      11-15-2011, 11:57 AM   #1
John Dempsey
Drives: White 135i M-Sport
Beat way to launch a 6mt
I\'m struggling to get a good launch out of my car. What are you guys doing to get a good launch. My 0-60\' is awful
      11-15-2011, 01:28 PM   #2
pixelblue
pixelblue's Avatar
140
Drives: the silver bullet
2010 135i  [8.90]
keep revs at 3k, drop the clutch and modulate throttle accordingly to eliminate wheel spin
"I would quote everything pixelblue said, but you've already read it. Take it from someone who's put the 1 through its paces"
      11-15-2011, 01:34 PM   #3
TEAM SLO
Slo'est E90 around
TEAM SLO's Avatar
Drives: 135i gone, 2011 335IX e90 6mt
What is your 60' time? I would expect a decent 60' to be around 1.8 - 1.9 with street tires. Will also depend on what clutch, tires, suspension. Are you bogging or getting too much wheel spin?
You probably already know this, but just in case..... You try and achieve a little balance of wheel spin vs bogging, in my experience, it's a tire screech without going to a full blown burnout.
Just my $.02, haven't taken out the 135i to the strip, but have done so with quite a few other cars all F/I. 1.81 with the 03 cobra with stock tires and a 1.69 for the STI with stock tires and exhaust. Understand the STI is awd though.....
      11-16-2011, 12:16 PM   #4
Mnst3r
Mnst3r's Avatar
Drives: 09 135i Msport 6MT
You need some dragtires like Mickey Thompson or Nitto tires. Then you can get better 60' times.
09 135i M-sport
      11-24-2011, 08:17 PM   #5
rathissolid
Drives: 08 135i 6speed
interested in this !?
      12-01-2011, 10:22 AM   #6
Mr. Nice
Mr. Nice's Avatar
141
Drives: G80 Comp XDrive
I launch like I would leave a stoplight, low in the rpm range, just do everything a little faster. That's on street tires, some Mickey Thompsons would be key if you want to drop down to 1.8s or better.
Originally Posted by djkrajzi View Post
Mr nice doesn't play nice. But I guess he has a very fast car
      12-24-2011, 12:09 PM   #7
rathissolid
Intrested in this
      12-24-2011, 02:09 PM   #8
Fundahl
Drives: VO 1M, 300zx TT
The trick is avoiding wheel hop AND avoiding too much bog. I find that launching with a slight amount of wheelslip to where the car is just about to bog and then going WOT gets the fastest 1st and 2nd gear.
The surface also plays a big factor of course.
Make sure your tires are warm. Try holding your revs around 2,800RPM and let the clutch out fast without dropping it (to not shock the tires). As you are letting the clutch out feed some throttle in. By the time you are 100% engaged you should be 100% throttle.
This whole process only takes about 3/4 of a second. The results should be a clean launch with slight wheelspin and NO wheelhop.
      12-26-2011, 08:14 AM   #9
dtwyim
dtwyim's Avatar
52
Drives: BMW no more
Do you go TIM YOYO or DTC?
      01-19-2012, 06:26 AM   #10
MrBlonde
MrBlonde's Avatar
Australia
122
Drives: Audi TTRS, M Coupe, 1299
Click on the link in my sig for tips.
.-=[ Kenny ]=-. 1999 BMW M Coupe 10.775 @ 134.35 mph w/1.600 60' (Best 136.07 mph) 25th August 2004. +2010 X5 35D+
Check out the 1Addicts Drag Racing Standings and Drag Racing 101.
      01-20-2012, 02:18 PM   #11
mdyates
Drives: 13 335is DCT JB4
I worked on this the other night. DSC off completely
CDV and BMS clutchstop on my '12 135i.
3,000 rpm and 3/4 throttle till mid 2nd gear. I have jb stg2 and dp though. I managed a 2.0 60 ft time on my RFT's the other night!
1addicts
