08-14-2011, 01:48 PM | #1 |
Rep 251
Opti-Coat?
Has anyone gotten the opti-coat treatment for their car? It claims to be a clear coat layer added onto the original clear coat permanently. It apparently gets good reviews and is said to last up to 5 years. It can only be done by select detailers and is pretty expensive so I was wondering what you guys thought about it?
08-14-2011, 07:23 PM | #2 |
Rep 31
Having used it a couple times now it is quite effortless to use. The paint will feel a tad sticky and even when its cured its not slick. Opti-Coat is the only true coating (urethane-ish design). Its the only true permanent coating as it acts as a sacrificial layer of clear. The only thing that will remove it is compounding it off (even a light polish doesn't always remove it fully).
Before use you want to make sure there are no defects, oils, residues etc. I use a paint prepping solution (works better than alcohol) to prep the surface. Max 10CC on a full car like the 1 series. Yes, it has a slight hardness to it, but will not protect from stupidity. Even with the coat proper paint maintenance is recommended. |
08-14-2011, 09:35 PM | #3 |
Rep 251
Awesome thanks!
I've read that waxing becomes moot with the coat, and the coat actually lessens the length of wax protection. Would you say that a shampoo with carnuba wax in it would be enough for weekly maintenance? Also I've read that sealants are no longer necessary and you should avoid polishing as it removes the coat (as you've stated) I guess I'm still a little ignorant to it, I just got a new 1 series and think it'd be nice to have like new paint in 5 years- what would you reccommend for maintenance to a car that has had the opti-coat applied? |
08-14-2011, 10:39 PM | #4 | |
Rep 31
You can apply v2 by yourself which has a longer cure time which in turn helps out a novice as you can buff down the high spots. It's $60 at Detailed Image. Otherwise look at about $150-200 for a coat from a detailer. |
08-15-2011, 09:53 PM | #5 |
Rep 3,732
Drives: BMW S1000XR
Thanks for the info...I was trying to figure out where to buy it. I am still trying to figure out the physics involved...10cc's for the entire car? I have seen some vids on applying this coating but still very hard to believe. I am not certain if there are enough molecules in the droplet they recommend to use on a sponge, let alone in 10 cc's for the entire car. Sounds like a great product...but (?).
08-15-2011, 10:24 PM | #6 | |
Rep 31
If you want to think about it in a physics perspective look at a paste wax, similarly you can do 40 cars with an 8oz jar of wax. 240ml/40= 6ml per coat on a car. I don't see why 10ml is all that shocking! A 1 series might take as little as 5ml, I've seen it done (well without wheels, plastic, and glass application). 10CC is 10ml, if you want I'll take a picture on how big the syringe actually is. Its way more than doctor grade |
08-15-2011, 10:37 PM | #7 | |
Rep 3,732
Drives: BMW S1000XR
08-15-2011, 11:08 PM | #8 | |
Rep 31
08-16-2011, 05:16 PM | #9 |
125
Rep 3,515
The Optimum Opti-Coat 2.0 Permanent Paint Coating works extremely well and as advertised. The first version was only to be used by pros because the application was so challenging. David G at Optimum revised the formula and made this version much easier to apply and it's now available to anyone. If you keep checking out our Ask a Pro Blog we should have an article and video up about it in the coming month. If you have any questions please let me know!
Greg @ DI |
08-19-2011, 08:29 PM | #10 |
Rep 251
I do have a question.
Say I did the 2.0 on my car: And as Reflections stated maitenance is required (Obviously). I wasn't "overrating" the coat as he mentioned- was just wondering what kind of maitenance would be best? I read on Opti-Coat write ups that waxing/sealing doesn't do much since wax and sealants wont bind to the opti-"Coat" so to speak. I assume a slick wash would be fine: Greg you mentioned the Dodo Juice with carnuba in it: Would that be fine? Sealants yes or no? What would you reccommend for someone with the Opticoat to do weekly/monthly/yearly? |
08-20-2011, 11:45 AM | #11 | |
27
Rep 872
You can look at the coating as the ultimate wax if you'd like, but I'd recommend you treat your coated car just like any non-coated car. If you do that, you'll still notice a huge difference over time as your car will stay even cleaner longer, will clean off easier, and will acquire many less paint defects over time. |
08-21-2011, 04:41 AM | #12 |
Rep 770
[I'm amused at the thought of people not wanting to use anything over Opti-Coat because it won't "bond." How strongly do you think sealants really bonded to your paint if they could be so easily removed with strong shampoo dilutions?]
A polymer sealant forms a molecular bond to the polyurethane paint, think of it like a chain, they are formulated to be detergent resistant, so harsh detergents don't break this bond they attack the chemicals of the polymer and weaken its links. See also "Chemical Bonding of Polymers etc" - http://www.autopia.org/forum/guide-d...ml#post1452821 Last edited by TOGWT; 08-21-2011 at 05:01 AM.. |
08-21-2011, 01:44 PM | #13 | |
27
Rep 872
08-21-2011, 01:55 PM | #14 | |
125
Rep 3,515
Greg @ DI |
08-22-2011, 05:37 AM | #15 | |
Rep 770
A polymer will only form a cross-linked bond with paint (polyurethane), this bond is formed on a molecular level by the polymer molecules bonding together, that's part of the reason why sealants cannot be layered. |
09-03-2011, 04:27 PM | #16 |
Rep 251
Hey Greg that does help.
TOGWT thanks for posting that info - I am a detailing newbie, and only read what the product description states (In this case OptiGuard/Coat 2.0 says that additional sealants and waxes will not adhere and may not be necessary.) So, if I had the 2.0 coat or even the OptiGuard applied: I would wash with my usual DoDo Juice Sour Power, then would a sealant like Opti-Seal be the second step? Or should I just go straight to DoDo Red Tropical Spray as my detailer - and THEN the Opti-Seal? (DoDo Tropical spray says it will help sealant durability, which I'm not so worried about after the OptiGuard coat) Again, these questions come from a complete newbie, as I read the directions and follow! Last edited by MPFit; 09-03-2011 at 05:54 PM.. |
09-03-2011, 06:58 PM | #17 | |
27
Rep 872
Use one or the other after a wash if you choose. |
