      04-04-2012, 02:57 PM   #1
pearlwhites
pearlwhites's Avatar
Drives: 1M, 06 CTT, 07 A8L
Anyone using helix intake?
Anyone running helix intake on their 1M? How was install?
      04-04-2012, 03:35 PM   #2
Franklin Joseph
Drives: BMW
Install was easy. I bought a used n54 airbox as i didnt want to drill a hole in the factory one.
Basically drill a 2" hole in the airbox and use the supplied jbweld and attach the adapter kit and let it cure (i left it overnite). Dont drill the hole too low, else it wont clear the diverter valve.
Other than that, its pretty straightforward and there should be a bunch of intake DIY floating around...remove cowl to remove airbox etc.
      04-05-2012, 08:54 AM   #3
eric@helix
eric@helix's Avatar
Drives: 01 M Coupe, 08 135i, '12 328i
One detail: we now have replaced the JB Weld with marine grade epoxy putty. It's easier to work with and cuts down on installation time.
      04-05-2012, 10:57 AM   #4
MDORPHN
Drives: AW 1M
I'm running it. Couldn't be more pleased.
Neil
      04-08-2012, 11:00 PM   #5
pearlwhites
Thanks. I have one ordered and will be installing ASAP.
1addicts
