09-12-2011, 03:01 PM | #1 |
13
Rep 343
135i - SCCA class with tune
i've had my 135i bone stock run under "D-Stock" in the SCCA autoX events...
Does anyone know what class the 135's falls under with a Tune (eg Cobb etc.)? Ididn't find the answer via any searches Some thing it may go in to the ST (Street Touring) class... but i'm not sure if the rules work in line with the tune... it would be great if someone can shed some light on this that may have done this. thx! Here's what the 2011 Solo Rules books says about ECU mods in those classes... F. The engine management system parameters and operation may be modified only via the methods listed below. Any and all modifications must meet or exceed the applicable EPA tailpipe emissions standards for the year, make, and model of the car. These allowances also apply to forced induction cars, except that no changes to standard boost levels, intercoolers, or boost controls are permitted. Boost changes indirectly resulting from allowed modifications are permissible, but directly altering or modifying the boost or turbo controls, either mechanically or electronically, is strictly prohibited. 1. Reprogrammed ECU (via hardware and/or software) may be used in the standard housing. Traction control parameters may not be altered. Altered engine controllers may not alter boost levels in forced induction engines. Alternate software maps which violate these restrictions may not be present during competition, regardless of activation. Street Touring Class (ST) Class Requirements and Restrictions: Coupes/Sedans - 4 seats minimum (non-sports car-based) Engine Displacement: Up to 3.1L normally aspirated or Small turbocharged engines specifically listed below No Limited-Slip Differentials except factory standard viscous types No Electric or Hybrid-Electric vehicles Example Classifications: BMW 3 Series (non-M) or... Street Touring Class X (STX) Class Requirements and Restrictions: Coupes/Sedans - 4 seats minimum (non-sports car based) Engine Displacement: Up to 5.1L normally aspirated or Up to 2.0L forced induction (turbocharged/supercharged) No Electric or Hybrid-Electric vehicles Example Classifications: BMW M3 (E30 chassis) (1988- 91)
|move over... please| |
09-12-2011, 03:09 PM | #2 | |
Rep 475
09-12-2011, 07:45 PM | #3 |
Damenslip-Tropfer
23
Rep 543
Any tune that increases your boost puts you in BSP like he said above. If you mess around with much an intercooler, BOV, or CDV it bumps you into Street Mod.
Heres the link you want: http://www.garageprosoftware.com/scirocco/135i.html Last edited by xerox445; 09-12-2011 at 07:52 PM.. |
09-12-2011, 08:06 PM | #4 |
13
Rep 343
Thx
Thanks guys.
Awesome link. I think I'll stay in d-stock for the rest of this season and then decide if I want to run with the big boys in BSP.
09-12-2011, 08:33 PM | #5 |
13
Rep 343
LoL
Was going thru the list and noticed that de-badging takes you out of D-Stock - lol... Maybe because of weight savings?
09-14-2011, 12:41 PM | #7 | ||
Rep 566
No, but that's a funny one I put in because believe it or not they explicitly mention it in Street Touring: Quote:
09-14-2011, 12:51 PM | #8 |
Rep 566
Back to the original question though; until Cobb comes out with a tune that does NOT alter boost for the AccessPort (doubtful at best), there are no 135i tunes allowable in Street Touring and you need to run BSP.
To further expand on this, even using JB3/4 or Proceed on STOCK mapping (or if they came out with a map that doesn't modify boost) is technically illegal: "Alternate software maps which violate these restrictions may not be present during competition, regardless of activation." The problem is it is difficult for them to police this in today's age of "hot-swap" capable tunes - they (SCCA) have no method to determine if you swapped from stock map to Map 85678 on the starting line.
09-18-2011, 08:43 PM | #9 |
13
Rep 343
this is good feedback and you're right, it's going to come down to the honesty policy. if i rank well, i'd want to be proud of it....
i'm going to try to stay stock for now, and then work on suspension and get a tune once i'm ready to jump straight to BSP. p.s. XaeRyan - my dad had a mid 80's scirocco in tornado red... i knew it was such a hot car even back then when i was like 9yrs old haha!
