BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > Australia
      05-24-2012, 03:05 PM   #1
Pakoris
Drives: M3 2010 E90
Dash rattle
Hi All,
My M3 developed a rattle behind the sat nav. At least that's where I can pin point at this stage.
Anyone experience this before and the fix what dealers offer?. Bit nervous about dealer fulling the dash board out.
Cheers,
      05-25-2012, 10:42 PM   #2
Stockgtr
Stockgtr's Avatar
Australia
Drives: E90 M3
Hey mate.
I have the same. It's behind the sat nav, I actually think its the hard plastic cover over the speaker.
I spoke to bmw Melbourne about it, as usual they said they test drove the car and couldn't find it.
Typical!
I'll be going for the test drive next time as its getting really annoying, especially when the car is cold with rough idle.
Good luck with your rattle!
2011 E90 M3
R33 GTR Skyline Track/Fun car
Landcruiser
LS2 powered
      05-26-2012, 03:57 AM   #3
Pakoris
Drives: M3 2010 E90
Yes, exactly the same symptoms. Cold start makes it so very noticeable and annoying. Maybe it's a conmen thing with these models?
Anyone actually got it fixed?
      05-26-2012, 05:24 PM   #4
aussiem3
aussiem3's Avatar
Australia
274
Drives: Goggomobil
///M cars are full of rattles, squeaks, and strange drivetrain noises if you come from a regular BMW or any other brand. There is so much going in an ///M car you will not know where to start. Get use to it. Enjoy the car.
F86 X6///
      05-26-2012, 09:20 PM   #5
Stockgtr
Stockgtr's Avatar
Australia
Drives: E90 M3
Lol!
I have raced cars for many years now. One thing that I have found in both off road and circuit racing is that just because the car is quick, doesn't mean that the interior needs to rattle.
We are not talking bout the rough cold start mechanical noises or the clutch plate rattles. It's the plastic interior rattles in a $150k+ car that are disappointing.
Should not be any different to a 335i as the interior is almost identical.
Just disappointing for such an awesome car to drive as a daily driver. At the end of the day the m3 is not track specific vehicle, it's a well rounded daily driver that is supposed to do everything well, that includes not have interior rattles.
Hopefully at my next service bmw Melbourne can address this.
2011 E90 M3
Landcruiser
LS2 powered
      05-26-2012, 10:47 PM   #6
nez
nez's Avatar
Australia
Drives: e90 m3
I have the same problem. Intermittent only. Not too fussed. Also getting peeling trim around the steering wheel and driver side window controls.
      05-26-2012, 11:04 PM   #7
Mr C
Mr C's Avatar
41
Drives: E92 Dakar and E90 AW
NEVER have service pull the Dash. You want rattles, you will have plenty after that!
Just do a search for rattles after having the dealer pull the dash.
2011 E90 M3 Alpine White M-DCT
2011 E92 M3 Individual Dakar 6MT
      05-26-2012, 11:25 PM   #8
ole85
ole85's Avatar
Greece
39
Drives: e92 m3/ Ferrari360
i think there are post on how to fix the problems
      05-27-2012, 06:37 AM   #9
DaveDee
DaveDee's Avatar
532
Drives: BMW X5M Comp
Having pulled the dash and nav screen apart on a few occasions now there are a few areas I have seen that can cause problems.
The center speaker bolts can become loose , the screen wire harness are the likely culprits. Very simple and safe to fix with the right trim removal tool which only costs a few dollars. Just say if you need more info and you are happy to do this yourself. (I have some DIY dash /screen removal PDFs) You can buy the tool from many specialty tools shops. That and some painters tape is all you need What members say about taking to a dealership is spot on. Recently had an annoying rattle in the centre console which the dealer tried to fix then said that the whole centre console needed to be removed to find the rattle. By simply unclipping the handbrake gaiter I found the rattle in a few seconds.Makes sense if you think beyond an hourly rate
      05-30-2012, 12:02 AM   #10
Stockgtr
Stockgtr's Avatar
Australia
Drives: E90 M3
PDF
Thanks for the insight Dave.
Thats my big worry. The dealer will just create more rattles.
It would be awesome if you could share your PDF of instructions with us.
2011 E90 M3
Landcruiser
LS2 powered
      05-30-2012, 12:20 AM   #11
DaveDee
DaveDee's Avatar
532
No problems, I'll PM you with the attachment
      05-30-2012, 03:23 PM   #12
Pakoris
Drives: M3 2010 E90
Went to BMW Melbourne and they re-seated the center speaker and rearranged the wiring loop.
So far so good, will keep you all posted.
      12-14-2012, 10:12 AM   #13
rockymtnway
Drives: 2010 BMW M3
I too would be interested in this PDF - can you PM me it as well? I'm struggling with a rattle somewhere behind the console as well.
Thanks!
      12-14-2012, 02:44 PM   #14
ole85
ole85's Avatar
Greece
39
In my case it was a 10 mm bolt that holds the dash onto a mental pipe which goes behind the dash. to see it take your screen out and look deep back in the centre its the bolt and metal making the noise
      12-14-2012, 03:15 PM   #15
aussiem3
aussiem3's Avatar
Australia
274
Drives: Goggomobil
What I noticed during the CIC retrofit is the two nuts that hold the center AC vent can come loose. As Dave said, if you remove the carbon trim and tighten the two bolts it might fix, if the two are the culprits. I've had the car for five years now, and apart from that, and that too being my fault, no other rattles ... touch wood!! Hope this helps.
F86 X6///
      12-14-2012, 03:29 PM   #16
ole85
ole85's Avatar
Greece
39
i think were talking about the same thing
      12-15-2012, 01:19 AM   #17
DaveDee
DaveDee's Avatar
532
Thanks!
Here it is for everyone. Very simple
      12-15-2012, 01:35 AM   #18
MFKN3
MFKN3's Avatar
Australia
127
Drives: supercharged 4.4L stroker E92
I've had an intermitent ticking noise from the airvent, but it must be normal because my last E92 was the same. I kind of disgree with you though, BMW's shouldn't rattle at all when you pay that much for them and so much engineering and QC has gone into them. I drive rental toyotas and holdens and they rattle heaps, there's plastic everywhere.
That peeling trim was an issue across the 3 series. The dealer should hopefully replace them gratis for you as it is a well known issue. I think in my last E92, they replaced the entire passenger armrest but repainted the drivers handle, all on warranty.
m3post
