E87
Hi, please can you help?
I'm based in the UK and race an E87 130i that has M3 arms, Ohlins/KW (mid set) dampers with a solid mounted rear sub-fame and solid engine mounts. I have to run road tyres in the series I compete in so Yokohama AD08's (235/40x18 & 265/35X18) on 9J 35et rims. Spring rates are 475lbs front/rear and I run a Drexler LSD. Camber is 2.5 all round, 4mm toe in rear, 2mm toe out front. With this set up and 300bhp 260lbs/ft, I struggle getting the power down without oversteer What suggestions do you have on this set up to help the oversteer? Thanks |
05-03-2011, 02:53 PM | #2 |
Rep 2,234
I would suggest setting the rear dampers to a softer setting and increasing rear tire pressure. additionally you could reduce your front camber or increase rear camber. you could also reduce front toe-out as well as more negative caster. all these would help with reducing over steer.
furthermore you can try modulating the throttle a little better coming out of turns. 135 has more torque and it all comes at a very low rpm so I need to be careful with throttle inputs otherwise I will be facing the oncoming traffic
"I would quote everything pixelblue said, but you've already read it. Take it from someone who's put the 1 through its paces"
05-03-2011, 03:03 PM | #3 | |
Rep 62
05-03-2011, 03:12 PM | #4 |
Rep 2,234
Running BFG R1
05-05-2011, 02:13 AM | #6 |
I'm Riley, I'm awesome
30
Rep 696
05-05-2011, 02:24 AM | #7 |
Rep 62
05-05-2011, 09:47 AM | #12 |
Rep 231
How can u get a 255hp 330i engine into 300hp?
pls shed some light..,more info on mods thx,
AC Style Strut Brace/ Koni FSD/ Eibach Pro/ BMW Performance Brake/ BMS PBX/ K&N Cone filter/ Retro-fit paddle shift/ Black shadowline/ Matt Blk Grill/ MTEC Angel eyes
05-05-2011, 09:53 AM | #13 | |
Rep 62
To get the power we first removed all the standard wiring looms, ECU's, fused boxes etc and fitted a custom loom with Motec M800 ECU and Motec PDM 30. ARP con rod bolts, E36 throttle bodies on custom inlet manifold, race headers as used by BMW South Africa and a lightened flywheel. This gave 299bhp at 7200rpm. |
ornicar136.00 |
05-05-2011, 05:46 PM | #14 |
European Editor
10589
Rep 22,992
I heard a tune on a 130i will get you 280 PS and 325Nm with an otherwise stock motor. this is done solely with software.
Quote: Originally Posted by kbird No transplant! This is the standard 130i engine Sorry, I saw the vave cover and it reminded me of an older engine. Now that I look closer to your engine photo - I can see the N52 waffling of the engine block. |
03-26-2014, 05:32 AM | #16 |
Rep 1,491
Can you make a race cam for us? If so how much? Interested!
Black Wrapped Roof, BFG Rivals, Dinan Camber plates, M3 Steering wheel, Matte Black kidney Grills, H&R Sport springs,
Sparco assetto gara,Pagid sport Brakepads,STOPTECH Slotted Rotors, DISA STG3,EURO BOX |
04-12-2014, 05:05 AM | #18 |
Rep 741
Drives: E87 130i
Cool build. How does the 18x9+35 fit? light lipping of the guards required?
