      08-18-2012, 10:58 PM   #1
chappy
chappy's Avatar
Australia
102
Drives: 335 M-SPORT COUPE
E92 M3 Rear Subframe Bushes Installed
Prestidge and Performance at Coorparoo installed the M3 rear subframe bushes and the rear end is nice and settled at full WOT 1st and 2nd no squirming anymore nice and firm great with the high torque that this car has,
Lets a bit more road noise in, but worth the expense.
THE BEAST MHD Flash Tune /M3 suspension/Forge Intercooler/Alpina B3 AT Flash/Bilstein B4 Suspension/BMW OEM M3 Steering Wheel and DCT Paddles/LUX V4 Angel Eyes/CIC Retrofitted
      08-18-2012, 11:18 PM   #2
BMW86
Australia
398
Drives: RS3 Sedan / Macan S
Nice, been wanting to do this for a while. How much was labour and how long did it take?
LSD next?
      08-18-2012, 11:39 PM   #3
chappy
chappy's Avatar
Australia
102
Around $600 for labour including wheel alignment which is needed front and rear and takes about all day.
      08-19-2012, 03:28 AM   #4
TimMc
TimMc's Avatar
Australia
44
Drives: E90 M3
Ditto.
Did you get a rear sway fitted at the same time Chappy? Do you already have the M3 rear control arms? How much extra noise is there? Do I ask too many questions?
Driving - Manual E90 M3 (Melbourne Red/Black).
Riding - BMW R1200RS Sport.
      08-19-2012, 05:16 AM   #5
chappy
chappy's Avatar
Australia
102
Originally Posted by TimMc View Post
Ditto.
HI TIM
I fitted the rear M3 sway bar a long time ago and no have not fitted the rear control arms a bit of toss up for that one and the noise is noticeable,but not too bad.
      08-19-2012, 07:07 PM   #6
Stuart@BMRAutowerkes
Stuart@BMRAutowerkes's Avatar
808
Drives: a black car
I'm looking forward to doing this as well
Let me know if anyone would like pricing on the above.
- M3 Front Sway Bars inc bushings
- M3 Rear Sway Bars inc bushings
- M3 Rear subframe bushings
- M3 Trailing arm bushings
- M3 outer camber link bushings
- M3 inner camber link bushings
In stock most of the time as well.
      08-19-2012, 07:57 PM   #7
Nugget
Nugget's Avatar
650
Drives: G81 M3 Touring, GR Supra GTS
2011 BMW 135i  [10.00]
I installed the Subframe bushings and the front control arm kit.
TBH I didn't notice a massive improvement. Not sure it's worth the money.
      08-20-2012, 08:04 AM   #8
koastal
Australia
376
Drives: F87
I imagine the improvement won't be noticed unless the limit is being explored, which shouldn't be on the street.
      08-20-2012, 04:34 PM   #9
chappy
chappy's Avatar
Australia
102
You can feel it straight away slightly more firmer in the rear end, but if you car is stock, yes you would not feel much difference only when the car is highly tuned and going full throttle through the gears the car would wobble from left to right with the high torque but now it perfect and powering out of corners the rear doesn't skip over bumps, just bites now.
If your still on crappy runflats and stock you might not tell much difference, normal tyres the bushes are too soft, bmw made the bushes soft for the runflat tyres.
      08-20-2012, 08:29 PM   #10
BMW86
Australia
398
That's pricey, should have installed these when I had my LSD installed. Will do it one day
      08-20-2012, 09:16 PM   #11
Nugget
Nugget's Avatar
650
I went to a tuning session a couple of weeks before and a couple of weeks after it was done.
It felt slightly different but not necessarily better. But I also think the wheel alignment they did is dodgy.
I have Michelin PSS and didn't notice a big difference (only stock power though).
What is completely gone, and what I found most disconcerting about the car when stock, is the pause before changing directions at higher speeds eg even just changing lanes at 130kmh.
      08-21-2012, 01:13 AM   #12
John_01
John_01's Avatar
Australia
232
Drives: E90 325i, E82 135i
I have the same issue with the 135i. Very weird steering response that becomes worse at high speed. Now with BMW Performance suspension its only half as bad as the stock car. Did you change any other aspect of the suspension at the same time as changing the bushes?
I felt the paused steering response seems like a bump steer issue. I heard the rear end tends to toe in as the suspension is compressed. Maybe the initial body roll tends to cancel out some the steering input. I'm in two minds about getting the subframe bushes done, because the cars handling isn't upsetting me as much now as it was. I also thought about getting adjustable rear dampers that might give a bit more lateral stability to the rear suspension.
      08-21-2012, 01:42 AM   #13
Nugget
Nugget's Avatar
650
I also have BMW performance suspension which made a much bigger difference than the bushings or front control arm kit.
I'm no expert but to me it felt like the issue was the soft bushings and suspension being loaded up before it would change direction.
      08-21-2012, 02:32 AM   #14
John_01
John_01's Avatar
Australia
232
Nugget, Thanks for the reply. I also have the M3 front arms, Performance suspension and Michelin PSS tires. Its good to hear that from someone who has the sub-frame bushings in addition to the mods I have already.
For now the car performs to the level I would expect of a BMW coupe. IMO, the stock M-sport suspension was way underdone, particularly the lack of damping, under-steer, and the large amount of body-roll.
      08-21-2012, 04:35 AM   #15
Nugget
Nugget's Avatar
650
If I was you I probably wouldn't bother with the bushings then.
I'm pretty happy where it's at as well, only thing I might add is camber plates as there is still a fair amount of understeer at the track.
      08-22-2012, 07:10 AM   #16
TimMc
TimMc's Avatar
Australia
44
Drives: E90 M3
Maybe if I installed these I could hold it flat out through the "kink" at Lakeside. At the moment myself & the car are too nervous to do this.
      08-22-2012, 07:22 AM   #17
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
The M3(1M) subframe bushing really make the car more stable at high(er) speeds. Also in town the rear end doesn't slop side to side - as IF its being held in place with rubber bands. Its been reported that after a year or two the rear OE bushings will be shot. Mine were very "soft" when I upgraded to M3 units.
The biggest change I noticed was how much better the front suspension seems to work! The back end has way less "wiggle" or "movement" and does exactly what you want it to do. When I drive over pot holes I no longer weave or try to miss them. These M3 bushing just soak them in. When corning hard and applying some power (WOT) in a turn.. the back end never does anything funny.
In short these M3 bushings are a MUST HAVE mod.
Dackel's replacement of rear suspension OE bushings with M3 ones…
http://www.1addicts.com/forums/showthread.php?t=638163
Dack
      08-22-2012, 07:50 AM   #18
BMW86
Australia
398
I let off through the kink as well Tim. I think the only times I don't are when I don't have enough speed coming onto the main straight so I'm not going as fast. I've been for a passenger run in Simon's car and thought he was going to kill us first time he went foot flat through it.
      08-23-2012, 05:32 AM   #19
TimMc
TimMc's Avatar
Australia
44
Drives: E90 M3
Even Simon backs off in my car through the kink. Before he drove it he scoffed at me for backing off...
1addicts
