      11-15-2011, 02:06 PM   #1
Elliott@DetailAddict
Drives: E90
Detaill Addict-Track Car, Custom Package 2006 s2000
2006 S2000 Laguna Blue
Engine
- Stock F22C with USDM F20C Pistons
- F20C Cams
- Kraftwerks Supercharger producing 381hp 242tq
- Hondata Kpro Dual Adapter ECU
- BlackTrax Fuel Return System
- Aeromotive FPR
- Walbro 255 Fuel Pump
- Spoon Engine Damper
Transmission
- Stock Transmission
- BT Custom Profile Stage 3 Clutch
- ACT Prolite Flywheel
Suspension/Wheels/Tires
- Spoon Front Upper Strut Bar
- JRZ RS-Pro 2-Way Suspension
- Swift 20kg springs
- Gendron Front Adjustable Sway Bar
- BT Front and Rear Bumpsteer Kits
- Toyo R888 Tires
- Wheels: 17x9 Black Enkei RPF1 and Magnesium Blue Volk CE28N wheels
Exhaust
- Test Pipe
- Invida Dual Cat Back Exhaust
Exterior
- Custom Carbon/Blue Kevlar Hood
- Seibon Extended CF Fenders
- Voltex Type II CF Wing
- OEM Hardtop
- Clear Bra by Omega Tintwerks
Interior
- JDM Center Console
- JDM Ebrake (located to driver side)
- BT Shift Knob
- Momo Corse Steering Wheel
- Brde GIAS Carbon/Kevlar Seat
This is a track car from BlackTrax Performance in Milpitas. They decided to give it a good buff after a recent track day.
Since this is a track car, we decided not to go with a 100% correction, but with G-1500, G-3500, and spot correction with G-1000, we achieved a lot of correction!
Wash
- Camspray Foam Gun
- Detail Addict Water Softening System
- Detail Addict Car Soap
- Detail Addict Grit Guard
- Detail Addict Wash Mitt
- Detail Addict Waffle Weave Drying MF
- Detail Addict Engine+Wheel Cleaner
- ACE TurboStick
Clay/Polish/Wax
- Porter Cable 7424XP
- Detail Addict Backing Plate
- Detail Addict CCS Pad Set
- Detail Addict Medium Grade Clay Bar
- Detail Addict Detail Spray (lube)
- Detail Addict G-1000 Polish
- Detail Addict G-1500 Polish
- Detail Addict G-2500 Polish
- Detail Addict G-3500 Polish
- Detail Addict Liquid Wax
- Detail Addict Carnauba Wax
Miscellaneous
- Detail Addict Carpet Cleaner
- Detail Addict Glass Cleaner
- Detail Addict Glass Towel
- Detail Addict Rub&Shine
- Detail Addict Dressing Sponge
- Detail Addict Leather Cleaner
- Detail Addict Leather Conditioner
Here are couple of before shots...
They saved a little something something for me...
We started with the wheels and tires first with our Engine+Wheel Cleaner
Agitate it a little with a soft brush
Crazy amount of brake dust, so we tackle the inside with our ACE TurboStick
With our Water Softening System and pressure washer setup, we went with our super concentrated Car Soap + Camspray Foamgun for maximum sud action!
With setting little under halfway, this is the kind of foam action we get!
With only this much of soap
And the rest is all water!
After just a quick wash
Get right to clay bar after the wash
After a quick rinse we check out the paint condition
We started off with G-1500 Polish and it was able to take care of most of the area. There were some trouble spots that we had to start with G-1000
Took a little break from the exterior and worked on the carpets a bit with our Carpet Cleaner
Pretty bad shape... and very worn on the driver side
All we did was spray and rub and wipe off with some microfiber towels
There is only one OEM seat in there, but we gave it a good clean and condition anyway
With just single pass of our Leather Cleaner and Leather Conditioner
Back to the paint and gave it another polish with our G-3500 Polish the follow up with our Carnauba Wax
It was getting dark QUICK! Here are the front and rear photos
1addicts
