      05-10-2012, 08:14 PM   #1
hxman
18
Drives: 2011 135i
Masking a 135
I was wondering what parts people are masking on a 135?
Thanks
      05-11-2012, 03:52 AM   #2
TOGWT
TOGWT's Avatar
Drives: 630i
Painter’s Tape (Masking Tape)
Mask areas which would be difficult to clean afterwards and or any parts which can be damaged or stained if it comes into contact with the pad or polish being used.
When to use masking tape;
1. To avoid discolouring the trim with synthetic polishes
2. Avoid soiling the pad when going over black trim. The dirt from the rubber gets pulled into the pad an being transferred
3. Avoid polish residue built up along the seams of the trim.
4. Tape edges of paint as to not polish too far since paint is usually thinner on the edges.
5. Also, tape paint seams to avoid residue in the jams.
6. Badges or emblems or anything with ‘sharp’ edges that you are likely to 'catch'
7. Use masking tape to protect from ‘burning’ trim (rubber, vinyl or metal); around windows, badges, light surrounds etc, can also be used to mask panel edges to avoid thinning the paint surface
8. Tape trim and protruding edges, and any panel gaps that are hard to get into to clean.
9. Tape some newspaper to the windows and over wiper blades and lower windshield trim.
Use one hand to hold the roll taut and to guide the piece as your press it into place with your other hand. Scotch® 3M Painter's Tapes are the most versatile in the Scotch® masking tape line. The low adhesion levels make them suitable for use on both coated and non-coated surfaces and are specially designed for safe use on delicate or smooth surfaces such as glass and painted metal, even on freshly painted surfaces.
These tapes are also UV and sunlight resistant, making them ideal for use on glass surfaces, without leaving any sticky residue. Tape sizes available 0.75 to 2-inch
3M Scotch® Performance Masking Tape Green- highly conformable, provides the best adhesive transfer resistance, hugs curves, contours and provides outstanding paint lines. Goes on quickly and easily, sticks at a touch and stays put. This tape has excellent conformability, Transfer resistance, and is resistant to bleed through, also has better UV resistance than traditional masking tapes.
3M's Scotch® Safe-Release TM Blue Painters' Masking Tape, this tape removes cleanly from a paint film or glass surface without adhesive transfer or surface damage for up to 14 days - even when exposed to direct sunlight. It is a medium adhesion tape with a flexible crepe backing allows for exceptional conformability to semi-smooth surfaces.
Tape residue removal – use a safe solvent that does not contain any harmful components (heptanes or xylene or hydrocarbon aliphatic solvents) 3M™ Adhesive and Wax Remover, that simply emulsifies and dissolves the residue. It is important not to leave a solvent based chemical on the paint finish longer than is necessary.
Simply apply to the affected area, allow sufficient to react time, and carefully wipe off, you may have to apply it three or four times allowing plenty of "react time" between applications.
      05-12-2012, 08:08 PM   #3
hxman
18
Drives: 2011 135i
Thanks.... This would make a good sticky....
1addicts
