03-11-2012, 12:22 PM | #1 |
Rep 197
Advice for mild track/mostly street pads
I've been searching around and reading tons of info on breaks, but between the HOT(high operating temp) pads, good cold bite or hot bite, proper bed in or burnishing procedures this could all get overwhelming. I track the car maybe once or twice a month, not every month maybe every other month. I recently did my first HPDE event and pushed my brakes pretty hard, they smelled and some times i felt a judder from the steering wheel under braking. My stock pads also got some fade, pedal feel was constant but no bite. I think i may have gotten the stock pads hot even to burn them. The outer slopy edge of the stock pads look burnt and i got a nice black line on the outer circumference of my front rotors, see pic below. I want something just above OEM performance but that doesnt squeal like hell on the cold street drives, low brake dust if possible and that resist fade on the few track events i do. Thanks for your help.
PS- If i don't reach my brake pad sensor i could just leave the stock ones on when replacing my OEM pads(which are not worn at all yet). For future reference whats a safe or recommend minimum rotor thickness and pad thickness before needing replacement, front and rear. Thanks a mil! Last edited by yomny; 03-11-2012 at 12:31 PM.. |
03-11-2012, 05:47 PM | #2 |
Rep 197
Was thinking of running a front set of Endless MX72 but wanted something a bit less expensive for the rear since a full set could run for $700. I was thinking Hawk HPS for the rear, or maybe a full set of Prjoect Mu hc+, if i could find them here in the US. Any advice would be highly appreciated.
03-11-2012, 06:59 PM | #7 |
Rep 197
03-11-2012, 07:11 PM | #8 |
Rep 957
I used PFC Z-rated for street and track, and they are as good as it gets for street - like stock but with less dust and less initial bite (more linear). But not as good at the track, get slippery at higher temps. Still much better than stock, though, and when they overheat, there is no drama - plenty of warning, and they don't fall apart. They are cheap and last long, so may be a good alternative for a more expensive multipurpose pads like Endless or Pmu.
03-11-2012, 07:59 PM | #9 |
Rep 197
Quite honestly I think I'll be switching from track to street, don't really want to half ass things. I'll just get two sets and switch them. Thanks all for the advice.
03-11-2012, 08:45 PM | #10 |
78
Rep 684
For dual purpose pads, I typically recommend my customers StopTech Street Performance. They can withstand more track duty compared to stock, and they are generally quiet on the streets.
The next level up would be Project Mu HC+. It offers a super wide operating temperature range and is consistant up to 1,400 degrees. Probably one of the best dual purpose pads on the market. They do make some noise on the street. The next level up... BBK. Let me know how I may be of help.
03-11-2012, 08:58 PM | #11 |
Rep 197
I didnt' think i could get a set of HC+ over here so i had opted for a street/track set up. What do you recommend. I don't really have many tools or a comfortable place where i could swap the pads easily so my best bet really would be a good hybrid like these Project Mu's but i see you dont have it for the stock m3 brakes. The only setup you have both front/rear for on your site is for the stop tech street. Another question richard, how exactly, after talking about ideal pad operating temps and max heat capacity can i measure the temp on my rotors as well as the temp on my break fluid, to know if the fluid has been boiled or not? Thanks for your expertise!
03-11-2012, 10:48 PM | #12 |
78
Rep 684
I would recommend going with Street Performance pads first, and then upgrade as needed.
I will verify HC+ availability for E9X M3. The ideal way to measure would be using a contact pyrometer, but they are expensive. Using an infrared pyrometer should also work.
03-12-2012, 08:02 AM | #13 | |
Rep 3,833
Ferrodo DS2500 is a great dual purpose pad.
03-12-2012, 11:43 AM | #14 |
Rep 869
+1 on the StopTech Street Performance for dual duty.
+2 on the Pagids for dedicated track.
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20 |
03-12-2012, 01:57 PM | #15 |
Rep 197
Sounds greats, i think for the street i could stick with OEM as i'm already accustomed to the feel and reaction, plus they are covered by BMW. I'll get a set for track that could last me a good year or so, considering i only track HPDE once or twice a month, every other month. Whats your take on that? Thanks for all your advice! I would get the stop tech for street but i really dont have canyons or twisty roads here in miami to benefit from them and give away the free replacement from BMW OEMs.
So Pagids for track, Turner Motorsports is recommending the RS-7 rear with RS-19 front? What do you think? |
03-12-2012, 02:42 PM | #18 |
Rep 869
Try www.raceshopper.com. Edwin has good prices.
03-12-2012, 02:48 PM | #19 |
Rep 197
Thanks guys, now the million dollar question, how in the world do i know what brake temperatures im dealing with. All the pads have max heat capacity, and ideal operating temps, the brake fluid as well but how do i know what im dealing with, what do i need for my specific situation, based on my rotors, style of driving, car weight and all these factors? Thanks for all your advice, if it weren't for this community it'll take a lot of hard trial and error/experience learning, as well as very costly experiences.
03-12-2012, 05:17 PM | #20 | |
collecting toys
41
Rep 810
Turner used to sell the RS-19's for the back, but they don't anymore...... But use the RS-19's in front. great pads for the track
2011 e92 M3 Monte Carlo Blue ESS 535 - gone but not forgotten
2015 cayman GTS - new toy 2006 SLK 55 AMG sold |
03-12-2012, 05:25 PM | #21 |
Rep 5,508
Yommy, did you PM me regarding the HC+ pads? You can get them from Project Mu for the M3. It just needs to be ordered from Japan since they will be custom made.
The best price I got for the HC+ is $250 for fronts which is the same price as their Japanese OEM Brembo applications. IMHO pretty reasonable. I loved them on my Evo. With 400hp, 4 piston Brembos and less weight, they probably don't work the brakes as hard as the heavy M3 though. |
03-12-2012, 06:48 PM | #22 |
Rep 197
ZK so the hc+ are good for street and track? I just wanted to stick to oem for street and take advantage of the warranty replacing them, the use a set for track. I may not need a full race pad for track since I really don't track the car much at all. What do you think, maybe something just under full race track pads for the track to take it easy on the rotors? Really appreciate all your help, it's tough getting along just reading without some personal feedback.
