08-13-2012, 02:18 PM | #1 |
111
Rep 365
ER charge pipe - DV or blow off
I'm planning to buy a an ER charge pipe for my 1M and can't decide whether to reuse the stock DVs or get the TIAL blow off set up. A third option would be the Forge replacement DVs.
My car is stock and my objective is to increase reliability for street use and occasional HPDE. Looking for opinions as to advantages and disadvantages of each set up. Thanks |
08-13-2012, 02:47 PM | #2 |
Rep 140
I too am interested in hear others preference and results..
I also am curious exactly what does the charge pipe look like? Apparently there are two different models. One for those 2010 and earlier N54 (that have a remove-able accordion rubber connector and 2011 and later models where the rubber piece is permanently attached. Can anyone confirm which one is correct for the 1M..?? I would assume the longer but is that absolutely a necessity.. ?? Thanks.. OP - I am planning on running the original DVs.. As I do not plan on tracking my car and I am still on the fence about a tune. Great Car.. |
08-13-2012, 03:20 PM | #4 |
Rep 508
get an ER charge pipe with a forge DV. You'll lose about 5-7hp with a blow off valve.
E92 M3 DCT/ESS VT-575/FABSPEED hfc's/AE exhaust/BBS LM 19'/ KW CS/RD sways/STOPTECH TK/ RECARO PP /BMW PSW/WIECHERS SPORT roll cage/CF parts that covers the back seat/VRS hood/bumper/csl trunk/diffuser type 2/CF:mirror cap/side & front grills
08-13-2012, 03:59 PM | #5 | |
111
Rep 365
08-13-2012, 04:31 PM | #6 |
Rep 2,898
08-13-2012, 05:19 PM | #7 |
20
Rep 325
Not sure about the n54 valves from forge but typically they are serviceable and you can swap the springs to a desired levels.
In short, the car was designed for DVs unless you want to tune around the complications of BOVs you should stick with DVs. |
08-13-2012, 05:26 PM | #8 |
Rep 4,848
Definitely DVs unless you go very high boost. Don't want to loose that power to sound .
Macan S Diesel - Carrera White
Macan Turbo - White 1///M - Valencia Orange |
08-13-2012, 05:41 PM | #9 | |
Rep 4,848
08-13-2012, 06:17 PM | #10 |
1M Owner
36
Rep 239
I had this same question recently when I replaced my broken stock charge pipe with the ER pipe. I have the COBB stage 2+ intercooler tune, so I'm running more than stock power levels. I asked COBB about the advisability of upgrading the stock diverter valves and here is the advice I got:
"Initially the stock valves should hold up very nicely. Heat and time does takes it's toll on them. If you want to be cautious, I would recommend the Forge BPVs. They have worked great on the our 335i stock all the way up to the aftermarket turbos. Hope that helps." So, I plan to wait until my stock ones melt or wear out at some point in the future. So far, all the new plumbing is holding together. |
08-14-2012, 05:48 PM | #11 |
69
Rep 359
08-14-2012, 07:12 PM | #12 |
Rep 770
08-16-2012, 09:52 PM | #13 |
11
Rep 33
08-17-2012, 03:32 PM | #15 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Stock DV's with ER CP is fine if you are stock or slightly elevated boost levels. Forge DV's will give you more reliability at higher boost levels.
We went with the BOV simply because of the cleaner look, without the additional couplers. |
08-17-2012, 10:02 PM | #16 |
11
Rep 33
08-18-2012, 01:28 PM | #17 |
Rep 14
I'm curious too. I'm planning on upgrading my charge pipe along w the HKS bov. Haven't heard anything about loosing power. Why the sudden remark w no explanation?
08-22-2012, 03:19 PM | #18 |
Rep 770
08-22-2012, 06:00 PM | #19 |
Rep 4,848
I am not sure about losing 5-7hp as I have seen no data on this. I would say theoretically at higher rpm where our stock turbo struggles would see some benefit having air recycled back after the turbo.
Now, BOV has been run on many N54 without any report of loss of power so it might not be significant. That swoosh sound many people like to hear carries some energy - but probably not that significant.
08-22-2012, 06:59 PM | #20 | |
Rep 770
09-17-2012, 10:54 PM | #21 |
69
Rep 359
hmmm, in actual fact there is no difference at all between DVs and BOVs.
I'm currently running my ER chargepipe together with Tial BOV, the response seems better than stock IMO. Anyone tried both BOV and Forged DVs? |
09-17-2012, 10:58 PM | #22 | |
69
Rep 359
So can you tell us if there is a difference between ER CP with forge DVs and the ER CP with a BOV? |
