03-25-2007, 03:35 AM | #2 |
Euro.Techniks-EAST
293
Rep 1,467
03-25-2007, 04:25 AM | #3 |
1312
Rep 10,185
He's talking about the rear differential, not the body kit
BMW if you are reading, I need a job, Please. |
03-25-2007, 05:26 PM | #5 |
Rep 65
E 92 wheels and rims
The owner of one our more reputable after market shops indicated there was information available for the E92 wheel and rim specifications? I would like to buy some new rims for my E46 M3 that I could later transfer to the E92.
Has anyone any info on the E92 wheel and rim specifications yet? Cheers, K. |
03-26-2007, 05:00 AM | #6 | |
Moderator / European Editor
1512
Rep 6,754
Best regards, south |
03-26-2007, 10:11 PM | #7 | |
Rep 65
Good info on rims
This is helpful, so I put in an order for some 19" rims that should be portable. K. |
03-01-2008, 12:13 PM | #8 |
Rep 2,560
Drives: Rapidly from A to B
Here is a pic.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
03-01-2008, 01:28 PM | #9 | |
Commander-In-Chief
2122
Rep 8,924
Drives: 2023 M2 Coupe, 2020 GLE 450
Final drive In principle, the final drive is assembled in the same way as in the E6x M5/M6. It is, however, a separate new development. The bevel gear shaft bearing is a frictionoptimized, double-row, angular-contact ball bearing. The gear ratio between the bevel gear and the crown gear has been adapted to the engine speed and gearbox ratio of the M3. The final drive ratio is 3.85:1. The 215 gear set (crown wheel diameter 215 mm) has been temperature and noise optimized. A friction-reduced gearing is used. The housing of the final drive has been adapted to accommodate the double-row angular-contact ball bearing. The flanges for the propeller and drive shafts are the same as those used on the E6x M5 and M6. The transmission housing end cover has been modified to ensure optimum gear oil cooling and bevel gear lubrication. The end cover has more ribs, which improves heat exchange. The internal styling of the end cover is adapted according to the size of the differential and the final drive ratio. This Mfinal drive also has three bearings, with two front bearing and one rear bearing. Fully variable M differential with locking action This unique limited slip differential design is based on the E46 M3 and the E6x M5/M6 limited slip differential, where it is described in detail. The function of the limited slip differential has been adapted to ensure that the M3 develops the best traction at different engine speeds and in every road situation
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 Last edited by GregW / Oregon; 03-01-2008 at 06:35 PM.. |
03-01-2008, 06:19 PM | #10 |
#thatsanicemovebro
202
Rep 3,920
Drives: E92 M3 LSB/Black 6MT
most important thing...100% wheel locking
