      01-09-2012, 10:34 PM   #1
M///1rider
M///1rider's Avatar
Drives: 2011 BMW 1M
Bmw 1m short throw shift kits
Hey guys so i was looking to purchase a short throw shift kit for my 1m.
I just saw that uuc has a kit that fits 2011+ 135i as well as the 1m and that kit looks great! .
Would the performance short throw shift kit from the 08 135i fit as well?
If so i believe i will purchase the performance one instead of the uuc just because it is a bmw part. Thanks
      01-09-2012, 10:39 PM   #2
HondaGoneRogue
They like my Swag...
HondaGoneRogue's Avatar
433
Drives: 15 GSM 435i GC
The carrier (shifter arm) for the BMW performance assembly must be replaced. I'm not sure if the 1M has the same part. The ssk was my first mod tho, and it is awesome.
Here is your break down:
Item #1 is the carrier. ( Shifting arm, reinforced 25117590609) The 08' unit is a different part number. ( SHIFTING ARM 25117524720) If you could find the part number for the performance piece, maybe we could tell if it works. Maybe the M has the performance piece already.
Parts here: http://www.realoem.com/bmw/showparts...28&hg=25&fg=05
My tablet can't copy all the pics so hope this helps.
2015 435i Gran Coupe - Current
2008 AW 135i - Sold
      01-09-2012, 10:43 PM   #3
M///1rider
M///1rider's Avatar
Drives: 2011 BMW 1M
Which ssk did you go with?
      01-09-2012, 10:58 PM   #4
HondaGoneRogue
433
BMW performance. I don't think the other companies require you to change out the carrier.
2008 AW 135i - Sold
      01-09-2012, 11:01 PM   #5
M///1rider
M///1rider's Avatar
Drives: 2011 BMW 1M
So all i need to purchase is the bmw performance ssk and the n54 transmission carrier and im good to go?
      01-09-2012, 11:05 PM   #6
HondaGoneRogue
433
The new carrier is part of the ssk. We need to know what difference the 1m carrier has from the 135i's. Since they are different part numbers (the stock pieces) I'm not confident in saying it would fit. We need to find the part number for the performance carrier just to make sure.
2008 AW 135i - Sold
      01-09-2012, 11:10 PM   #7
M///1rider
M///1rider's Avatar
Drives: 2011 BMW 1M
Oh sorry i thought you had a 1m!! And yea i had the performance ssk on my 08 135i as well and it was great i would really like to stick with a bmw part so figuring this out would be nice if not ill just go with the uuc tho
      01-09-2012, 11:11 PM   #8
HondaGoneRogue
433
If you go here: http://www.shopbmwusa.com/ProductLis...=139&perf=true
The ssk option disapears when you select 2011 or newer. I believe that is due to the n55 not being compatible. There isn't even an option for the 1m. It could still work tho. I would email dan@unitedbmw and ask him.
2008 AW 135i - Sold
      01-09-2012, 11:13 PM   #9
HondaGoneRogue
433
Lol nope. I always find myself in the 1m forum since the new post button just shows all new posts. Sometime I don't even realize I'm here hahaha. Down to figure it out tho.
2008 AW 135i - Sold
      01-09-2012, 11:26 PM   #10
M///1rider
M///1rider's Avatar
Drives: 2011 BMW 1M
Yea if i could figure it out it would be great if not ill just go with the uuc kit tho
      01-10-2012, 07:51 AM   #11
robertm
Drives: 2020 M2 Comp
I would get the UUC kit and not give it a second thought. I've used lots and lots of different SSKs over the years and UUC has always been among the very best. Even if BMW offered one, I'd choose theirs over BMW ssk.
      01-10-2012, 12:54 PM   #12
Dackelone
European Editor
Dackelone's Avatar
Germany
10539
Drives: N54 e82
For a 1M or a N55 135i, you can NOT use the BMW Performance SSK. The 2011 135i's(N55) and the 1M share the same 6MT trans which is different from earlier N54 cars.
The BMW Performance SSK only works on N54's. I have one on my car and LOVE it. It is a very nice mod.
BMW 135i SSK throws 6MT
N54 = 80mm throws
N54 w/Perf SSK = 55mm throws
N55 = 70mm throws
Like RobertM says... UUC makes some very good (short shift)shifters. IF they have a SSK for the 1M... its safe to say its probably pretty high qaulity.
I have always wondered IF you could just use the shorter shift lever/arm (#8 in the RealOEM photo above) on a 1M or N55. I bet that would give you 80% of theshort shift feel of the Perf SSK.
      01-10-2012, 04:02 PM   #13
ayao
Thread killer
642
Drives: 1M
N54 = 80mm throws
N55 = 70mm throws
Out of curiosity how much does the shift effort increase with your SSK? The 1M's throws are long-ish but I like the hot-knife-through-butter feel.
      01-10-2012, 04:43 PM   #14
Dackelone
European Editor
Dackelone's Avatar
Germany
10539
Drives: N54 e82
When you make the throws shorter(no mater who's SSK you use...) you also will increase the force(s) needed to move the shift lever. I'd say with the Perf SSK the effort goes up some 30% or so. 1st/2nd slots are more notchy... but the rest is pure sex. very short and crisp throws. I really enjoy the 3rd/4th gates with the Perf SSK now.
I rememberd with my stock shifter... when I would change from 2nd to 3rd... it would feel like my hand would almost hit the console under the radio area. With the Perf SSK... the lever hardly moves. It has been said that the Perf SSK is one of the best mods you can do to a 135i. I agree 100% with that.
Here is a very good FAQ on how BMW short shifters work and how to install them. Written by Ron Stygar... checkout Ron's little video at the top left corner of the page to see how much shorter a SSK is vs stock.
http://www.z3bimmer.com/Garage/Performance/ShortShift/
and...
http://www.unofficialbmw.com/e36/dri...ift_lever.html
http://www.unofficialbmw.com/e36/dri...er_images.html
      01-11-2012, 12:11 AM   #15
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Have a look at Rogue Engineering, they have a very nice 135i SSK. The 1M kit should be right behind it.
      01-14-2012, 09:10 PM   #16
Slats
Drives: 2011 1M & 1997 M3
My E36 M3 has a UUC short shifter that is a marked improvement over the stock setup. But I wouldn't want to change a thing about the way the 1M shifts. It seems perfectly balanced - an effortless fairly short throw.
      01-15-2012, 12:17 PM   #17
Vrumpkin
Seymour J. Vrumpkin
Vrumpkin's Avatar
15
Drives: BMW 1M
I agree with you on that. I always wanted an SSK and I think the 1M would be a great car to take advantage of that but I do like how effortless 1st-2nd is around town etc. with the stock setup.
Videos of an SSK on the M would be great!
      01-15-2012, 01:18 PM   #18
MDORPHN
Drives: AW 1M
FWIW, I put a short shifter in my '99 M Coupe. I have no such plans for my 1M. It's pretty sweet as is!
Neil
      01-15-2012, 03:51 PM   #19
Nate@IND
Nate@IND's Avatar
2868
Drives: BMW
We used the prototype 1M Rogue SSK on a build. The shifts were very short and smooth. Right when it comes out we will have a thread up.
http://ind-style.com/2011/12/02/1159/
IND DISTRIBUTION | 866-963-4520 • FACEBOOKINSTAGRAMFLICKR
      01-15-2012, 04:02 PM   #20
MDORPHN
Drives: AW 1M
Originally Posted by Nate@IND View Post
We used the prototype 1M Rouge SSK on a build. The shifts were very short and smooth. Right when it comes out we will have a thread up.
Is that red powder or paste rouge (or did you mean ROGUE)?
Neil
      01-15-2012, 07:14 PM   #21
HP Autosport
Drives: F80 M3
Neil
Rogue. Prototype is done. Production version should be out soon.
      01-15-2012, 07:17 PM   #22
Nate@IND
Nate@IND's Avatar
2868
Drives: BMW
Neil
Yes Rogue my bad
1addicts
