      02-15-2012, 12:22 AM   #1
rvsixdriver
rvsixdriver's Avatar
Drives: 2011 128i
Which camber plates?
Have a stock 128i 6mt sport pkg. stock wheels and rflts. Have done 2des and really got lots of outer edge wear on the fronts. Backs look ok.
Our track is really fast with several high speed sweepers. I dont plan to autox.
Im Driving the car pretty hard and having fun with ok lap times so I'm ok with performance as is, but I'm killing the fronts.
Heard pulling the pins only gives .5 neg, so I'm thinking about plates. Car still in warrantee, so I was thinking about dinan even though it only adds .7 deg fixed? Is this enough with pulling pins?
Is there a warrantee issue if you install for Vorshlag or ground control?
Which is better between ground control and Vorshlag?
This is my daily driver, so I don't want noise issues.. I like the car on the street juste the way it is, just looking to save some rubber for 8 to12 de 's I will do.
      02-15-2012, 06:50 AM   #2
Bimmer-Bob
Bimmer-Bob's Avatar
Drives: 2010 128i
I have the Dinan plates (installation requires removal of the camber pins, btw) and am running about -1.5° at each wheel after a dealer alignment. Previously I was at -1.16° and -2.16°, so I know I could be running more aggressively if I wanted to, but for the time being I'm just glad to have them more closely matched.
I don't have M3 control arms in front, which would add even more negative camber, but I am lowered at least an inch. I'm not sure you could duplicate these numbers at stock ride height.
____________________________
      02-15-2012, 02:17 PM   #3
Eddy@ApexWheels
Eddy@ApexWheels's Avatar
445
Drives: E30 M3, F10 M5
There is no warranty issue if you install GC or vorshlag plates. A law/bill was passed last year that prevents dealers for denying warranty claims because of aftermarket parts. The only thing they don't have to warranty is the upper mount that is replaced by the Camber plate.
      02-15-2012, 08:38 PM   #4
syenisch
syenisch's Avatar
Drives: 2015 435i Gran Coupe
Your first step should probably be M3 Control Arms. You get the camber of Dinan camber plates, but You also get the stiffer bushings. Next I would add the Dinan camber plates since there's no risk of noise there either.
      02-15-2012, 08:46 PM   #5
syenisch
syenisch's Avatar
I currently run BMW PS and M3 Arms and my wear is pretty even with 13k miles a year mostly highway and one DE event. I am adding the Dinan plates soon and an hoping to have good wear with 2 events per year.
      02-26-2012, 12:06 PM   #6
uberschnell
uberschnell's Avatar
675
Drives: Wide Body 1
Camber plates transfer so much noise into the cabin. Hitting a pot hole feels like it's going to tear the front of the car off.
That said, having a good shop align your car (with plates) transforms the car. I was amazed at how much the handling improved.
      02-26-2012, 01:33 PM   #7
syenisch
syenisch's Avatar
Curious to know which plates you are referring to? Careful to make blanket statements. There can be a big difference in the design from one company to another.
      02-26-2012, 02:21 PM   #8
pixelblue
pixelblue's Avatar
140
Drives: the silver bullet
2010 135i  [8.90]
I like to know which brand doesn't make any noise? I need one. tired of my noisy plates
"I would quote everything pixelblue said, but you've already read it. Take it from someone who's put the 1 through its paces"
      02-26-2012, 02:29 PM   #9
Focusedintntions
Drives: 2011 135i M-Sport :D
kori you may want to check into the ground control hybrid camber plates.
Faster, faster, faster, until the thrill of speed overcomes the fear of death… – Hunter Thompson
      02-26-2012, 02:43 PM   #10
syenisch
syenisch's Avatar
I've seen multiple reports that Dinan camber plates are noise free. They are just a plate that bolts on top of the OEM top-hat. Still uses the OEM bearing, etc. Just offsets the bolts to add some camber. No adjustability, but that means less parts that can squeak and creak. I am going to have them installed on my car in about a month. I already have M3 arms and BMW PS. I will be sure to report what my camber is with that combination.
      02-26-2012, 02:44 PM   #11
syenisch
syenisch's Avatar
Ill be sure to report if they are noise free for me too obviously.
      02-26-2012, 03:10 PM   #12
pixelblue
pixelblue's Avatar
140
2010 135i  [8.90]
dinan's plate give you very limited camber. if someone could make a fixed plate that offers max camber or to some varying degree I would buy.
Chris - isn't GC plates the same design as vorshlags ot tck's? spherical ball joints?
      02-26-2012, 03:28 PM   #13
yandy
yandy's Avatar
Drives: 2009 e92 MR "Civic" ///M3
2009 BMW M3  [0.00]
I don't know dude; my Vorshlags make no noise, on the street or on the track. Maybe I haven't noticed, but was one of the first things I tried to look for. Is it an install issue? Or maybe I'm just lucky I guess, I did install them myself just in case.
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
      02-26-2012, 04:22 PM   #14
pixelblue
pixelblue's Avatar
140
2010 135i  [8.90]
Give it some time. Already rebuilt mine in 2nd year
      02-26-2012, 09:05 PM   #15
GaryS
Drives: 2009 135i 6MT
2009 135i  [6.50]
Ground control makes street, hybrid and race camber plates for our cars. People who have them say the street plates make some noise, but a lot less than the race plates. Here's a thread. http://www.e90post.com/forums/showthread.php?t=514467
Dinan plates + M3 wishbones is a good compromise for doing street/track on street tires. It's not enough to get full potential from sick track tires like Pixelblue runs. Besides not enough camber, it's also not firm enough.
      02-27-2012, 06:40 AM   #16
EFI Logics
EFI Logics's Avatar
Drives: '08 BMW 135i, 08 535Xi
We will be installing a set of the Ground Control street plates within the next month or so for my 08 135i and I will make sure to do a nice write up for everyone to see.
Personally, they seem to be the best compromise between a full race plate like Vorshlag and a fixed plate like Dinan. They have axial load bearings that will need to be replaced after time like any other camber plate, but they also feature urethane bushings for long life and a smoother ride. You can also order them so that they are compatible with the factory springs or 2.5" race springs. Just my $.02.
-Josh
      02-28-2012, 05:55 AM   #17
CrustyNoodle
Australia
12
Drives: 135i DCT
Thanks Josh - very interested in the outcome.
Why have you decided to go for the street plates over the hybrid ones?
BMW - 135i DCT
Audi - Q5 3.0TDI
      02-28-2012, 11:40 AM   #18
EFI Logics
EFI Logics's Avatar
I have used GC products in the past and the design of the street plates fit my needs well. The urethane bushing aspect is very nice feature which will help reduce the NVH and harshness typically associated with a camber plate. It may cause a little deflection, but really I doubt it will be anything noticeable after looking at and feeling the bushing myself. They are also designed specifically to be compatible with the stock spring diameter. From what I understand, some people haven't had the best experience using the Vorshalg camber plates with the factory springs. I cannot confirm if that is true or not though as I have not tried them myself. I ruled the Dinan camber plates out because they don't offer enough camber, they aren't adjustable and I actually like the fact that the GC plates will be replacing the stock strut tops as they will be reducing a fair amount of deflection just by themselves. I will report back to you guys though with my final thoughts after having tried them out.
-Josh
      02-28-2012, 08:15 PM   #19
cpt97m3
AutoXer
34
Drives: 2009 135i
I had a set of Dinan plates, and they don't make any more noise that stock since they bushings and bearings are all stock. Dinan just adds an offset plate. I switched to the ground control street plates last weekend so I can get more camber. So far, they have been totally quiet. They don't use a solid metal bearing like Vorshlag. It is some type of poly bushing, so there is some flexibility, but it's much stiffer than the stock rubber.
The only problem I had is when I first got then, they came with spring hats that were 1/4" too wide, so they rubbed the body. I had to switch them with my stock hats, and now it's been working fine.
2009 135i, Alpine White, 6MT, M-Sport, iDrive, iPod/USB, Heated Seats, Premium Sound, BMW Assist
      02-29-2012, 02:23 AM   #20
uratomb
uratomb's Avatar
29
Drives: 08 AW 135i
For my 135i,
I got GC Street Camber plates on my stock suspension.
So far I don't really hear any noise from the plate.
And with stock height maxing out the plate will only give me -1.9 degree.
      02-29-2012, 03:01 AM   #21
fboutlaw
Cone Cruncher
fboutlaw's Avatar
Drives: Dinan 135i
I've used the Dinan Plates, Vorschlag plates, and M3 control arms in different stages of my build.
If you want solid, go with Dinan Plates. You get -1.5 camber off of them and it's really just a metal plate to move the mounting points. If you are still wearing down the outer edges, get M3 control arms as well which give you better steering feel as an additional benefit. This will get you around -2.3 deg, which is pretty ample for track.
I did go more extreme though with Vorshlag's and M3 arms, which give -3.7 deg camber, which I've found fantastic for track. There was a little squeaking the first 500 miles with the Vorshlag's in my case. Now there is zero noise and I don't notice any extra sound after 10 month, 7 autox's, and 3 track days.
      02-29-2012, 07:31 AM   #22
EFI Logics
EFI Logics's Avatar
The Dinan camber plates and M3 front suspension components compliment each other nicely. Seems like the perfect setup for someone who wants to set 'em and forget 'em.
-Josh
1addicts
