M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      09-24-2011, 01:46 PM   #1
-=Hot|Ice=-
Been There, Done That.
-=Hot|Ice=-'s Avatar
Drives: 2013 BMW M3
BMW Active Differential on F10 M5, what is it?
What is the M5's new active diff? How does it help? I'm guessing it'll make it's way onto the F80, but how is a rear diff 'active'?
Originally Posted by Jaypod View Post
You sound like my buddies who have AMG's - Slam the gas, slam the brakes...
      09-24-2011, 01:50 PM   #2
abehwang
Drives: e90 m3
Helps prevent wheel slip as much as possible while distributing the right amount of power to each wheel , mainly during cornering, which results in better handling with optimum power.
      09-24-2011, 02:05 PM   #3
-=Hot|Ice=-
Drives: 2013 BMW M3
That's the thing, how does it prevent wheel slip any more then the current M diff does?
      09-24-2011, 02:13 PM   #4
duk
///M
Drives: 2011 AW/FR 6MT E92
electronics?
2011.5 AW/FR E92 M3 6MT
      09-24-2011, 02:13 PM   #5
-=Hot|Ice=-
Drives: 2013 BMW M3
Originally Posted by duk View Post
electronics?
The ///M diff is mechanical, unless that's changed.
      09-24-2011, 03:27 PM   #6
abehwang
Drives: e90 m3
it transfers different percentages of power or torque to the wheels to help prevent slipping or compensate for things like understeer
      09-24-2011, 03:44 PM   #7
-=Hot|Ice=-
Drives: 2013 BMW M3
Doesn't the current M diff do that as well? What I'm saying is, how has it been improved over the current M Diff?
      09-24-2011, 04:13 PM   #8
piloto
Drives: 2011 E90 M3 - AW/FR
An active diff works just like a traditional limited slip diff, except it's proactive in a sense rather than reactive. For instance, the current M Diff needs to sense slippage before it adjust the torque split between the two halfshafts, whereas an active diff will consider the steering input, yaw rate, vehicle speed, individual wheel speed, etc to proactively adjust the torque split in anticipation of what what the car will be doing. It's exactly what Ferrari's eDiff does. Same thing basically.
      09-24-2011, 04:21 PM   #9
-=Hot|Ice=-
Drives: 2013 BMW M3
That's what I was looking for. Thanks Piloto.
Tags
2012 m5 active diff, 2012 m5 active differential, active diff, active diff f10 m5, active diff m5, active differential, active differential bmw, active differential f10 m5, active differential m5, bmw active diff, bmw active differential, bmw m5 active diff, bmw m5 active differential, f10 m5 active diff, f10 m5 active differential, m5 active diff, m5 active differential, new m5 active diff, new m5 active differential
m5post
