BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > Australia
Mporium BMW
      08-06-2012, 07:36 PM   #1
MFKN3
MFKN3's Avatar
Australia
127
Drives: supercharged 4.4L stroker E92
Brake upgrades?
Has anyone upgraded their brakes and can offer feedback - or fitted optional brake ducting?
The stock brakes are decent, but was thinking about fitting stoptech ST-60's to the front for ocaassion track use.
OEM brake fade isn't too bad, but just wanted to know if they're worth the big $ and will allow later and harder braking? Would there be any issues only fitting a front kit?
      08-06-2012, 10:16 PM   #2
nez
nez's Avatar
Australia
Drives: e90 m3
If its just occasional track use, a set of track pads would do the job. Plenty will fit the oem caliper. Just look at the tracking forum to get ideas in which ones to get.
To answer your question , a bbk may not necessarily equate to improved braking performance. Improved resistance to fading - yes. If course better resistance to fade means you can get on the picks hard more often but absolute stopping distance may not be significantly better. I've found that the main factor in how late you can brake is the size of your testicles.
As for the value equation, well that's up to you. There are plenty of guys with bbks who never intend to see the track but will attest to the value of a bbk.
There a plenty of guys who know much much more on this than I do on the suspension , brakes and chassis forum and I'm happy to be corrected by them.
      08-06-2012, 10:37 PM   #3
DaveDee
DaveDee's Avatar
532
Drives: BMW X5M Comp
This is a good post and seems to cover the subject fairly well...
http://www.m3post.com/forums/showthr...t=brembo+stock
and another one I know is on your mind right now
http://www.m3post.com/forums/showthr...ht=supercharge
      08-07-2012, 03:58 AM   #4
NBTBRV8
Drives: LCi E60 530i
For 4-6 track days a year I'd fit Pagid RS29 front pads and run Castrol SRF brake fluid, this would give you a pretty good session before the fade really set in.
      08-07-2012, 04:15 AM   #5
TurboBimmer
TurboBimmer's Avatar
Luxembourg
79
Drives: F82 M4
If you're semi-serious about tracking the car, I would strongly suggest investing into a BBK, at least for the front. The pedal feel, fade resistance and consistency is far superior to any "upgraded stock brakes setup". And it also gives you that piece of mind which is very welcome on the track, especially when it comes to braking.
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
      08-07-2012, 07:32 PM   #6
MFKN3
MFKN3's Avatar
Australia
127
Thanks for input everyone.
I tend to brake very late and hard and do get a bit of fade toward last few laps. My technique's probably not ideal though.
Fade isn't terrible though, so hard to justify $3,300 on an ST-60. OEM brakes are still very decent compared to other cars I have driven. I will prob look at some track pads for starters and I'm due for fluid swap soon too.
      08-07-2012, 10:26 PM   #7
OM VT3
OM VT3's Avatar
140
Drives: 2011 e92 zcp m3
OEM brakes are good for 8 laps at the most with hard braking
      08-08-2012, 04:24 AM   #8
nez
nez's Avatar
Australia
Drives: e90 m3
May as well get some stainless steel brake lines if your replacing your brake fluid.
      08-12-2012, 07:21 AM   #9
MFKN3
MFKN3's Avatar
Australia
127
Going with SS lines, track pads and motul 600. Sessions are quite brief and will complement 18" apex arc8 with Nitto nt01 275's all corners.
      08-12-2012, 08:13 AM   #10
nez
nez's Avatar
Australia
Drives: e90 m3
nice combo. which pads are you going with?
      08-12-2012, 03:19 PM   #11
Tomislav
Panty Schtuffer
Australia
21
Drives: 2008 E92 M3 Coupe
2008 BMW M3  [0.00]
2010 BMW X6M  [0.00]
1997 BMW 323i  [0.00]
1994 BMW M3  [8.00]
This. Have a look at your technique, or get someone to come with you and critique your driving. I've had professional drivers drive my car, and the things they could do was amazing.
.: 2010 E71 X6M - stock, daily driver, towcar :.
.: 2008 E92 M3 - 6MT, Carbon Roof, Eibach Springs, Megan Axle Back exhaust :.
.: 1997 E36 323i Frankenstein - too much to list, track whore, stripped, caged, MoTeC, S85B50 :.
.: 1994 E36 M3 3.0 - 19" BBS LM Reps, Bilsteins :.
      08-12-2012, 05:29 PM   #12
MFKN3
MFKN3's Avatar
Australia
127
HP+ pads. They're a track pad that are suitable to drive to and from the track, but no good for daily driving. Pagid's would have been nice, but would rather put that money towards BBK. Will see what difference this set up makes...
Thanks Tom, I know. I have another training session soon
      08-12-2012, 09:59 PM   #13
Tomislav
Panty Schtuffer
Australia
21
2008 BMW M3  [0.00]
2010 BMW X6M  [0.00]
1994 BMW M3  [8.00]
I have EBC Green in both cars (the e36 and e92) but the E36 has AP's and it'll stop all day every day.
I am not so sure on the E92, with the EBC's and stock everything else (but better fluid) I don't think it does very well. I came down Mt Hotham one day and the smell and feel of the brakes was shithouse.
The E36 might go to yellow's soon seeing as its not registered any more, so I don't need to think about brakes on a normal road anymore.
      08-12-2012, 10:22 PM   #14
jpc
jpc's Avatar
Australia
Drives: E90 2011 DCT ESS VT2-650 SC
A couple more thoughts that may be helpful.......
1. OEM rotors are not heavy duty enough to cope with track use if you change up your friction material. They will crack out from the drill holes.
2. In respect of the above, if you get BBK, make sure you get slotted rotors.
3. I run a Brembo GT 380 front and 365 rear. Cooked a hardware set using Hawk DT 60. After replacing, Brembo recommended Pagid RS29. They have been really very good.
4. COOLING is vital. If you drive hard and want to get the most from your track sessions, you need this. I have custom backing plates (Cantrell racing)
that direct ducted flow from my duct inlets (on front lip) to the centre of the rotor for centrifugal venting, which is basically A race car setup.
5. Don't buy all the tales about DD use. If you can tolerate at bit of noise and a slight hit on cold brake performance, it's not worth the hassle of constant pad changes.
6. SS lines and high performance fluid a must.
7. Don't remove the backing plates - they are heat shields that protect lines, sensors, ball joints, etc from rotor heat
If you are track-serious, go a BBK. Brembo, Stoptech both good. Also locally, a poster on this forum (can't recall alias) produces Harrop - look quite nice.
Cheers
J
2011 E90 DCT, ESS VT2-650 SC, Brembo BBK 380/345
AKRA Evolution system, RKP motorsport Lip /brake cooling ducts/diffuser, KW Clubsport coilovers, TMS race solid subframe mounts, performance seats/steering wheel, RMS harness, Sneed GT wing.
      08-13-2012, 02:12 AM   #15
MFKN3
MFKN3's Avatar
Australia
127
Cheers
J
Thanks JP,
OEM brakes at the local track hold up fine on 15min sprint sessions, so will be interesting to see the difference after mods. When my car does back-to-back sessions though it does get a bit hot.
Was looking at cooling but the GTS duct kit is too dear. If only someone made an entire aftermarket duct, pipe and back plate kit... Also can't believe this feature didn't come stock! I think cooling alone would probably make the OEM setup miles better.
That's good to know about DD track pads. I heard the hawk hp+ are very very noisy and will chew through rotors when cold. I have to swap wheels, so pads would take an extra hour probably. Could probably leave them in during track season though.
I'm just happy and privileged getting out to a track in an M3 for a bit of fun It's an addiction
      09-04-2012, 11:42 PM   #16
MFKN3
MFKN3's Avatar
Australia
127
The track pads, fluid and steel lines were night and day over stock.
Highly recommend!!
The Nitto NT01 semi slicks also held up well.
      04-20-2018, 11:04 AM   #17
byroncheung
Drives: e90 m3, 997.2 c2s, x166 GL450
my OEM rotors' life is up and need replaced.
what are the recommendation for replacement rotor that will fit the stock caliper? Looks like there are a few choices like OEM, Zimmerman, StopTech?
i'm thinking about trying the ferodo DS2500 pad that everyone seems to like as well.
      04-22-2018, 12:56 AM   #18
Joe S
Joe S's Avatar
Australia
151
Drives: E92 M3 Competition Package
Get the Harrop Ultimate brake kit
[IMG]http://www.xbimmers.com/forums/image.php?type=sigpic
      04-30-2018, 10:21 PM   #19
byroncheung
Originally Posted by KevinKMi View Post
Излишняя сухость воздуха – это извечная летняя неувязка. Зимой втомжедухе воздух может быть некотороеколичество суховат. Мойка окон зданий в современных жилых помещениях все реже сталкивается так именуемая генеральная организация интерьера. Так что ежели вы ощущаете, что ему нехватает воды, то элементарно добавьте ее. Приобретите маленький увлажнитель, настройте его и подключите.
Хорошо, ежели приспособление станет делать еще и очистительные функции. Регулярная влажная чистка Ну и, естественно же, невозможно забрасывать о влажной уборке. Проводить ее необходимо как минимум 1 2 раза в недельку. В современных жилых помещениях все реже сталкивается так именуемая генеральная организация интерьера поддерживающая уборка коттеджа цена . Следует воспринимать, что пыль в дом заносится в всяком случае, и этого момента никоимобразом не избежать. Зато разрешено избежать лишнего скопления данной самой пыли, не дозволяя ее скопления желая бы на раскрытых поверхностях. Так что чаще держите в руки влажную тряпку и швабру, и ухаживайте за собственным зданием.
Wow this is really helpful to my questions... thanks kevin! Say hi to Donald for me!
      05-09-2018, 05:11 PM   #20
Ski1
Drives: F80 M3
Guys,
anyone care to commont on the option of just change the front brakes to a Stoptech 355 or similar, and leaving rear as original fit?
Currently:
Stock rotors and calipers front and rear
EBC yellowpads
Race fluid
SS lines
Conty road tyres
I get a small amount of pad (not fluid) fade after 20 mins on track.
When I start with semi-slicks I suspect the greater heat into the brakes will become by limiting factor.
Just change the front calipers to something like Stoptech 355 ??
      06-16-2018, 04:31 PM   #21
Ski1
Drives: F80 M3
anyone?
      06-16-2018, 05:29 PM   #22
DaveDee
DaveDee's Avatar
532
Originally Posted by Ski1 View Post
anyone?
Jarrad changed his front brakes to Harrop and left the rears stock. As you know he mostly uses the car on the track and it's driven pretty hard and he's had no issues so it's a good option the direction you are taking
m3post
