      12-15-2011, 04:39 PM   #1
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Post Eisenmann "SPORT" Exhaust
Just purchased the Eisenmann "SPORT" Exhaust, so I guess I am going to be "the canary in the coal mine" since no on else has purchased/installed or even heard this system. The OEM system is pretty loud straight from the box. In fact it is by far the most aggressive sounding OEM exhaust I have ever had on any previous M car I've owned before. My E90 M3 was 'Civic' quiet in comparison. My goal is that this system changes the tone without getting too loud. Regardless, the quality of the Eisenmann is superior to the OEM and it will tuck under the rear valence nicely. A few extra hp's maybe, but not expecting huge gains.
The Eisenmann "Sport" will increase sound levels over OEM system by ~3db's but should be 1/3 the volume of the "Race" system. I plan to do the Akrapovič downpipes next and then finally an ESS tune to round out the performance mods. The system should be here shortly after Christmas and on the car early January. I will update with pics/video and my evaluation at various loads and RPM's.
Would like to thank Josh, Gregg, Scott and Sean at VIVID Racing(in AZ for hooking me up: http://www.vividracing.com/catalog/e...=27&class_8=28
Of course thanks to Ilia and Nate at IND for your help as well!
This clip was recorded with an iPhone 4s after 2k mile break-in on the exhaust.
Sound Levels/Decibel Ratings
Eisenmann exhausts are available in two sound levels.
Decibel levels as compared to the OEM factory exhaust:
Sport exhaust: + 3db
Race exhaust: + 10db
Slip-on System Features
Rear muffler section with 4 x 83mm tips
Connecting Pipe
Full system weight: 35.6lbs
Eisenmann Exhaust Specifications
- Made in Germany
- 2 year warranty
- 100% light-weight T304/T306 stainless steel
- Top quality craftsmanship
- TUV certified (only SPORT sound level)
- DIN EN ISO 9001 certified
- CAD/CAM graphics and simulation design technology
- Laser CNC machining and sheet-metal processing
      12-15-2011, 04:46 PM   #2
mPlasticDesign
684
RESERVED
EDIT:
OEM vs Eisenmann comparison
SPORT
moving vehicle = 75 db
stationary vehicle = 92 db at 6.225 1/min
25% flow improvement over stock
weight of the muffler = apr. 21 kg
RACE
moving vehicle = apr. 95 db
stationary vehicle = apr. 102 db at 6.225 1/min
32% flow improvement over stock
OEM
EISNEMANN
      12-15-2011, 04:51 PM   #3
marcel b
marcel b's Avatar
132
Drives: F31 340i
I will get the sport system as well, the cat-back version. What did you order? Mufler only or including the midpipes?
      12-15-2011, 05:03 PM   #4
HP Autosport
Supreme Allied Commander
Drives: F80 M3
You should look into a midpipe as well. We have had great sound and performance results from both the Mad Dad (preferred) and Berk midpipes.
-Tyler
      12-15-2011, 05:15 PM   #5
mPlasticDesign
684
-Tyler
Mid-pipes > Down-pipes?
I got the axle back only. I was under the impression that the money would be better spent on down pipes. I'm not sure now....
      12-15-2011, 06:48 PM   #6
Dan Parker
Drives: 2012 Golf R
Thanks for testing. Any dyno plans?
Dan Parker
      12-15-2011, 06:58 PM   #7
Powerbeast
Powerbeast's Avatar
Drives: F80 M3 RarriRot
Nice system.
      12-16-2011, 09:14 AM   #8
mPlasticDesign
684
I will probably just do a final dyno when everything is done, just to see what the car is putting down. I don't have access to a dyno to do before/after runs on every planned mod, even though that would be nice.
      12-16-2011, 11:59 AM   #9
richb811
richb811's Avatar
455
Drives: 2020 G20 330i M Sport
I usually recommend the Race if you are looking for an increase in sound. IMHO the difference between the Sport and OEM is not enough to notice.
      12-16-2011, 12:22 PM   #10
mPlasticDesign
684
I was told by several different sources that the tone difference is noticeable(deeper). It will be a bit louder, I know myself enough to know the Race would be too loud for me. So I take it you've heard the Sport on the 1M?
      12-16-2011, 12:32 PM   #11
TunedM2C
TunedM2C's Avatar
829
Drives: 2016 LBB M2
Plan on mid pipes too. These plus the dp's will maximize the power gains.
      02-14-2012, 11:12 AM   #12
BucksCty135i
Drives: 2012 LeMans Blue 135i M Sport
Have you installed this system? Curious as to your thoughts on the tone / volume for the sport.
2012 135i M Sport, LeMans Blue/Black int with Poplar - PPK, Dinan Front Sway, BMWPedals, Active Autowerke Strut Brace, KM11 for winter and VMR 718for summer.
      02-14-2012, 12:08 PM   #13
///M1
///M1's Avatar
Drives: Many
+1 Based on my experience with the 135i and 1///M, you get more gains from the mids than the axle back itself. And some meaningful weight savings to be had as well, the stocker with the resonator and secondary cats is a pig.
2011 BMW E82 1///M: AW, all options; Renntech, Akrapovic, Forge, P3, RevoZ CF bits, many mods
1988 BMW E30 M3: Hennarot, S14, stock
2018 Porsche 991.2 GT3: PtS, CXX, LWBS, PCCB
1998 Porsche 993 C4S: Zenith Blue, last aircooled widebody, Bilstein PSS10, Fister II + Fabspeed exhaust
2008 Audi B7 RS 4: Sprint Blue, Audi Exclusive Euro Bucket Interior, Premium+Titanium, many mods
      02-14-2012, 12:34 PM   #14
VO 1M
VO 1M's Avatar
Drives: 1M Coupe
I have the full sport system installed (mid pipe and muffler) and indeed the sound is deeper. When I start the car in the morning the house starts shaking :-)
I only have it installed for abour 500 miles, it is still getting louder. It seems to get louder up to 3'500 miles. While cruising it is quieter then stock, at least at the moment. This is because the drone is gone! I am happy with it, for sure.
      02-14-2012, 12:43 PM   #15
mPlasticDesign
684
It's been a long wait, but I get it in 2 days and should be on the car before the end of the weekend. I will have video clips of before/after posted as well then.
This is good news! Why anyone would want drone at cruising speeds is beyond me.
      02-14-2012, 02:37 PM   #16
VO 1M
VO 1M's Avatar
Drives: 1M Coupe
It will quite silent when you start it the first time. But don't worry, it will get louder. Also, don't be surprised if you see your exhaust smoking in the beginning. (smells as well) This is the muffler being burned-in.
fully agree, it is such a relief. The drone was really annoying me on longer trips.
      02-21-2012, 03:24 PM   #17
mPlasticDesign
684
Updated with pictures in post#2
Well, the exhaust is finally on the car. It was a long excruciating wait but well worth it. The exhaust sounds amazing so far. The drone at cruising speeds is gone. Some more drone is present below 2k but I don't care because I don't spend any time down that low. So I can't really say much more because I think it will change with a few hundred miles on the clock. The tips are an improvement over OEM and the body of the exhaust tucks up nicely under the rear valence unlike the OEM that is kinda an eyesore. The welds, the finish, worksmanship is incredible! I still want to meet up with someone with a Race system to do a comparison. If I continue to gush over the system you are going to start to think I have some stocks in Eisenmann or some vested interest, so I will stop.
I am going to do some video clips this week and post them here so stay tuned!
      02-22-2012, 01:16 AM   #18
VO 1M
VO 1M's Avatar
Drives: 1M Coupe
Great you finally have it. I have made the same experience as you and indeed, it will get louder ;-)
      02-22-2012, 02:49 AM   #19
Stratus650
United Arab Emirates
189
Drives: 1er M Coupe
looking great Metak ! Congrats
I think the drone will be the only reason pushing me to replace the exhaust later on, other than that I think it looks and sounds fine.
We are looking forward for the Video
'12 Candy Grey Metallic 1M
      02-22-2012, 07:38 AM   #20
eeghie
Kind of a big deal
300
Drives: an 1M not often enough
... Regardless, the quality of the Eisenmann is superior to the OEM and it will tuck under the rear valence nicely. ...
Nice, thx for posting. Agree that OEM=eye soar and the improvement is very well illustrated
... Rear muffler section with 4 x 83mm tips ...
It does look good, but for me the OEM pipes are slightly more modest ~elegant. (rather have the sound do the talking)
... Full system weight: 35.6lbs ...
What is the weight comparison with OEM axle back?
PS I could never get enough of your de-lip-ed trunk pics ...
      03-13-2012, 02:05 AM   #21
Stratus650
189
Drives: 1er M Coupe
Any videos Metak ?
How's the eliminated drone ?
      03-13-2012, 11:32 AM   #22
///Morgan
///Morgan's Avatar
10
Drives: BMW
I am seriously considering this exhaust for my 1M, but the only thing that stops me is that I think the outer tips are too short and everybody will see the welding + diferent sizing of the tubing joining to the tips.
Can someone please post some pics to confirm or dismiss this issue?
Thanks!!
1addicts
