11-15-2011, 10:59 PM | #1 |
76
Rep 380
a/c not blowing on one vent
hi guys this is happening on my 07 x5 on my driver side vent, next to my door, double vent, I noticed that is barely blowing air, compared to the other vents, what can be causing this? Thanks |
11-16-2011, 10:05 AM | #2 |
Rep 1,410
It's your battery.
I has the same issue with mine. 07 E70 4.8. It only worked on one side. New battery aftermarket $160. Dealer $375 Went the aftermarket route worked great. When you swap the battery you may experience issues with radio and other electronics not working. If so that is due to the programming that needs to be done on the car for the new battery. Dealer or certified BMW shop can do this $80-$250 depending on how good or bad they are. Good luck.
