      03-21-2012, 04:58 PM   #1
theonlynameleft
Drives: 2008 128i all stock
How do I make this part looking clean like new again?
Not sure what the part is called, but in the picture its the part right behind the rim, not sure what I should use to clean it off, I was at the dealer the other day dropping my car off to get my lifters replaced (ticking noise ) and 8 hours later they called me saying they dont have the part. Either way I saw a new Z4 there and this part was silver/shiny brand new, how do I get this to look like that again? (Preferrably without taking the wheel off...
and btw, see that brake dust? That was after less than 2 hours of driving after washing
DSC_0391 by LizardMan86, on Flickr
      03-21-2012, 05:19 PM   #2
Derek8819
Derek8819's Avatar
35
Drives: 2015 F80 M3
It's rust. The rotors are steel. I took my rotors off and cleaned it all off with steel wool then coated that area with high temp clear paint to prevent oxidation. Looks like new still after 6 months.
      03-21-2012, 05:22 PM   #3
theonlynameleft
I don't have the necessary know how to do this, so there really isn't anything I can do though?
      04-14-2012, 08:59 AM   #4
stevenc
Coming Soon
Drives: 2015 BMW M4 Alphine White MT
Rotors in general are made of raw steel and therefore always have surface rust. Short of painting that area, there is nothing you can do.
      04-14-2012, 09:57 AM   #5
1Fasst1
1Fasst1's Avatar
Drives: 09 135i, Jet Black 6MT
Just remove the wheel and wire brush the area. You can use a dremel or electric drill ect, tape off the caliper and surface area of the disc and paint with a hi-temp paint of your choice. No mechanical experience is necessary.
      09-07-2013, 11:06 AM   #6
jmcgraw013
jmcgraw013's Avatar
Drives: '11 135i Cv
Rusted rotors - paint job
I also had badly rusted rear rotors, so I took off the wheels, sanded the rotor hubs down with a 150 grit sand paper by hand, wiped them clean, taped off the calipers and rotor surfaces with blue 3M painters tape and then used Rustoleum high temp silver spray paint with a couple of coats. Looks decent enough until I have the rotors replaced down the road.
'11 135i Cabriolet
Crimson Red, CPO, Savanna Beige Lthr, High Gloss, Shadowline
DCT, Prem Pkg, Sp Pkg, Value Pkg, Sirius, Alarm, CA, 264's
      09-08-2013, 05:18 AM   #7
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
You can try 1z wheel cleaner it is real magic.
      09-08-2013, 11:53 AM   #8
cpt97m3
AutoXer
34
Drives: 2009 135i
Painting them should work for a while. Another option is going with 2-piece rotors with aluminum hats. That's an expensive option, but if you need to replace the rotors anyway, these are lighter than stock. See: http://www.ecstuning.com/News/BMW_Bi...013/ES2550968/
2009 135i, Alpine White, 6MT, M-Sport, iDrive, iPod/USB, Heated Seats, Premium Sound, BMW Assist
      09-08-2013, 01:23 PM   #9
cpt97m3
AutoXer
34
Drives: 2009 135i
The link above is for front rotors, but I just realized you are looking for rear rotors. Here is a link to rear rotors with aluminum anodized hats: http://www.racingbrake.com/Two-piece...008-p/2167.htm
      09-11-2013, 06:58 AM   #10
TOGWT
TOGWT's Avatar
Drives: 630i
Hyde's Serum Rustopper -a spray-on anti-rust solution for your wheel and braking systems (Detailers Domain)
      09-11-2013, 06:42 PM   #11
Jmoney
Jmoney's Avatar
Drives: 2012 135i BSM/CR
This should help you out. I recently received my car from NJ and it was full of salt corrosion. This really helped my car... I used Einszett Colourtec wheel cleaner in combination with a Swissvax Wheel Brush.
http://scheerdetailing.com/shop/1z-e...-wheel-cleaner
http://www.swissvax.us/merchant.mvc?...de=ACCESSORIES
For all Swissvax USA Orders please contact Dominic Scheer using this page.
http://scheerdetailing.com/swissvax/
Hope this helped!
2012 LeMans Blue Metallic 135i Coupé - SOLD
2013 Mineral Grey Metallic 335i Sedan - Returned
2012 Black Sapphire Metallic 135i Coupé
Still keeping it classy with a Clutch..
1addicts
