M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      04-22-2012, 04:05 AM   #1
clar
clar's Avatar
Singapore
144
Drives: M5
Post F10 M5 Active Sound Disabled (DIY and Audio Clips)
BIMMERPOST
     Featured on BIMMERPOST.com
Not a day goes go by without some "purists" lamenting the passing of BMW M greatness. The culprit for all these doomsday cries is none other than the infamous Active Sound in the F10 M5. Lame, pathetic, J-lo lip-sync, etc are words commonly used against it. I swear that if I wait a while longer, some "experts" would probably draw a co-relation between children exposed to Active Sound to serial homicide. I figure that if we are to demonize Active Sound, we should at least put a face to it, or in this case, sound. BMW's product literature did not indicate clearly what is being introduced.
To start with, let's identify the sounds in the cabin of the new M5. The following 3 sounds are most dominant in the cabin:
- Engine note
- Turbo whine
- Exhaust note
Some ask what happens if you change the exhaust? Is Active Sound gonna mix in the old exhaust note thereby ruining your new exotic exhaust? The short answer is No. To find out what AS introduced, I carried out a very simple experiment of disabling it via the fuse box and recording the sounds via a Zoom H4N professional handheld recorder. The recording device lightened my wallet by around US$300. Yes, some of u clowns are responsible for this damage...
Coming from a long history of failed DIY projects, I didn't wanna risk yanking out the fuse myself for fear of detonating the whole car. I drove the car down to the dealership (Munich Automobiles Singapore) and harassed the poor SA (KT) for assistance on this thankless task. The SA was very nice and helpful despite being very busy, so kudos to him. He promptly assigned 2 of his guys, which opened up my trunk and located the fuse box. They even pointed to the right fuse while I snap a picture of it as I would have to put it back on my own after my experiment.
Fuse #200 rated 40 amps was yanked out (photo below). It worked as advertised in Automobile magazine. I started the car and verified that the stereo was dead. I drove off with a couple of the dealership's staffs in tow for a quick test run of the car without AS. It is indeed quieter without AS so I figured I was ready and headed home. I couldn't have picked a worst time to yank out the fuse. On the way home on the highway, there was a massive jam for no apparent reason and there I was, stuck and crawling home without my stereo. Luckily the AC was still working. It must be noted that with the fuse yanked, the warning tone of the rear/front parking sensor is gone as well. That's something that almost caused me to reverse to the wall at the basement parking of my apartment.
I carried out the test the following day on a stretch of desolate road by doing a few runs on WOT with the fuse yanked, and then putting the fuse back and repeated the process. The recorder was secured onto the arm rest. After listening to the sound clips, I can safely say that AS adds only the engine note. The turbo whine and exhaust note you hear is the real deal. That makes me wonder if the whine could make its way into the cabin despite the sound insulation, why can't the engine note?
Attached are 2 sound clips for your listening pleasure. There is not much to get excited over. This car really needs an exhaust upgrade. I begin to wonder what is the real reason behind the introduction of AS. I am guessing it's not so much of the superior sound insulation, but that they were trying to mitigate the pain of moving away from that glorious V10. Going FI means you are gonna loose induction note. In the sound clip without AS, I can still hear the same engine note albeit a lot softer. That leads me to conclude that AS is basically to give you back some of what going FI took away rather than the sound insulation. For the factory to spec a louder exhaust would probably tip the scale too much towards being outwardly racy and offset the fine balance of performance vs executive touch. Personally, I can't wait for my Akra to arrive
Conclusion: Is Active Sound fake? I wouldn't say so. The engine note is a genuine production from the engine. Active Sound simply amplifies and play it back via the speaker. It's not live production, but I have never much liked live concerts anyway. Does it affect how I feel about this amazing car? Not one bit. Does it help the AS luddites accept this car? I highly doubt it, but that's not the purpose of this experiment anyway. Do I wanna see AS implemented on the next M3? Hell no...
Audio Comparison (Before and After Disable):
A little trivia: The owner of the dealership just took delivery of his new McLaren fax machine
- Frozen Grey F10 M5 DCT
- Rosso Corsa 458 Speciale Sold
- Frozen Grey E92 M3 Sold
      04-22-2012, 06:54 AM   #2
TonyMeister
Drives: Not a BMW...
Location: I'm here I'm there I'm F' everywhere I'm the eggman
None of the links worked for me.
      04-22-2012, 09:09 AM   #3
Grover432
Drives: 2013 535 XDrive
me neither
      04-22-2012, 10:22 AM   #4
singularity
Driver
singularity's Avatar
94
Drives: M5 (F10)
Links work fine and the difference is clear. The problem with active sound is that it doesn't sound realistic, it sounds like a video game otherwise I wouldn't mind.
Thanks for the extensive guide and a clear writeup, I'll pull out that fuse on my car too.
      04-22-2012, 10:29 AM   #5
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Here are the audio files in a format which should be accessible to all:
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook
Follow us on Bimmerpost Twitter
Subscribe to Bimmerpost Youtube Channel
      04-22-2012, 10:46 AM   #6
E90Fleet
South Africa
1312
Drives: BMW
I think there is a simple fix for BMW on this, leave the system in the M5 and all the next ones they have it lines up for, but put a option in Idrive to disable it.
Will make everyone happy.
BMW if you are reading, I need a job, Please.
      04-22-2012, 11:54 AM   #7
phish_100
United Kingdom
17
Drives: Azurite Black F10M M5
Pulling out the fuse disables the stereo doesn't it?
      04-22-2012, 06:48 PM   #8
AMPowerJ
One mod leads to another ...
AMPowerJ's Avatar
Drives: 2014 F10 M5
So how does this work if you have the stereo on? Wouldn't that defeat it as well?
Current: 2014 F10 M5
Previous: 2015 F80 M3, 2013 E92 M3, 2013 F10 M5, 2009 E90 M3, 1998 E36 M3
      04-22-2012, 08:09 PM   #9
clar
clar's Avatar
Singapore
144
Drives: M5
U can't turn on the stereo with the fuse pulled. It's like someone flicked the power switch to the stereo.
      04-22-2012, 10:01 PM   #10
AMPowerJ
AMPowerJ's Avatar
Drives: 2014 F10 M5
I understand that. I am talking about when the fuse isn't pulled and you are listening to music or talk radio. Does Active Sound still work then? I am not sure how it would.
      04-22-2012, 10:30 PM   #11
clar
clar's Avatar
Singapore
144
Drives: M5
Of course it does. It works even when you are on the phone via the car's bluetooth. BMW can't have it work sometimes and not work other times. That would be a dead giveaway. Listening to music or not, it works. There is just more sound coming out of the speakers that's all.
      04-22-2012, 10:40 PM   #12
phish_100
United Kingdom
17
I think this calls for another experiment with music playing at the same time. I often turn the stereo off as I feel I can't hear the 'note' with loud music on.
      04-23-2012, 02:33 PM   #13
pharding
Drives: 23 Audi Q4 e-tron + 14 X3 28i
BMW should let the user disable it. Fake is not good.
23 Audi Q4 e-tron; 23 i4 M50 on order
14 X3
Retired: 20 Tesla Model 3 LR AWD; 17 540i x; 14 550i Euro Del; 11 550i Euro Del; 08 550i Euro Del; 06 330i Euro Del; 04 545i Euro Del; 01 530i Euro Del
      04-23-2012, 02:41 PM   #14
Alan l.
Alan l.'s Avatar
5507
Drives: 2020 F95 X5M Competition
Now my question is this....is AS really just playing back what your engine actually sounds like or is it just playing a pre-recorded soundtrack by bmw? What if you added an intake to the car, would it sound different through the AS?
I heard the new lexus GS350 also has some intake noise generator making the car sound like a V8 when you step on it. Seems like this is going to be a new fad...
Alan
      04-23-2012, 02:49 PM   #15
Singletrack
4th down; 4th quarter? Renegade.
Singletrack's Avatar
Drives: 09 SSII E92 M3; 19 FG M5C
I couldn't hear a difference in sound in the video to be honest.
BMW should just make this configurable via idrive.
I would guess it can also be disabled via coding; without pulling the fuse.
      04-23-2012, 03:00 PM   #16
e92_m3
194
Drives: 2009 e92 m3
The same concept applies to the new 911 carrera s. They also have a sound amplification system on the new 911 carrera s, but for Porsche it's the real deal. It's called the sound symposer.
I was also wondering if changing the intakes would affect the active sound. How about adding a blow off valve (BOV)? Would it affect active sound as well???
It would be funny if you notice that the intake, BOV isn't synchronizing with the active system.
Hellaflush? All I could say is "effyo'flush","flushnuff", and Instead of 'illest', I'm calling it "faillest". It's just form over function nowadays...
-END RANT
      04-23-2012, 03:04 PM   #17
mookie45
mookie45's Avatar
770
Drives: 2017 AW 340i M-Sport
the tone sounds the same to me..but with active sound it's a little louder.
      04-23-2012, 03:07 PM   #18
boosted43
boosted43's Avatar
Drives: 2017 C43 AMG
2015 BMW 335i  [0.00]
MP4-12C
2014 X5 xDrive50i Mineral White | DinanTronics Stage 1 | Vossen HC3
      04-23-2012, 03:12 PM   #19
Diver
Diver's Avatar
Drives: Black '12 135i - Sold
I think the entire idea of active sound is really strange. They should have adjusted the car's sound insulation instead. Besides, who needs it in a car that has the goods in such enormous quantity?
      04-23-2012, 03:17 PM   #20
Rolitto
Rolitto's Avatar
Lebanon
Drives: BMW
I don't understand why some complain. It's a nice sound at the end.
      04-23-2012, 03:34 PM   #21
MistaVauros
///M... Nuff Said.
MistaVauros's Avatar
Drives: 2020 M5 Competition
2020 BMW M5C  [0.00]
Exclamation
The point is, BMW can't just FORCE this on the customer. Did BMW conduct a customer survey asking if more engine sound was needed in future vehicles? NO. It seems the designer of the M5 just decided, based on personal preference, that the F10 M5 needed additional engine noise in the cabin. There is no way you make a design decision like this on behalf of the consumer and make them live with it.
Present: 2020 M5 Competition (I'm back!)
Past: '17 Audi R8 V10 Plus, '13 M5 Comp, '13 X5M, '13 GT-R, '12 GT-R Black Edition
'11 E92 M3 ZCP, '05 E46 M3 ZCP, '03 E46 M3
"Dream as if you'll live forever, Live as if you'll die today" - J. Dean
      04-23-2012, 03:37 PM   #22
uhn2000
Big K...
uhn2000's Avatar
173
Drives: M3CS BX7
+1
I really don't see the issue here, how do you turn it up
Many fun toys... M3CS XB7 FTW!
Tags
2012 bmw m5, 2012 m5 forum, 2013 bmw m5, 2013 m5, 2013 m5 forum, bmw active sound, bmw active sound design, bmw f10 m5, bmw m forum, bmw m forums, bmw m5 active sound, bmw m5 active sound design, bmw m5 f10, bmw m5 forum, bmw m5 forums, disable active sound, disable f10 m5 active sound, disable m5 active sound, disable m5 f10 active sound, disabling f10 m5 active sound, disabling m5 active sound, f10 m5, f10 m5 active sound, f10 m5 active sound design, f10 m5 active sound disable, f10 m5 active sound diy, f10 m5 forum, f10 m5 specs, m forum, m forums, m5 active sound, m5 active sound diy, m5 f10, m5 f10 active sound, m5 f10 active sound design, m5 f10 active sound disable, m5 f10 active sound diy, m5 f10 forum, m5 f10 forums, m5 forum, m5 forums
m5post
