XBimmers.com | BMW X6 Forum X5 Forum
TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > General BMW X6 and X6M Forum
      08-02-2011, 06:49 PM   #1
mohd606
Drives: BMW X6 M
looking for Angel Eyes?
i have 2011 BMW X6M
and i looking for Angel Eyes like the new x5 or 5 series
      08-02-2011, 08:28 PM   #2
zerrantoss
25
Drives: 2011 X6
LUX
      08-03-2011, 11:14 AM   #3
LuxAngelEyes
LuxAngelEyes's Avatar
Drives: BMW
Originally Posted by zerrantoss View Post
LUX
+1 - we offer the LUX H8 V3 angel eyes and they fit on the X6's
      08-03-2011, 12:13 PM   #4
dmlgc
dmlgc's Avatar
Drives: 2022 BMW X6MC - 335D
+1
I bought the LUX H8 V3 from these folks and they are better than any other solution I have tried.
Update: As someone gently reminded me ... I will post pics tonight when I get home.
      08-03-2011, 09:13 PM   #5
dmlgc
dmlgc's Avatar
LUX Pictures
The pictures are outside ( except for one in garage) drivers side has sun shining on it so gives you a good idea of what they look like during the day.
      08-04-2011, 11:46 AM   #6
LuxAngelEyes
Drives: BMW
Thanks for sharing the pictures!!!!!
      08-04-2011, 02:11 PM   #7
AndreyATC
AndreyATC's Avatar
Drives: 2016 Tesla Model X P90DL
Yeah,
I think it's time to order...
      08-04-2011, 09:37 PM   #8
zerrantoss
25
Drives: 2011 X6
I also got mine installed.
But I am having a hard time "twisting" the bulbs in place.
After inserting the bulb, it should be twisted from 0 degrees to 45 degrees, but I can only turn up to around 10 degrees. Then the orange rubber makes it too tight to turn.
From one of the other posts, someone mentioned that they had to trim the orange rubber a little bit.
Did you have this problem?
Right now, I just left it positioned at 10 degrees.
      08-05-2011, 12:52 AM   #9
dmlgc
dmlgc's Avatar
I agree I torn up the top of my hands getting these installed, I think I have them in at about 15 degrees that's all I could turn them. It's something the LUX folks need to work on.
      08-05-2011, 08:47 AM   #10
AndreyATC
AndreyATC's Avatar
Someone here used channel lock to twist the bulb
Seems like it's very very tight fit, not like OEM
LUX, is it easy enough to swap the rubber seal?
      08-05-2011, 11:02 AM   #11
Tatuaje
Drives: '11 X6 50i
I used a set of channel locks. They work, but you need to be really really careful.
      08-05-2011, 11:26 AM   #12
dmlgc
dmlgc's Avatar
I don't think I'm that confident that I would try the channel lock approach, my luck I would break them. Hopefully LUX can weigh in with some tips, I really like these but the installation is a challenge.
      08-05-2011, 12:28 PM   #13
scottjays
Starfleet Command
scottjays's Avatar
315
Drives: 2020 X5 M50i
I tore up tops of both, as well as sides and both thumbs. lol, it was quite painful to twist the lux lights. I am not even sure I twisted them at all. I have cracked the hood to check the if they have popped out each time I return from driving. so far so good. I love the look of the lights but I have emailed LUX to say the O ring is the problem, way to thick. I have swapped the AE's between OEM, PIAA and another brand more time than I wish to admit and the LUX are by far the hardest to fit.
      08-05-2011, 08:38 PM   #14
dmlgc
dmlgc's Avatar
yup same as you swapped same brands , these are the best. Also like you trashed tops and sides of both hands. I think I have them twisted about 15° and check them every few rides. so far so good.
      08-06-2011, 01:55 AM   #15
zerrantoss
25
Drives: 2011 X6
I tried to take out the rubber and test rotate the angles.
I think at around 10-20 degrees, the outer ring lights up the most.
So I am good with leaving it at 10-20 degrees.
You guys can do some testing and check which angle is brighter.
      08-08-2011, 09:44 PM   #16
ThatDude
Beltway Haven
Drives: X6 M
Will like to get a set for my 2011 X6 M. How long do you think it will take my mechanic to fit in? Don't want to be messing with my baby.
      08-09-2011, 02:53 AM   #17
zerrantoss
25
Drives: 2011 X6
No more than 30 minutes..
I am not a mechanic, and it only took me 15 minutes.
      08-09-2011, 02:03 PM   #18
LuxAngelEyes
Drives: BMW
Luckily the X5 and X6's have much more room to work in, so installing these will take 5-10 minutes
      08-10-2011, 10:37 AM   #19
dmlgc
dmlgc's Avatar
Hopefully you will create more lights for the X6, backups would be next on my list. normally ones too dim.
      08-10-2011, 07:21 PM   #20
Mrpeterman
Drives: 2007 x5 3.0is
How do the GT Autohause LED's compare ?
      08-11-2011, 10:41 AM   #21
itsme123
Drives: 2013 MCB F10 M5
There is an overall consensus on this (and others) forum from those who tried LUX that it is the best choice hands down. There is only one other brand that is better --->BMW OEM LED.
      08-11-2011, 11:15 AM   #22
LuxAngelEyes
Drives: BMW
Do you have any pictures of what that brand looks like?
